03-01-2013, 05:17 PM | #1 |
77
Rep 664
Drives: 2013 BMW 335i
Code to turn off Reverse Light Error Check for LED use
How do i code it so that my car doesn't check for error in the reverse lights? I put in error free LED reverse light but it flickers when i turn on car and randomly while driving.
Another member told me its the car constantly checking bulbs so it flicks when it check. Said it's possible to code it so it doesn't check. Is there an option to just code the reverse check only or if code the check off then its for all lights in car? |
03-03-2013, 01:07 PM | #2 |
77
Rep 664
bump
03-07-2013, 12:04 AM | #3 |
Rep 227
Me and awhk were playing around with this in coding, try reading his post here:
http://www.f30post.com/forums/showth...0&post13208390 basically, there are a few settings for each bulb... cold check, warm check, and IS_LED. you want to set the checks off for whichever bulb you are changing to LED, and also set IS_LED to 'aktiv'... let me know if that works for you. BTW the chart says REF_01 module but mine was in the REM_01 module. |
03-07-2013, 06:01 PM | #4 | |
77
Rep 664
THanks. |
03-25-2013, 01:02 AM | #5 | |
77
Rep 664
http://www.f30post.com/forums/member.php?u=65772 or you can go email also. size is p21 |
03-26-2013, 12:19 PM | #7 |
77
Rep 664
03-31-2013, 10:57 PM | #8 | |
77
Rep 664
06-06-2013, 10:55 AM | #9 | |
Rep 2
Just a quick question. Can you explain what IS_LED does? It's Not-Active as default and you mention that it needs to be changed to Active. Is this function for LED light for future F30 LCI model? |
06-07-2013, 12:33 AM | #10 | ||
BimmerPost Supporting Vendor
171
Rep 1,397
if you are using cree leds though do not set is led to active as it wont provide enough power thats from my experience I could be wrong |
06-07-2013, 12:35 AM | #11 | |
171
Rep 1,397
unscrew it and pull that piece out you will see 2 hex bolts that hold your tail lights onto the car. unscrew those and gently pull the tailight out unplug everything and your good to do w.e you want to do |
11-05-2013, 07:36 PM | #12 | |
158
Rep 1,136
would love to have you code few things on my f30 if you're up for it..
sent from bimmerpost Android app
11-05-2013, 07:37 PM | #13 |
158
Rep 1,136
hey Ant, do you still do coding?
11-23-2013, 10:24 AM | #14 |
77
Rep 664
