BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Can anyone help and tell me what this noise is please?
      03-06-2013, 06:59 PM   #1
mspired335i
42
Drives: 2021 M5
Hey guys like the title states , I have a very weird noise in my engine bay , and it increases the more I push the throttle down. Its really worrying me as I hope its not the bottom end. Mods are just dual cone intakes and Jb4. Any help would be greatly appreciated.
Link:
      03-06-2013, 07:14 PM   #2
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
My car makes the same noise from time to time. Does it do this all the time? I have heard others talk about this and seems pretty common. I'm sure if you do a search you can find something that talks about the noise your describing.
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
      03-06-2013, 07:17 PM   #3
mspired335i
42
Drives: 2021 M5
Hey man thanks for your reply. And yes it does this all the time . Sorry for the crąppy iPhone quality.
      03-06-2013, 09:47 PM   #4
BillionPa
BillionPa's Avatar
Drives: 335i
sounds like valve chatter... what kind of oil you running?
      03-06-2013, 09:54 PM   #5
mspired335i
42
Drives: 2021 M5
Bmw SAE-5w30(fully Synthetic). I just changed the oil 3 days ago but this noise has been there since 2 weeks now.
      03-06-2013, 10:16 PM   #6
SharkBait
14
Drives: 2010 E92 335i
Sounds too high pitched to be anything on the bottom end. Sounds more like an intake valve or a lifter. Did it start suddenly or build up gradually over time?
      03-06-2013, 10:17 PM   #7
BillionPa
BillionPa's Avatar
Drives: 335i
What happens is the oil 'burns' on a hot spot, and little tiny flakes come off over time, and get stuck in the valve lifters, making this noise.
It sounds like a single lifter to me.
On my old V8 a 50/50 mix of Redline 5W30 and M1 0W40 was able to clean most of it out over the course of about 15000 miles...
      03-06-2013, 10:42 PM   #8
mspired335i
42
Drives: 2021 M5
suddenly starting happening,atleast as loud as it is now. But I feel like it could have been there in the past but I haven't noticed it..
      03-06-2013, 10:44 PM   #9
mspired335i
42
Drives: 2021 M5
Solved. It was the air intake clamp
      03-07-2013, 12:34 AM   #10
BillionPa
BillionPa's Avatar
Drives: 335i
there is no way in hell I would put seafoam in the engine oil, it is literally rubbing alcohol and will only prevent the oil from lubricating anything
      03-07-2013, 01:29 AM   #11
BlueBimmer
Enthusiast
BlueBimmer's Avatar
45
Drives: 2009 335i Convertible
this doesn't sound normal at all - take it somewhere and have it diagnosed, does it run normal?
      03-07-2013, 08:20 AM   #12
mspired335i
42
Drives: 2021 M5
Truthfully speaking it does run normal, because I have to drive it everyday. It's just that noise is annoying. \
      03-07-2013, 09:21 AM   #13
BlueBimmer
Enthusiast
BlueBimmer's Avatar
45
Originally Posted by mspired335i View Post
Truthfully speaking it does run normal, because I have to drive it everyday. It's just that noise is terrible. Not that I beat on it but that few time I have gotten on it, it's pulled hard all the way to red line .
I am by no means an expert - but it sounds like its something loose, broke or going to break. Maybe it's just low oil or something stuck somewhere it shouldn't be.
Either way - if the sound wasn't there before and now it is - you should check it out, waiting will accomplish nothing.
      03-07-2013, 10:31 AM   #14
mspired335i
42
Drives: 2021 M5
Well I was hoping someone from the forum could help that has had the same issue before. But I guess it's a trip down to the dealer then. Thanks again.
      03-07-2013, 10:38 AM   #15
eric@helix
eric@helix's Avatar
210
Drives: 01 M Coupe, 08 135i, '12 328i
Yeah that sound is concerning enough that I would take it to a qualified technician. Better safe than sorry.
      03-07-2013, 11:31 AM   #16
SharkBait
14
If it's a lifter, it might not cause any problems right away but over time the journal will wear and ultimately the lifter will fail.
      03-07-2013, 01:21 PM   #17
mspired335i
42
Drives: 2021 M5
fixed
      03-07-2013, 07:28 PM   #18
BillionPa
BillionPa's Avatar
Drives: 335i
damn! for some reason I thought the noise was coming from the rear left corner of the engine bay (exhaust valve lifter problem is very common).
Did they determine the cause of the pump failure? I ask because I am in the process of replacing my PS fluid.. the stuff in there looks like the alien black oil from the x-files...
