Coding problem?
03-02-2013, 12:23 PM | #1 |
Rep 37
Coding problem?
So I put in LED angel eyes, but I had to take off the canceler on one of them because it was fried I believe and didnt work. So i put them both in and they worked (worked before i started the car). Then i started the car and that one that doesnt have the canceler doesnt work now, and its showing that the bulb is out. The light does work, im wondering if that can be coded so the car recognizes the LED as working and then it would actually work?!?
What do you think! thank you |
03-02-2013, 02:55 PM | #2 |
441
Rep 18,331
Since you took out the resistors the light will now throw a bulb error...You can code out that bulb error by taking out the warm and cold checks...Dont let that error occur too long as after the light module counts the error about 50 times it will have a short circuit protection and shut that outlet out and then you are in trouble...Resetting the module is not all that easy..
03-02-2013, 08:28 PM | #4 |
Rep 37
Or will unplugging the battery reset the counts back to 0?
I am having this guy do my coding http://www.facebook.com/home.php#!/Tripl3OCoding |
03-02-2013, 08:38 PM | #5 | |
441
Rep 18,331
