Dixis BOV W/ Video
08-31-2007, 02:23 PM | #1 |
2164
Rep 5,623
Dixis BOV W/ Video
damn dixis is looking good. titanium full exhaust setup, c/f intake, and now a bov.
http://translate.google.com/translat...language_tools PS: anyone got dynos of the intake by dixis and what is the connection between dixis and gruppe m? is gruppe m just the name of the distributor in the US? |
08-31-2007, 02:25 PM | #2 |
22
Rep 617
I love literal translations:
At the time of accelerator off boost pressure inside the piping loses the destination because you can close the throttle, returns to the turbocharger and because the action which uses the brake occurs, burden falling on the turbine shaft, becomes cause of trouble. Of course, genuine being in 335, the small-sized blow off valve of the plastic make it is installed, but when it supercharges highly with SSC, it becomes complete capacity insufficient. In order to cancel that perfectly, it is the case that it means to replace the blow off valve to dixis. The dixis super blow off valve is not to make retard simply, with feeling good sound, is the case that it bears also the function which protects the turbine the atmosphere by opening |
08-31-2007, 02:26 PM | #4 | |
Modder Raider
755
Rep 8,633
Drives: M3
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
08-31-2007, 02:44 PM | #5 |
Perf BMW mag issue 147, 159
414
Rep 6,803
it'll affect the cars performance when the stock rubber diaphram bov's crack, leaks, and decide to take a shit on you... that seems to be the problem most of you guys on here dont understand. a good majority of you guys on here have procede, xede, turbo tuner or something that adds more boost so it will only be time till you guys realize it..
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
08-31-2007, 03:03 PM | #7 |
617
Rep 1,155
And you can go with piston style diverter valves instead, like the ones from Strat. I'm sure others will be out soon too, maybe from Forge or something. If the car came with DV's, it was for a reason. Just my thoughts.
08-31-2007, 03:07 PM | #8 | |
Modder Raider
755
Rep 8,633
Drives: M3
Forge has already developed the DV for our cars, and they should be coming out soon. http://www.e90post.com/forums/showthread.php?t=79750
08-31-2007, 03:19 PM | #10 | |
Modder Raider
755
Rep 8,633
Drives: M3
Forge's pictures are showing them being connected the same way.
08-31-2007, 03:24 PM | #11 |
2164
Rep 5,623
wow didn't even see that they have a oil cooler out. looks nice. but for oil cooler in think the dinan one would be better. direct fit and no problem. even dinan can't screw up a oil cooler lol.
and my bad about the gruppe m and dixis comment. didn't know why i even typed it in there. |
08-31-2007, 05:38 PM | #12 |
Boris the Blade
17
Rep 317
I didn't think there was one from Strat already? According to their website, it is still in development.
Allan
Montego Blue 335i Sedan w/Navi/Magnetic Black NISMO 350Z #831/76' Mini 1100 "SPECIAL" Export |
08-31-2007, 07:30 PM | #13 |
Rep 301
I love the whole "BMW saw fit to put it there so don't mess with it" argument. Well BMW also saw fit to put 4 cats, low boost, a flap valve on the drivers muffler, incandescent bulbs, etc... How many people have chopped out or changed these?
"Hello Mr. Kettle my name is Mr. Pot, my aren't you dark." |
08-31-2007, 07:55 PM | #14 | |
617
Rep 1,155
The DV's I'm talking about are not same as what BMW put on the car. The dv's are aluminum piston style. They are tougher, quicker, can handle more boost and still recirculate the air as the 335 was setup to do. The stick dv's are plastic diaphragm style and are prone to tearing in other applications especially under increased boost. I assume bmw and other manufacturers choose these over piston style since they are cheaper and require less maintenance. Bov's on the otherhand vent the air. In other applications where people have replaced dv's with bovs, some have run into lean conditions. I don't know if this has been tested on the 335. They make noise,. Not sure of any other benefit. btw, I have no idea what you are referring to with the kettle comment. |
09-01-2007, 09:06 PM | #16 |
Rep 45
I trip out on how everyone makes such a big deal over this BOV vs DV (non)issue! They both benefit the person who has increased their engines performance over stock and needs the extra strength. Neither is ricey if your car has the performance to back it up, whether its a turbo Integra or a Saleen S7 Twin Turbo.
Since either route will work with a 335i, the bottom line is this: If you like it quiet get a DV. If you like it loud get a BOV. Either way is the right way if it makes you happy!
soon: 07 335i
05 Mazda RX8 (F/S) 05 Harley Davidson F250 (gf's ride!) 89 Nissan 240sx (sr20det) -sold 03 Ninja ZX6R 636 |
09-04-2007, 11:59 PM | #19 |
294
Rep 2,414
Drives: E92 335i
Nice found
09-05-2007, 10:04 AM | #21 |
Moderator
133
Rep 6,775
Drives: TiAg E92 335
You can tell that they are a JDM tuner from the color schemes that they choose. The BOV/vac lines make the engine bay look like the 335 that superman would drive. I'm allowed to say this since I had blue vac lines all over the place on my s2k.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
09-20-2007, 07:40 PM | #22 | |
2164
Rep 5,623
anyone know a site where one can order the gruppe m intake? |
