Diagnose my problem! 335i
02-26-2013, 04:41 PM | #1 |
12
Rep 167
Ok so I'm driving a 2008 335i and I'm getting a bit of a rattling noise from a cold start in the morning.
Hear is a link to a sound similar to what mine is making.... So is it a valve problem? |
02-26-2013, 04:50 PM | #3 |
30
Rep 644
Are you really in Ireland? What is the road tax on that beast. Check out this link. It is your problem.
http://www.e90post.com/forums/showthread.php?t=13504 |
02-26-2013, 04:51 PM | #4 |
15
Rep 88
You shouldnt have modded it! lol jk.
Myn does that too intermitently. I had BMW and my indy shop guy look into it, and they said that BMW had a hydrolic lifter problem that was updated. Apparently, myn has the updated lifters and it still ticked sometimes, rarely Im guessing because of the way BMW has their variable valve timing setup with the VANOS solonoids, and use oil pressure to regulate, it could just be off a bit. A quick rev will help stabilize it. Check your oil levels, and oil pressure. My was ticking when my oil levels were low, and I had a massive oil leak in a failed turbo causing a loss in oil pressure. But that was fixed and I havent heard a tick since...
09' 335i Sedan
02-26-2013, 07:03 PM | #5 |
79
Rep 2,110
sounds like the hydraulic lifters to me, it sounds way worse than it actually is. My n52 does this, not as loud, on cold starts now and again. once everything worms up it should stop. I believe it due to a lack of oil/oil pressure in the hydraulic lifter.
02-27-2013, 04:47 AM | #6 |
12
Rep 167
Here's a video of mine:
I think it's an hydraulic valve lifter as well. When the problem started I quick rev of the engine used to sort the problem out. However, revving the engine isn't as successful any more. Is it a big job to replace the hydraulic valve lifter? Is replacing the lifters a successful fix? Also is the thread linked above not specifically for NA cars? |
02-27-2013, 04:48 AM | #7 | |
12
Rep 167
02-27-2013, 04:48 AM | #8 | |
12
Rep 167
It's annoying as hell to hear it though! |
02-27-2013, 04:50 AM | #9 | |
12
Rep 167
02-27-2013, 11:00 AM | #10 | |
30
Rep 644
02-27-2013, 12:53 PM | #12 |
14
Rep 308
I just picked up a 2010 335i E92 (PPK stage 2, PE exhaust, all the trimmings) with 28K on the odo and it makes this noise too on cold start. I've also noticed it on one occasion when fully warmed up after a few hours of highway driving. Also at idle. Blipping the throttle cleaned it right up and it didn't come back.
It passed its PPI, has a pretty clean service history (HPFP recall only) and pulls well so I doubt anything is malfunctioning but whatever it is, it is loud and will wear down over time. That said, this is my first N54 and my first DI motor so I don't know what's normal. The cold start noises it makes are disconcerting. Debating whether or not to take it in. Seems at least a few people have had this problem for a while with little ill effect. From my research it's either lifter noise, injector noise, or WG rattle (it's more of a consistent 2x per sec tick for me so not sure about this one). |
02-27-2013, 01:42 PM | #13 | |
12
Rep 167
It's really starting to piss me off. I'm considering switching it at the moment. |
