BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DEFIV Differential Lock-Down DIY
      02-19-2013, 08:57 PM   #1
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Note: Not responsible for any damage to you or your car,
this worked on my car so will work on yours. Thi kit as been tested over and over countless hours by
Rick@DEFIV. If it doesnt fit you did something wrong.
***This tutorial assumes you know how to get your car secured on jack
stands, if in doubt do NOT attempt this DIY!
Suggestions:
Do NOT use a torch to remove bushings, it is not needed and can deform subframe amd make install of bushing
appear off...they are with in .001" tolerance. They fit PERFECTLY.
Notes:
*I assume you know how to take exhaust, panels ect off.
**The design off this product is the copyrighted by Rick@DEFIV.
***You can use a hole saw to pull out bushings instead of pipe if needed.
Here is the work of art, this kit really impressed me with how close everything fit....I can't imagine the testing
involved to get this to spec. Rick Has some of the best customer service in this bussiness period!
[/B]Removal of differential (I had mine out for wavetrac so I took as many pics as I could):[/B]
Removal of "Front" (smaller)bushings:
Removal of "Rear" (larger) bushing
Installing bushings
Installing Diffetrential/half shafts and driveshaft back in car, some steps are left out since it is basically
reverse order:
Note on driveshaft installation: Tighten in order below!
A. Insert nut
B. Guibo
C. Center support bearing
4th link bushing installation:
I hope this is of help to you guys!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      02-28-2013, 09:55 PM   #2
Rotary Rasp
Rotary Rasp's Avatar
241
Drives: 2009 E92 335i 6MT
Excellent write up!
      02-28-2013, 09:57 PM   #3
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Originally Posted by Rotary Rasp View Post
Excellent write up!
Thank you!!
      03-20-2013, 08:45 PM   #4
Sniz
Sniz's Avatar
654
Drives: e92 335 - gone // e36 M3 turbo
damn thorough well done
      03-20-2013, 08:47 PM   #5
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
thanks man!
      03-24-2013, 12:04 AM   #6
SneakyDeeky
driver mod in progress
SneakyDeeky's Avatar
225
Drives: with both feet
2015 VW Golf R  [5.50]
2014 Audi SQ5  [10.00]
Legit write-up! Thanks for taking the time to educate the rest of us.
      03-24-2013, 01:12 AM   #7
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
thanks man!
      03-24-2013, 04:06 PM   #8
mrbillytalent
17
Drives: '99 e46 323i & '07 e90 335i
Be careful with the part number for the Guibo bolt's nuts. He lists a 'kt' at the end however the parts number did not pull up for me. Just remove the 'kt' and it will give you what you need.
Thanks for the thorough write up
      03-24-2013, 04:25 PM   #9
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
weird, I read them right off the pkg.
      05-01-2014, 04:37 PM   #10
uniter
Black on Black on Black.
38
Drives: 335i/6mt Sport,Nav,Prem.
These are 10% off if you email them.
LEMANS BLUE M-TECH E92->PROCEDE REV3::BIEHNTUNE FLASH::ETS 7" FMIC::RACELAND DPS::OS GIKEN 1.5 WAY::DEFIV DIFF LOCKDOWN::DEFIV OCC::DEFIV INTAKE::RB PCV
      06-15-2014, 10:30 PM   #11
techmaster05
23
Drives: E90 335i
im sorry to revive this but what exactly is this??? is it like having an lsd?? or does it only take away wheel hop???
What's the difference between a stock FBO 335 and an upgraded Single Turbo 335?
Nothing! They both run 11's LMAO
      06-19-2014, 09:00 AM   #12
sprygsxr
sprygsxr's Avatar
36
Drives: <LCI E90 SGM 335xi FBO
Its for wheels hop
http://www.defivfabrication.com/n54.html
      08-18-2014, 04:36 PM   #13
gzim335
gzim335's Avatar
148
Drives: e92 m3
2007/1 e90 335i  [2.00]
Bumping thread
Do you suggest subframe bushings n rear sway bar along with LSD install?
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth
kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery
