long crank, ran crappy, restart, ran fine???
02-18-2013, 05:13 PM | #1 |
226
Rep 1,064
Went to the mountains for a spirited drive Sunday and thought I was not going to make it.
20 something degrees outside, initial crank was a bit extended, not much, but the car was idling badly and was vibrating more than usual. I drove it for a bit thinking temp was the issue. It ran terrible, upon accelerating it would vibrate as if a cylinder was not firing. I have read all about fuel pumps and how long cranks are a sign of failure, but my car restarted quickly and ran perfectly after I stopped. As I understand the long cranks would continue if it were the fuel pump, correct? I then enjoyed a day in the mountains flogging my car through the turns and have not seen the issue pop back up again. I am going in for service in about 300 miles for oil, headlight washer covers, battery cable, and possibly brakes. Any ideas of what it was or if they can prevent a future occurrence of this? thanks, mxa |
02-18-2013, 09:57 PM | #2 |
45
Rep 1,754
What you saw can be, not necessarily must be, an early warning of a failing HPFP. When our's started to go, at first we only got occasional long cranks, then after a while, it would do it every time the car sat overnight. Then I got a really long one, car finally started and ran fine. Took it in at that point and it had been throwing codes for a while, according to the dealer.
02-20-2013, 12:59 PM | #3 | |
226
Rep 1,064
02-20-2013, 01:15 PM | #4 |
79
Rep 2,110
sounds like HPFP to me, they don't normally go out all at once sometimes they show some shines that seems pretty similar to yours.
Could also be your plugs |
