Speed limit coding help
03-08-2013, 05:16 AM | #1 |
41
Rep 164
Hi guys
Is it possible to code e92 speed limit warning light to come on 140km not 120???
BMS Dual intake system RB PCV Valve BMS Oil Catch Can BMS Oil Thermostat COBB FMIC COBB AccessPort V3 Aerodynamic kit M Package Cp-e BOV Cp-e 3" catless DP Wedge performance stg2 map
03-08-2013, 08:17 PM | #2 |
Rep 288
... didnt even know there was one!
At least our US spec cars do not have one, so I believe the fact that you do have one would be coding controlled, so you should be able to uncode the light completely or change the speed |
03-08-2013, 11:38 PM | #4 | |
89
Rep 1,529
09-01-2013, 03:45 AM | #5 |
295
Rep 2,202
Just did this to my car today and felt like I invented slice bread! Lol I am not sure of the speed change tho but I will try changing speed and see what happens.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
09-02-2013, 10:11 AM | #6 |
886
Rep 9,097
If you have normal standard radio, then you can code the speed limit in KMBI.TRC.
By default its 120KM, unless you know a way to change it. If you have idrive (CIC), then you can add any custome speed limit or just disable it.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
09-02-2013, 11:12 AM | #7 |
295
Rep 2,202
Since the keyword here takes the literal speed as variable, would it be to just put whatever desired speed in? say 100KM?
09-21-2016, 02:02 PM | #9 |
Rep 9
I was able to change mine through the Idrive, don't remember what it was set at but I was able to raise it to 200kph, it's pretty deep in the menu's but it is there.
