diagnostic cable / software
03-14-2013, 06:31 AM | #1 |
woman with spanners
17
Rep 122
hi
is anybody using the diagnostic obd code reader / software like this one on ebay item 200905835663 ? are they good / easy to use? i suppose at that price its worth a try ? regards kathy |
03-14-2013, 07:16 AM | #2 |
14
Rep 282
I'm using in for fault codes and reset. It took me a week to install it. But it works. If you using windows 7 64 bit is even harder to install it. I tried on 64 with no luck. Then on 32 bit (my old laptop) no problem.
06-16-2013, 09:52 PM | #3 |
Rep 26
06-18-2013, 07:40 AM | #4 |
56
Rep 623
Drives: F10 530d M Sport, E87 118d M
Yes - I have used a similar cable together with the INPA and DIS software to read the technical codes to help me diagnose my ABS/DSC faults.
I used INPA for the brake bleeding process after the ABS/DSC unit was rebuilt. I also used the DIS software to read the DPF back-pressures which gave me the comfort that, despite the car having covered 142,000 miles and showing a remaining life of 14,000 miles for the DPF, the DPF is hardly clogged and actually good for another 120,000 miles or so. I also discovered a fault code indicating that the fogging sensor had failed in the module located around the rear view mirror. I traced this back to when my windscreen was replaced by Autoglass. I called them and they asked me to pop in and they replaced the fogging sensor without question. These cost around £60.00. I spent many hours setting up the software (I downloaded from various sources) and building a number of VMs which now do the job. Having a spare laptop is handy - as well as an interest in IT. I guess I have made some decent use of it as well. Just be careful it doesn't take over your life - I have a code showing that one of the glow-plugs has failed and I keep thinking about replacing it - but the car starts perfectly no matter what the outside temp. I am also showing a fault with the "Additional Water Pump" but the heating works fine - especially since I replaced the thermostats. You can end up being a slave to the technology if you are not careful.
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
06-19-2013, 06:06 AM | #6 |
889
Rep 9,097
Expect an influx of pms from all sort of members on this forum who will be willing to give you tuition. All the best!
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
