Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Replacing the fuel breather pipe
      03-19-2013, 03:44 PM   #1
BeakerBoy
52
Drives: BMW 330i
I finally decided to deal with the strong smell of petrol around my car whenever I fill up the tank.
There is a flexible breather pipe which runs from the top of the fuel tank back to near the fuel filler cap, which vents air from the tank when fuel is poured into the tank. This pipe passes through an aperture in the car and it rubs against an edge on the fuel tank side of this aperture, eventually causing a small hole in the pipe and allowing excess fuel to dribble whenever the fuel level is high.
I took some photos to help with reassembly, but thought I would post them on this forum with some notes in case it is of help to anyone. I have included details of fastener types and torques wherever possible.
1. Preparation:
Before starting, it makes the job a lot easier if the fuel tank is almost empty. Otherwise, drain as much fuel as possible from the tank into a suitable container.
Slightly loosen the nuts on the rear right-hand side wheel, since the hand brake and propeller-shaft will already be disconnected when it is time to remove the wheel.
2. Remove centre console:
Remove the gear knob by pulling firmly upwards (do NOT twist). On the M-Sport, the gear knob is glued to the gaiter, so it is best to grip around the top of leather gaiter. The frame of the gaiter is held in by four plastic lugs. Carefully detach the gaiter from the centre console trim.
The centre console trim panel is secured by eight metal spring clips. Use a pry tool to remove the panel, taking care to protect the surface of the plastic console.
Remove the two plastic covers and remove the screws underneath (10mm hex socket).
Move both front seats forward to provide better access to the rear section of the centre console. Use a pry tool to release the top edge. Release clips either side near the carpet by carefully reaching underneath or use a suitable pry tool. Disconnect the cable connected to the air-vent and remove the rear section of the centre console.
Remove the two screws (10mm hex socket). Unplug the two connectors indicated and snip the cable tie. (I have also inserted an M5 washer on either side of the arm rest hinge to cure a rattle.)
Move the seats back to a mid-way position. Open the storage compartment and carefully pry the handbrake gaiter out of the centre console.
The centre console can not be removed because it fouls on the hand brake. To overcome this problem, release the handbrake, then reach beside the handbrake press upwards on the black plastic lever below the handbrake mechanism whilst simultaneously lifting the hand brake lever. The hand brake lever should now lift much higher than normal (about 6 notches further than normal). This allows the centre console to fit over the handbrake so it can be removed upwards and towards the rear.
3. Disconnect airbag control unit:
First disconnect the battery negative terminal (12mm hex socket, 5Nm) then wait a few moments to be sure that there is no power on the airbag system.
Remove the foam cover from the airbag control unit. Unplug the two connectors indicated, by opening the plastic levers. Then remove the two nuts and one bolt (10mm hex socket, 8Nm). Note the position of the negative lead and ensure it is replaced during reassembly.
Remove the airbag control unit, taking care to avoid static discharge.
4. Disconnect handbrake:
Use a medium (approx 6.5mm) flat screwdriver to push the handbrake adjusting spring backwards and engage the locking mechanism.
Lift the plastic cable tray out of its two rear mounting points, to access the handbrake balance arm. Open the black plastic retaining clips on the balance arm, then lever the handbrake cable anchors out of the balance arm.
Finally, use the screwdriver to release the handbrake adjusting spring, back to its normal position.
5. Remove rear seat:
Whilst working inside the car, it is a good time to remove the base of the rear seat. Firmly lift the front edge of the seat to unclip it on the left and right. Feed the seat-belt buckles through the openings in the seat. Then remove the seat.
6. Remove exhaust:
Raise and secure the back of the car, then support the rear of the exhaust system.
Release the eight M8 bolts securing the under-body reinforcement plate (T50 Torx bit, 30Nm).
Unfasten the four nuts between the downpipes and the exhaust (15mm hex socket, 45Nm). If these nuts are corroded then they will be difficult to release. Replace the four M10 copper nuts during reassembly (P/N 18301737774).
If necessary, soak the nuts/bolts overnight in penetrating oil (PlusGas). Any broken bolts can be drilled out and replaced, but it is time consuming and best avoided.
Tap the joint with a mallet to free the exhaust from the downpipe.
Details of the exhaust system will vary for different models, but these images are for the standard exhaust on an E90 330i.
Unfasten the exhaust clamp (E10 Torx socket, 21Nm).
Unfasten the front hanger (18mm hex socket, 30Nm).
Unfasten the left rear hanger (E18 Torx socket, 21Nm).
Unfasten the right rear hanger (E10 Torx socket, 21Nm).
Disconnect the hose to the pneumatic valve which activates the exhaust flap.
With help from a second person, remove the temporary exhaust support and lower the exhaust away from the car.
Upon reassembly, either replace the two gaskets (P/N 18107549447) or apply copper grease to the mating faces.
7. Remove under-body panels:
Remove the front and rear sections of the heat shield, then the triangular and mid sections of the plastic under-body panels.
Remove the left and right under-body covers adjacent to the rear wheel arches. Each cover is secured by two plastic screws (T30 Torx bit) and two small plastic expanding rivets. The rivets can be removed using a pry tool and pliers, or alternatively the centre pin can be punched out. The rivets will probably need to be replaced (P/N 51161881149).
I also removed the long left and right side under-body panels, but this may not be absolutely necessary.
8. Remove propeller shaft:
Mark the position of the propeller shaft relative to its connections, so that it can be reassembled in the same relative position.
Raise at least one of the rear wheels off the ground so the propeller shaft is free to rotate. Put the transmission in first gear to lock the propeller shaft. Start removing the three M10 bolts connecting the rear giubo to the differential input (E12 Torx socket, 20Nm + 90º). It will be necessary to put the transmission in neutral and rotate the propeller shaft to gain access to all bolts.
Put the transmission in neutral so the propeller shaft is free to rotate. Remove the three M12 bolts connecting the front giubo to the output of the transmission (18mm hex socket, 55Nm + 90º). Use an 18mm open-ended spanner to hold the nut while turning the bolt. The spanner fits through the transmission mount, which also provides a convenient anchor point for the spanner.
Remove the two bolts securing the propeller shaft centre joint (13mm hex socket, 21Nm) and lower the centre mount so that the propeller shaft is in a ‘V’. First detach the rear of the propeller shaft from the differential input flange then detach the front of the propeller shaft from the transmission output flange.
Upon reassembly, clean and apply suitable grease to the centre mounts at each end of the propeller shaft. BMW recommend Dow Corning Molykote Longterm 2 Plus. Important: Upon reassembly replace the three nuts and six bolts (P/N 26117526140, 26117523709, 26127536563) and ensure that they are correctly torqued.
9. Remove handbrake guide tube:
Remove the six bolts securing the handbrake guide tube (10mm hex socket, 8Nm). Pull the guide tube towards the rear and feed the handbrake cables out of the car.
The rubber gasket should be replaced (P/N 34406764925) if it is damaged.
10. Remove wheel arch cover:
Remove the right rear wheel. Release six screws (8mm hex socket) and five plastic nuts (10mm hex socket). Free the outer edge of the wheel arch cover from around the wheel arch where it meets the car body. Then feed the cover downwards and out of the wheel arch.
11. Remove fuel tank:
There are two circular metal covers located under the black insulating material which lies beneath the rear seat. Remove the four screws from each of these covers (10mm hex socket) and lift up the covers. Disconnect electrical plugs. Under the left cover, disconnect the fuel feed line by pressing the grey ring away from the fuel line. Under the right cover, disconnect the fuel vent line by pressing the quick-release fastener.
Inside the wheel arch, disconnect the fuel breather pipe from the top of the fuel filler pipe by pressing the quick-release fastener. It might help to also twist the breather pipe to help work it free.
Unfasten the hose clamp (6mm hex socket, 4Nm) on the fuel supply hose at the rear of the fuel tank. Place a suitable container under the tank then disconnect the hose. There may be a dribble of fuel depending on the residual level in the tank. There is a non-return flap at the mouth of the opening. Insert a clean screwdriver or similar implement into the opening to release the non-return flap and allow any remaining fuel to drain into the container.
Support the fuel tank as there will probably still be some fuel remaining in it.
Remove the bolt securing the centre of the tank (13mm hex socket, 19Nm). Remove the two bolts securing the retaining straps on the left and right sides of the fuel tank (13mm hex socket, 19Nm). Remove the two retaining straps and the two exhaust heat shield retaining brackets.
Lower the fuel tank from the car. Empty any remaining fuel from the tank as it will be easier to refit when it is empty.
Detach the old breather hose by pressing the quick-release fastener and replace with a new vent pipe (P/N 16126765748) and a protective tube (P/N 16124390434). The old damaged breather pipe looked like this.
This is the aperture that the pipe rubs against.
The new breather pipe looked like this, although the first image does not show the protective tube, since I opted to slide it through from the wheel arch.
12. Reassembly:
Reassemble the components following the reverse process.
Pour at least 10 litres of fresh fuel into the tank. Check operation of the hand brake, although it should not be necessary to adjust the hand brake.
This job took two days, including taking photographs and cleaning many of the components removed from the car.
Appreciate 5
      03-22-2013, 09:23 PM   #2
tcw
52
Drives: 2008 335i
Impressive DIY! Seems like a lot of work for a relatively small problem.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
      03-23-2013, 05:23 PM   #3
cisach
cisach's Avatar
11
Drives: 2007 335i Coupe BSM/CR
2007 335i Coupe  [0.00]
HOE-LEE-SHIT
2007 335i BSM/Coral Red | White DCI | Alpina AT Flash |
      03-24-2013, 07:24 AM   #4
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
You couldn't just access it thru the wheel well?
      03-24-2013, 08:07 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Very nice DIY.
But why did you have to remove the center console? Couldn't you unbolt the rubber flex disc (quibo) from under the car? And how did you "fix" that rough edge circled in your photo ? Did you just grind it down?
      03-24-2013, 09:29 AM   #6
nc1mike
Drives: Red e90 335i Sport
Your DIY is excellent, but my god that's a lot of work!!!!
      03-24-2013, 11:43 AM   #7
BeakerBoy
52
Drives: BMW 330i
This is a £650 job at the dealer or approx. £300-£400 at an independent. Several other people on the forums have had this fuel leak problem and a few have done a DIY - but I couldn't find any photos from anyone, so thought I would share. I spent £50 on parts and quite enjoyed tinkering with the car for the weekend.
Some of the tasks involved in this DIY might be relevant to other jobs, e.g. changing the giubos (spelling?), changing the hand brake cables or solving armrest rattle.
The fuel tank cannot be removed without first removing the exhaust, heat shields, propeller shaft and hand brake cables as they all run underneath the centre of the fuel tank. I believe some of the independents disconnect the hand brake cables from the wheels, but the BMW recommended method is to remove the centre console and disconnect the cables from the anchor.
Some say it is possible to loosen the fuel tank and disconnect the breather pipe in-situ. Having removed the tank and seen how tight the tube is connected, I am quite impressed that people have managed to do it that way.
Although I said that the fuel pipe chafes against a sharp edge on the car body, the edge is not razor sharp, it just isn’t rounded. If the pipe rubs against this edge then it will wear. I think the real question is why is the pipe rubbing, i.e. why is the fuel tank moving?
There should be four square foam pads on the top side of the fuel tank (one of these pads is visible on a photo). Three of these were not in place, so my fuel tank could move slightly, even though the retaining straps were secure. After I removed the tank, I cleaned the outside surface and reattached these pads, so my tank is now firmly held in position. However, I think there might be a better solution – perhaps replace with a larger piece of foam?
      03-24-2013, 02:55 PM   #8
Ml3456
14
Drives: 2013 X3 & 335i E93
Breaker boy, what kind of jacks are those under the rear tires. Never seen something like that before.
Thanks, ML
      03-25-2013, 11:40 AM   #9
BoondogUK
England
28
Drives: Monaco Blue e90
Spot on... I have just had mine done for a shade under £300 from an indy.
Pre LCI Monaco Blue e90, iDrive, 18" 220M reps, M3 Front Bumper, LCI headlights, Darklines, Eibach Pro Kit [Build Thread]
ICE: DLS R4s, Gladen HG-201BMW-3, Alpine PDX 4.100
      03-25-2013, 03:52 PM   #10
BeakerBoy
52
Drives: BMW 330i
Thanks, ML
The jacks under the rear wheels are hydraulic ramps, from cjautos.
The ramps are very useful to lift/lower my cars for servicing without using a trolley jack or conventional ramps (which don't clear the front bumper on most modern cars).
Here is a review of the ramps...
ramp review.pdf
      02-23-2014, 03:12 PM   #11
Born2driveCZ
Born2driveCZ's Avatar
Czech_Republic
Drives: BMW 330i E90
Hello, first of all thank BeakerBoy very much for this DIY. Good news is no more petrol on the road, but I probably did some mistake with mounting propeller-shaft. On second gear during full load car starts vibrate. Unfortunately I removed also front flex disk (I didn't know that this is not neccessary) and I forgot to mark position of the flex disk also
I think that here can be the problem. Maybe wrong position of bolts or reversed sides of the flex disk (transmission side and propeller-shaft side). Does anybody know if exist some procedure how to install OEM flex disk? Or any idea what I could do wrong?
Thank you in advance for your help
...Life is race...
Biginboca3763.50
      03-02-2014, 10:33 AM   #12
Born2driveCZ
Czech_Republic
Mine assumption was correct. I reversed flex disk. Correct position you can identify by arrows. See pics. I did not notice it. Everything is alright now. Car goes well with full tank!
BTW: Bmw should bear the consequences. I think that this issue with breather pipe is very dangerous. Especially with gasoline engine.
...Life is race...
feuer4275.50
      03-03-2014, 01:52 PM   #13
mazac
Drives: BMW 330xd 2005
Fantastic howto! Thanks for this.. Just changed the fuel breather pipe today, was really a pain .. now all OK
BeakerBoy/all, can you please tell me/quide me where do you find torque values for all screws ? I looked TIS but I can hardly find all which you mentioned here in TIS.
Thank you!
      03-04-2014, 02:30 PM   #14
Born2driveCZ
Czech_Republic
It can help, but I used values by BeakerBoy.
...Life is race...
      07-13-2015, 10:01 AM   #15
Bob Shiftright
Save The Manuals!
Bob Shiftright's Avatar
64
Drives: E91 Schleppwagen
Attachment 835672
Thank you for posting this -- because I could not find the picture anywhere else -- but I can not seem to get the black plastic lever to move to release the handle.
I am likely missing something obvious, because other posters seem to have removed the console without too much difficulty and didn't even mention this part of the instructions. I am baffled at the moment although it could be in part because I am doing this half-blind since the console is still in place and because of my large hands.
Thanks!
2008 E91 36K, 6-speed, RWD, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Euro split armrest, Lidatek, remote V-1, Cocomats, beach sand, $10 clutch stop mod. 1998 Volvo V70T5 226K, 5-speed, original clutch (third clutch pedal!), aspheric driver's mirror, E-code headlights, IPD sway bar, strut tower brace & skidplate.
      07-13-2015, 11:12 AM   #16
Bob Shiftright
Save The Manuals!
64
Victory!
I got it to go by jiggling the handbrake handle while pushing on the lever -- eventually it fell into place and released.
Sorry to be a bother, and apologies for double-posting!
      06-18-2017, 02:46 PM   #17
Rogue335d
Drives: 335da m-sport
Guys I just wanted to give my two cents on this.
I decided to save myself a few hundred and went in under the rear seat with a 30mm holesaw. It worked out nicely and taking my time measuring took about 2 hours to get the new pipe and protective sheath installed.
Im just waiting on a few grommets coming to plug the holes.
The way I looked at it it's my car I can drill holes where I like.
Appreciate 2
feuer4275.50
      08-03-2017, 10:32 AM   #18
E90_330xi
Drives: E90 330xi
That solution seems to be worth a try. So you cut the holes through which you unclip the breather pipe end from the tank and then you pull it out backwards? Is the wider clipping part of the pipe an issue, is the bodywork hole big enough for it to go through?
      04-12-2020, 09:29 AM   #19
Sensible_
529
Drives: 2008 E90
Old thread. Just thought I’d let people know the hole drilling method above works a treat. You can do it with just the hole on the side (lower hole in the photos). Slide a screwdriver in and push on the white clip. Pull the pipe out at the same time, from under the wheel arch liner.
It’s an easy job. 1 hour max. Seriously no point in dropping the tank. I drilled a 20mm hole and that was enough to get the screw driver in to depress the white clip and lever
      04-13-2020, 06:05 AM   #20
bluewater328
626
Drives: 2011 bluewater 328i LCI sedan
Thinking about exploring this. Is there a telltale way, without pulling it completely apart that you can tell it's this besides just the smell (ie fuel regulator and charcoal canister also have same symptoms)?
Also for the hole, just the side hole on the passenger rear area is good (you said about 20mm)? Was there any fear of cutting anything wrong along the way and what of the debris cleanup?
Was it easy to reconnect the hose afterwards? Were long-noses pliers the order of the day?
Would a simple tape-off be a resolution or is it only a whole piping replacement that works?
      04-15-2020, 04:36 PM   #21
Sensible_
529
Drives: 2008 E90
Old thread. Just thought I'd let people know the hole drilling method above works a treat. You can do it with just the hole on the side (lower hole in the photos). Slide a screwdriver in and push on the white clip. Pull the pipe out at the same time, from under the wheel arch liner.
It's an easy job. 1 hour max. Seriously no point in dropping the tank. I drilled a 20mm hole and that was enough to get the screw driver in to depress the white clip and lever
I got the tell tale puddle of fuel left by the wheel arch after filling the tank and leaving the car. It got quite bad.
I did actually drill the 2 holes but I'm sure you could do it with just the one on the vertical part of the seat bodywork.
To release it you need a long narrow flat head screwdriver through the hole and pry out the white plastic from the connector. You then lever out the connector whilst pulling the other end of the pipe from the wheel arch.
It may be stuck on a bit, you just keep pulling and levering and eventually it comes off. Pull the pipe out from the wheel arch.
You can repair the pipe by plastic welding or maybe some export stuff. I replaced it though. Then duck tape and then another extenders corrugated plastic pipe on-top (bmw has it own part number for this, but it literally is just a piece of black flexible cable management tubing I think.
The other end of the pipe is easy to take off fro under the wheel arch liner. Just squeeze and pull.
To fit the new/repaired pipe you need to line it up as before. You then push hard from the wheel arch end whilst levering the connector in place until the white clip clicks into place. You can see the white clip physically click into place also.
I've filled the holes with grommets. I used a hole drill bit so all I got was a little disc back. Hoovered up the little pieces.
I'd probably drill the bottom hole in the photo a little more to the right. Then you'd definitely not need the top hole.
      04-15-2020, 08:39 PM   #22
bluewater328
626
I dig the grommets, where did you source those?
I'm going to pull the wheel liner this weekend. Figure I'd be able to at least see if it's frayed when I take a look at the hole area.
