03-16-2013, 03:30 PM | #1 |
Rep 9
Error lights after spring install
Just install H&R springs to my F31. Drove off and all these error lights pop up to my dashboard. Any ideas what can cause this? I also tried to reset the tire pressure monitor but it only gives me FTM system error!
And what the he.. that check engine light doing in there! Check control: - Brake system. drive mo... - Flat tyre monitor (RPA) ... Last edited by _r4_; 03-16-2013 at 03:38 PM.. Reason: Updating... |
03-16-2013, 04:54 PM | #2 |
209
Rep 3,288
Drives: anything given a chance
I'm guessing you probably disconnected a few things without disconnecting the battery first?
You might need to find a mate with a code clearing tool or take the car to your dealer to make the bad lights go away. |
03-16-2013, 06:36 PM | #3 |
Rep 24
I'm guessing you broke one of the ABS sensor wires on one (or more) of the axles while replacing the springs unless you unplugged one and forgot to plug it back in.
2012 328i Sport - Mineral White - Coral Red - Xenon - H/K - PDC - Surround View - BMW Assist w/ Enhanced BT - Premium Package - Fold Down Rear Seat
03-17-2013, 07:16 AM | #4 |
Rep 9
Maybe you are right! I didnt disconnect the battery. Does F3x have any warning lights reset option like E9x has?
03-18-2013, 06:52 AM | #5 |
209
Rep 3,288
03-18-2013, 06:26 PM | #7 |
413
Rep 1,975
No problems here and I didn't unhook my battery. Make sure all of the sensors on the shocks/struts are securely and properly replaced
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
03-19-2013, 02:51 PM | #8 | |
Rep 9
These fault code we find, P15C9 and P15DD. P15DD - Vehicle speed, wheelspeed sensor right/rear P15C9 What this is ??? |
03-19-2013, 04:19 PM | #9 |
11
Rep 184
i think you didnt plug all the abs sensors back...check if all the abs sensors are plugged in correctly lol
03-19-2013, 06:01 PM | #10 | |
413
Rep 1,975
I think you should go to every corner, unplug all sensors, blow in them to make sure there's not dust or debri and reconnect. I can't see how it is anything else unless you somehow clipped a line or something but I don't even see how that could've happened.
03-20-2013, 12:01 AM | #11 |
Rep 9
03-20-2013, 05:27 AM | #12 |
17
Rep 174
Find out the code and see what sensor is bad, you probably pulled the wires too much and it ripped inside. So they all look find but the wiring is back.
2013 EB2 335i 6MT
