CIC Legal Disclaimer
03-17-2013, 10:27 AM | #1 |
33
Rep 648
So I understand from reading and doing it on my own car that in order to deactivate the idrive legal disclaimer in the CCC module that I change
Legal_Discl nicht_aktiv but that value wasn't in the CIC module I tried to code. I found these: Macro_Cam_LegalDisclaimer ld_mit_timeout Macro_Nivicam_LDisclaimer ld_mit_timeout Legal_Disclaimer_Time kein_ld Early_Video_LegalDiscl kein_ld Am I in the wrong module or do I need to change one of these values? I'm assuming it isn't as simple as making one of them nicht_aktiv. |
03-17-2013, 10:55 AM | #4 |
33
Rep 648
04-08-2014, 11:18 PM | #6 |
583
Rep 2,233
Drives: '12 M3
So is this under CAS, FRM or NFRM when I load up NCSExpert? I hate this warning in my 09...
04-09-2014, 12:09 AM | #8 |
583
Rep 2,233
Drives: '12 M3
I figured it out under CIC, but it's weird that i have to first load up one of CAS/FRM/NFRM to get my VIN read by NCS... that's where my confusion was. I guess once it's loaded, it doesn't matter what I chose out of those three and I can select from more modules under Process ECU and just go from there.
04-09-2014, 12:19 AM | #9 | |
16
Rep 128
load ncs f1 f3 e89 then always (cas) then back then process ecu (this is where you actually choose the module you want to work with.. same procces all the time.. |
04-09-2014, 05:58 PM | #10 |
Rep 66
like above states, go through normal steps and when you select Process ECU select CAPPL, then continue. I just did this in my 08 it was listed as CAPPL.
08 335i E90, BMW PE, Coded
99 328i E46 Sedan stock |
