Gear box oil?
03-14-2013, 08:54 AM | #2 |
1545
Rep 8,970
The grades below are as BMW spec for the 335i, so check your grade spec for your gearbox and diff,
The brands below are top quality full synthetics, I used them after reccomendations on here: Gearbox oil - 2 litres of Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic Diff oil - 2 litres of Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil After changing the box oil I really noticed an improvement in shift feel and smoothness. |
03-14-2013, 11:15 AM | #5 |
1545
Rep 8,970
Its not a sealed box, just BMW reckon you don't need to change the oil ever, probably right technically, but it can't hurt though, and mine felt a lot smoother when changed for a top notch oil at 42k.
It still has a drain plug underneath and a filler/level plug on the side. |
03-14-2013, 12:30 PM | #7 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Possibly for the auto, but not for the manual.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
03-15-2013, 05:22 AM | #9 |
14
Rep 282
That's why I will thinking to change oil. And my car is over 70k miles and is good time to change. I don't believe in anything in long life if is not maintain properly. If was build 20- 30 years ago then probably
03-15-2013, 08:34 AM | #11 |
622
Rep 3,198
Mine's the same. Tried new oil with no improvement. About to fit revised mounts:
http://www.ca-int.co.uk/single_prod.php?prod_id=201
03-15-2013, 09:10 AM | #13 | |
1545
Rep 8,970
03-15-2013, 03:13 PM | #14 | |
622
Rep 3,198
http://www.opieoils.co.uk/p-981-fuch...ion-fluid.aspx
03-16-2013, 04:31 AM | #16 | |
26
Rep 639
03-21-2013, 08:45 AM | #17 | |
622
Rep 3,198
Bear in mind though that mine is MSport spec, which I believe has a shorter throw and stubbier knob than the SE as standard, so the effects might be different with another model. Worth the money? Hmmmm maybe - useful mod, but probably a bit overpriced for what they are. Just my five penn'orth... Next job...replace the CDV valve!
03-21-2013, 09:08 AM | #18 |
1545
Rep 8,970
Nice work Phil,
I've got he mounts coming, so hopefully it will tighen things up a bit. +1 the Msport has a slightly shorter 'knob' but the shift arm & mech is identical between models, so throw angle is the same across model. I've got the BMW Perf short shift kit, which has a whole new shift arm that changes the linkage geometry, giving a much shorter angle of movement. It also has a stiffer vibration damping section in the two part shift arm. It has a nice bolt-like action, so I hope these new mounts will make it even better! Last edited by doughboy; 03-21-2013 at 09:14 AM.. |
03-21-2013, 01:22 PM | #19 | |
26
Rep 639
Great review, i will pick a set up. Will these fit an pre lci e90? (just to be 100% certain) Also, are these relatively easy to fit? |
03-21-2013, 06:10 PM | #20 | |
622
Rep 3,198
http://www.e90post.com/forums/showthread.php?t=804839 plus if you're buying the mounts made by Rogue Engineering, you'll receive fitting instructions with the goods.
03-22-2013, 03:15 AM | #21 | |
26
Rep 639
03-22-2013, 03:26 AM | #22 |
622
Rep 3,198
Seriously looks worse than it is. Took me about 20 mins...but if you're not confident, get a good indy to do it for you.
