Coding out headlight checks ( just want to review )
03-13-2013, 04:20 PM | #1 |
362
Rep 1,407
Drives: 13' F30 328i 6MT
Hello All,
I have been reading a ton of posts/sticky and just want to make sure im not missing anything to fix this issue. To make a long story short I am helping a friend out who bought aftermarket headlights for his halogen equipped 07 E90 without knowing he would need to code his car for them to work, Needless to say since putting them in he has an error and no headlights only fog lights and DRL's. From what I gather we need the following :
Tested ( laptop can talk to car successfully ) Now the only coding we are trying to do for now is fix his headlights ( CODE out Voltage Checks ) From what I gather this is all we need to do. Following coding -Disable Bulb Testing in Headlights NFRM module KALTUEBERWACHUNG_AL to nicht_aktiv (low beam cold) WARMUEBERWACHUNG_AL to nicht_aktiv (low beam warm) KALTUEBERWACHUNG_FL to nicht_aktiv (high beam cold) WARMUEBERWACHUNG_FL to nicht_aktiv (high beam warm) KALTUEBERWACHUNG_BLK_VO to nicht_aktiv (turn signal cold) WARMUEBERWACHUNG_BLK_VO to nicht_aktiv (turn signal warm) KALTUEBERWACHUNG_SL_V_L to nicht_aktiv (parking lamp left cold) WARMUEBERWACHUNG_SL_V_L to nicht_aktiv (parking lamp left warm) KALTUEBERWACHUNG_SL_V_R to nicht_aktiv (parking lamp right cold) WARMUEBERWACHUNG_SL_V_R to nicht_aktiv (parking lamp right warm) FEHLERMELDUNG_CC_SL_V_L to nicht_aktiv (parking lamp left error code) FEHLERMELDUNG_CC_SL_V_R to nicht_aktiv (parking lamp right error code) Can anyone confirm this is all we need to do? I want to do a bunch of other things in the future but that I can learn as I go. Im pretty tech and auto savvy so once I do it a few times im pretty sure it will be a walk in the park. We are gonna attempt this on a 1 hour lunch break at work. Thanks in advance guys, I will be following the .pdf in the sticky and have read and done as much research before posting.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 03-13-2013 at 04:31 PM.. |
03-13-2013, 04:23 PM | #2 |
72
Rep 838
It will be an easy coding job bud dont worry. Make sure to disable the FEHLERMELDUNG_CC etc checks for the other lights as well if possible. Might not be able to depending on your car
03-13-2013, 09:55 PM | #3 |
441
Rep 18,331
If its DEPO lights....Have fun coding them and make sure you have some coffee and something to eat because you will be there for quite some time and find out that it still wont work..
03-13-2013, 11:00 PM | #4 | |
362
Rep 1,407
Im hoping this is basic, It appears so I just dont know enough. Shouldn't be to hard, Ive datalogged and burned roms in my other car plus I work on computers for a living.. Just not familiar on this platform yet and would hate to make a mistake that could cost alot to fix.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
03-14-2013, 05:14 PM | #6 |
362
Rep 1,407
Not halogen they are projector just non HID with halos.. Look pretty much like depots. there not mine I have OEM HID's Im just trying to help him out.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 03-15-2013 at 02:03 PM.. |
03-14-2013, 07:47 PM | #7 |
441
Rep 18,331
If they look like Depot lights, then your in for a long day...Please come back and let us know how it went..
03-14-2013, 08:50 PM | #8 |
33
Rep 648
If all of this coding fails I would try going the physical route. I'm not an expert on BMW lighting diagnostics so this is theory but here are my thoughts: the frm measures resistance (or lack of) in a circuit to determine if there is a fault. The resistance of the headlight circuit is different than that of the OEM headlights for one if three reasons: the angel eyes are on the same circuit as the headlights or the wattage of the headlights is different or both. Higher wattage bulbs draw more current (less resistance) while lower wattage bulbs draw less current (more resistance). Angel eyes in parallel with headlights decrease resistance while angel eyes in series with headlights increase resistance and variance between OEM and aftermarket bulb wattage just adds a little more to the equation. If you draw a wiring diagram and post it I could take a look, it might be less of a headache than trying to code out the errors. What you would need to do is place a resistor in the circuit in series or parallel to mimic the OEM circuit or possibly get one of those AE harnesses that keeps them on all the time.
03-15-2013, 12:31 AM | #9 | |
362
Rep 1,407
03-16-2013, 01:43 AM | #10 |
362
Rep 1,407
Wish me luck and thanks for the help Its a 2007 Halogen E90 328ix
03-16-2013, 01:55 AM | #11 |
Rep 83
Drives: 2009 AW/CR E93 335i 6MT
03-16-2013, 05:37 PM | #13 |
362
Rep 1,407
No luck yet, Only got a 30 min window to try today as the weather is kinda crappy in NJ.
INPA Connects then when I try to read the airbag as a test per the .pdf I get the following error : So it appears I either missed a step when setting up my laptop or mis-config'd something.. Its XP ill tripple check and retry when there is better weather. Currently I am reading up to see what maybe wrong.
03-16-2013, 06:26 PM | #14 | |
33
Rep 648
03-16-2013, 09:12 PM | #16 |
362
Rep 1,407
Here is the cable I am using -
When I plug into the OBD port it lights up, Im assuming the issue is on the laptop side of things. Is Windows 7 32bit preferred over Windows XP or is it irrelevant?
03-17-2013, 04:50 AM | #17 |
49
Rep 347
I think your software is old, you have to update it, I can help you, PM me.
INPA and rest of softwares work on Windows 7, even on 64 bit version. |
04-02-2013, 01:36 AM | #18 |
No 55mph
1622
Rep 8,476
I've coded my car MANY times + many other cars - I have NEVER got the airbag test to work on any of the cars...
No worries, as long as you get the black communication dots in the previous step you're good to go. That airbag test really has nothing to do with whether the car will code or not. So as long as you get the communication dots - just got on ahead with the coding and skip the airbag test
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
04-02-2013, 01:59 AM | #19 | |
362
Rep 1,407
