10-22-2013, 04:06 PM | #5 |
58
Rep 376
I am in Tampa and I have coded my car... Not sure how technical you are wanting, but it is pretty straight forward. I have cable and software.
10-23-2013, 09:13 PM | #6 |
393
Rep 3,893
not bad. i'll check with our Tampa chapter rep and see if he knows anyone up there also that can help...
10-24-2013, 09:09 PM | #7 |
Rep 93
Drives: 2014 335i M SPT - PPE/PPK - AW
+ 1 for some F30 coding in tampa
10-24-2013, 10:46 PM | #8 |
58
Rep 376
If anyone in Tampa wants to meet up for some programming just send me a PM, so far I have done video in motion and auto folding mirrors with door lock/unlock
11-13-2013, 09:11 PM | #9 |
58
Rep 376
UPDATE:
Had a little coding fun this weekend with my and my friends F30s. Pretty straight forward coding multiple cars. Things coded this weekend: Car always starts in ECO mode (for my hippie friends) Activate Sport + mode in non-sport (me of course) TPMS shows actual pressure and temp Car ringtone matches iphone ring tone GPS clock matching Some more mirror open close with door locks and I have done video in motion before as mentioned. If anyone in Tampa area wants any coding done I am pretty comfortable with it now. Just send me a PM |
03-04-2014, 04:10 PM | #11 | |
58
Rep 376
In addition, I have done a lot more coding since I started this thread including: flashing brake lights on hard braking enable sport + mode (in non sport line/m-sport cars) enable sport automatic transmission enable launch control (a lot more complicated than regular coding though) and a lot more.. |
03-04-2014, 09:27 PM | #12 |
Rep 133
Thanks for the reply. Maybe we can try to get together in April or May. There are a few changes I'd like:
Doors unlock with ignition off Disable Nav startup screen Flashing brake lights TPMS pressure/temp display Has the sport auto trans been confirmed as a software only change from the standard 8AT? I've been trying to find documentation on that but haven't seen anything definitive.
Holy #&%@, it's flat.
03-16-2014, 04:47 PM | #14 | |
58
Rep 376
I am in and out of town until April so that would be best for me. PM me your details anytime in April to arrange a time to set it up. |
03-17-2014, 05:52 PM | #15 |
61
Rep 702
Sounds good thanks!!
Is there a thread that lists everything possible for coding?
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
03-31-2014, 05:43 PM | #16 |
58
Rep 376
I am back in town and able to do coding for some peeps.. Just send me a PM and we can arrange something.
As far as what can be coded, there is info spread out, but for the most part you can look at the description using the database found here, www.bmw_codingdatabase.com/ (just remove the underscore between bwm and coding) Otherwise you can look through the 281 pages found here: http://www.f30post.com/forums/showthread.php?t=696777 I can also bring a list with me that shows everything |
04-25-2014, 09:30 AM | #17 |
Rep 67
Drives: F33 M Sport 435i
Can the dealer tell that you have made changes to the coding (giving them a way to void the warranty)?
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk |
04-25-2014, 11:14 AM | #18 |
1140
Rep 1,137
From my understanding(someone correct me if I'm wrong), yes the coding can be traced even if you go back and undo it before you take the car in for service. Chances are, if you just go in for an oil change or something minor, they won't say anything about it. I had my car in to have my glove box lock replaced and they didn't say anything about mine, but mine aren't majorly noticeable changes(M performance logo on instrument panel being the most obvious, Tire Pressure/Temp display, video while driving, comfort access windows up with remote, other small things). If you were to go in for "Hey my head unit stopped working" and they found that you had coded it, then chances are they would try to deny it under a warranty claim.
Additionally, if you have the car in for service and they do a software update, more likely than not it will clear away your coding meaning you would have to go back and do it again with updated software. |
04-29-2014, 06:27 PM | #19 |
61
Rep 702
I'm wanting the following things coded. Are these possible and am I missing anything else big?
-audio starting at last position when car is started (at current playback if using iPod) -auto folding mirrors with lock/unlock -TPMS showing psi and temp -disable warning screen on iDrive at startup -ASS work in Sport mode -ability to configure Sport mode in iDrive menu
04-29-2014, 07:34 PM | #20 | |
58
Rep 376
04-29-2014, 08:21 PM | #21 |
61
Rep 702
Thanks for the info!
So your car will turn off (ASS) when stopped in Sport mode (the button not the shifter to the left)? Mine only will in Comfort or Eco Pro This thread talks about the current playback coding http://www.f30post.com/forums/showthread.php?t=950004
05-02-2014, 11:33 AM | #22 | |
58
Rep 376
