03-14-2013, 01:29 AM | #1 |
///M Enthusiast
30
Rep 357
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
jb1 issue.
Sup fellow f30 members, so I have a 328 n26 with a jb1 with 5k on the car and i've noticed my car makes a grinding sound on start up and changing gears from 1-3k rpm. Not sure what it is, might be a charge pipe? Anyways should I remove my jb, clear it, and take it in? Don't think its normal.
03-14-2013, 03:12 AM | #2 | |
193
Rep 3,780
But yes.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
03-14-2013, 09:21 AM | #3 |
233
Rep 1,177
Hope the dealer doesn't have a way of checking whether you had it installed before.
Current: 2022 X3M Comp
Previous: 2020 X4M Comp | 1982 E24 633CSi | 2016 F82 M4 | 2015 F80 M3 | 2014 F30 335xi | 2013 F30 335xi | 2010 E92 335xi |
03-14-2013, 06:55 PM | #6 |
101
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
How is this related to a JB1 issue?
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
03-15-2013, 12:13 AM | #7 |
///M Enthusiast
30
Rep 357
03-15-2013, 01:02 AM | #8 | |
101
Rep 3,566
Have you had a chance to remove the JB1 & test?
03-15-2013, 08:32 AM | #9 |
///M Enthusiast
30
Rep 357
not yet.. too lazy to take it out, LOL. im probably going to end up doing it asap then check before taking it in though. but you do have a good point, doubt the problem is due to the jb.
03-15-2013, 12:51 PM | #10 |
Hooah!
Rep 126
Too lazy? It's potentially hurting your car and you're too lazy to take it out to see if its the problem? SMH.
'11 E90 335i M Sport Black Sapphire
'13 F30 328i M Sport Black Sapphire |
03-15-2013, 03:27 PM | #11 | |
101
Rep 3,566
How does a piggyback tune affect a cold engine/transmission grinding startup?
03-15-2013, 09:15 PM | #12 |
Rep 31
As the power gain with JB1 is fairly modest, most likely it is coincidental that your car is having grinding noise and happen to have JB1. Factory tuned cars have problems all the time. And since JB1 is the most popular tune right now, the likelihood of such owner reporting problem with their car is more.
But I would still take off my tune just to be on the safe side. |
03-16-2013, 12:37 AM | #13 |
71
Rep 556
Drives: 2012 BMW 335I
When you say grinding sound, is it grinding from the engine? Does it do it while your moving or not moving? Could it be something else like something with your suspension grinding?
03-16-2013, 02:47 AM | #14 |
///M Enthusiast
30
Rep 357
its when i first start the car and im idle in park, then the other sound happens when moving slowly in low gears around 1-3 rpm.
