Help with $676 hifi coding Please !!
02-11-2013, 04:01 PM | #1 |
20
Rep 183
Hi all,
Got stuck with my problem for a day now. I manage to get my new base stereo upgrade to work : subs+speakers+amp All is working really fine. Buy I'm trying to code the famous $676 option to get my HU run as HIFI. I successfully manage to code the new VO into CAS and NFRM (not FRM as I have NFRM). But I have NO changes at all :$ What am I doing wrong? In NCSExpert tool I choose FA_WRITE as I don't have FW_WRITE. Do I have to something else? Should I hard reset the HU to get the new setup apply? I made the changes a day ago, but no changes. Thanks guys !! |
02-11-2013, 05:10 PM | #2 |
1911
Rep 13,104
Take a look in the 2urad file.
There should be line about which kind of stereo your car thinks it has. I don't know if just changing the VO will change this or not. This what mine looks like with Hi Fi , Bluetooth and SOS. Its and 06 and I have never changed it. CODIERUNG_ERFOLGT codierung_erfolgt CDC nicht_aktiv AUDIO_SYSTEM pl2_hifi pl3_hifi SDARS nicht_aktiv PDC nicht_aktiv ACC nicht_aktiv STANDHEIZUNG nicht_aktiv AUX_RAD aux BAUREIHEX e9x COUNTRYCODE_RADIO us IBOC nicht_aktiv KEY_MEMORY_R aktiv MUTE_TIMES pl2 NACHLAUF_INT_R pl2 RIGHTHAND nicht_aktiv SOFTEN_ENTERTAINMENT_PDC nicht_aktiv TCU_ECE nicht_aktiv TIMEOUT_INT_R pl2 ULF_ECE nicht_aktiv BMW_AKD nicht_aktiv BMW_HOME_DEALER aktiv BMW_INITIALIZE aktiv BMW_MOBILE_SERVICE aktiv BMW_PHONE_SERVICES nicht_aktiv BMW_ROAMING nicht_aktiv BMW_TELESERVICE_ONLY nicht_aktiv RING_STATUS aktiv BLUETOOTH_RAD2 aktiv DISPLAY_LOGIC7 nicht_aktiv HI_TEMP_VOL_CTRL pl2_hifi pl3_hifi SMS_RAD2 nicht_aktiv PHONE_BUSINESS_R2 nicht_aktiv SVS_LOW_RAD2 aktiv BMW_ASSIST_RAD2 aktiv BMW_HOTLINE_RAD2 aktiv DAB nicht_aktiv CAR_COMP_ACTIVE aktiv TCU_JAP nicht_aktiv CONTACT_NR_DEALER aktiv CONTACT_NR_HOTLINE aktiv CONTACT_NR_MOBILE_SRVC aktiv ABS_VOL_GONG e91_hifi CROSSOVER pl2_hifi e90_hifi r56_stereo r56_hifi DELTA_GONG_ENT wert_0 DELTA_PDC_ENT wert_0 RATIO_AUDIO_SOURCES ece us VEHICLE_FILTERS e81_stereo e82_stereo e87_stereo e88_stereo e90_stereo e91_stereo e92_stereo e93_stereo pl2_hifi r56_hifi VOL_TEL_MAX stereo_mulf_e87 hifi_mulf_e87 top_hifi_mulf_e87 stereo_mulf_e90 hifi_mulf_e90 top_hifi_mulf_e90 stereo_mulf_e91 hifi_mulf_e91 top_hifi_mulf_e91 stereo_tcu hifi_tcu top_hifi_tcu VOL_TEL_MIN wert_0 VOLUME_TABLE e91_hifi MY_INFO_RAD2 nicht_aktiv V_INFO_RAD2 nicht_aktiv PHONE_PROF_RAD2 aktiv I heard some of the years weren't capable of being reprogrammed but I don't know which ones and the 2urad file is the 2rad file in Europe. The above file is for an pro radio not a idrive. Last edited by ctuna; 03-16-2013 at 11:28 AM.. |
preppyr67.00 |
02-11-2013, 05:46 PM | #4 |
20
Rep 183
So here some parts of my FSW_PSW.TRC
EQUALIZER nicht_aktiv AUDIO_SYSTEM pl2_hifi VOLUME_ADJ_1 e93_hifi VOLUME_ADJ_2 e93_hifi VOLUME_ADJ_3 e93_hifi VOLUME_ADJ_4 e93_hifi FILTER_FZG_BLOCK_1 e93_hifi FILTER_FZG_BLOCK_2 e93_hifi FILTER_FZG_BLOCK_3 e93_hifi FILTER_FZG_BLOCK_4 e93_hifi PHASE_BLOCK e93_hifi CROSS_OVER_1 e93_hifi CROSS_OVER_2 e93_hifi OUTPUT_GAIN_SYSTEM e93_hifi NIVI nicht_aktiv VOLUME_MAXIMUM_TEL e90_hifi VOLUME_MAXIMUM_ON standard VOLUME_AUDIO_1 e93_hifi VOLUME_MINIMUM_NAVI e93_hifi VOLUME_DELTA_NAVI_ENTER standard VOLUME_MINIMUM_TM e93_hifi VOLUME_MINIMUM_TEL e93_hifi VOLUME_DELTA_TEL_ENTER standard VOLUME_KLANG_1 e93_hifi KLANG_OFFSET e93_hifi VOLUME_PDC e93_hifi VOLUME_DELTA_PDC_ENTER e87_hifi VOLUME_SECUR_1 e87 LOUDNESS e60 GAL_MAIN e60 GAL_DEFAULT e60 MUTE_ON_CRASH nicht_aktiv VOLUME_MINIMUM_SPEECH e93_hifi |
02-11-2013, 05:50 PM | #5 |
20
Rep 183
SOUNDAUSSTATTUNG
hifi VOLUME_ADJ pl2_hifi BEEP_CONTROL_CG1 e93_hifi BEEP_CONTROL_CG2 e93_hifi BEEP_CONTROL_CGL e93_hifi BEEP_CONTROL_PDC e93_hifi DEF_GONG_VOLUME e92_hifi DEF_JPGONG_VOL e92_hifi DEF_PDC_VOLUME e92_hifi this one is the trace file of my NFRM ... Last edited by laurentProd; 02-11-2013 at 05:51 PM.. Reason: edit |
02-11-2013, 05:52 PM | #6 |
1911
Rep 13,104
You should do a readout on the 2rad file only
That will give you all the parameters for the radio only. you notice on mine it says high fi system not to far down. AUDIO_SYSTEM pl2_hifi pl3_hifi Are you sure it didn't take ? There is a hidden menu that I don't know how to access that shows what level the radio is at. You hold some the menu button or some combinations of the menu buttons for a ceratain amount of time then it comes up and tells you the parameters the radio is set for. Last edited by ctuna; 02-11-2013 at 05:58 PM.. |
02-11-2013, 06:02 PM | #7 |
20
Rep 183
huu, yep but I'm not next to my car right now...
and it's already 1 am in France I have this : AUDIO_SYSTEM pl2_hifi does it mean the settings were apply successfully? I didn't notice any drop in sound volume but could be normal... |
02-11-2013, 06:09 PM | #8 | |
20
Rep 183
And I have I-Drive |
02-11-2013, 06:34 PM | #10 |
Rep 62
for the impatient:
Main Menu Press and Hold Controller for 8-10 Sec then release Turn Controller Right 3 clicks Turn Controller Left 3 clicks Turn Controller Right 1 click Turn Controller Left 1 click Turn Controller Right 1 click Press Controller |
02-12-2013, 05:59 PM | #12 |
1911
Rep 13,104
This might help
This might help
http://www.e90post.com/forums/showthread.php?t=660738 In step three after changing the VO he codes the radio. http://www.e90post.com/forums/attach...2&d=1260829447 page 25 in the above document. Last edited by ctuna; 02-12-2013 at 06:05 PM.. |
02-14-2013, 02:30 PM | #13 |
Rep 13
Hi
First add $676 to VO, then FA_write in FRM and CAS. Then, using NCS, with the profile "expert", code the following modules : CHOST CAPPL CGATE CAUDI CTUNE to code, you just have to make an "SG_CODIEREN" on the modules, with expert profile. NO BLANK .MAN FILE ! No need to read the modules first, just code... Then stop the car, wait for a few minutes (useless ?) and enjoy for Hifi ! If you just add an amp for front speaker and sub, the the PDC sounf from the rear will become low, but just enough. |
03-14-2013, 03:01 PM | #17 |
Rep 15
Help with coding professional hu from base to hifi
Hello Everybody,
I am trying to code my stereo to hifi, took a look at numerous guide but want to work with a step by step guide for this that isnt as clear online for this exact job. If anyone could please input their knowledge on the step by step Ill put as it will be missing alot and then once I've got a step by step I will take screen shots for when I do it and host and link. Thanks in advance. Plug in cable to OBD port and selected usb port Run NCSexpert Click "file" and select "load profile" and select "expertmode" Click "VIN/ZCS/FA Click "ZCS/FA f. ECU Select chassis type "e89" On choose ECU select "CAS" After your vin is shown select "enter FA" Select chassis type "e89" Ensure VIN shown is correct and select "OK" Enter $676 and then select "add" Then scroll down and select "£676" and select "OK" Then select "Back button" Then select "F4 Process ECU" Then select from drop down list "CAS" Then select "F2 Change Job" Then select "FA_WRITE" and click "OK" Ensure CAS is shown on "Get Coded" and FA_WRITE shown on "JOB NAME" Select "F3 Execute Job" Thanks again for any help with this guys - its so interesting to learn something new but also scary Last edited by bear85; 03-14-2013 at 03:13 PM.. |
03-14-2013, 04:08 PM | #18 | |
33
Rep 322
Add Ons: Charcoal Filter Delete, K&N Drop-in, Air Scoops, HID Angel Eyes, Splitters, M3 Lip Spoiler, Gloss Black Kidney Grills, Blackvue DR500-GW, M-Tech rear, BMW Performance Exhaust, M3 control arms, Bilstein HD
03-15-2013, 05:47 PM | #20 |
20
Rep 183
-> $676 this step is to ensure the vehicle option (VO) has correctly been applied. The procedure need to be apply on both CAS and FRM modules ! Once done, don't forget to "SG_CODIEREN" on the modules CHOST CAPPL CGATE CAUDI CTUNE You need to wait yhe car to go into sleep mode before settings to take effect. (10 min I guess, go drink a beer, you deserve it!) You're good to go ! Last edited by laurentProd; 03-15-2013 at 05:52 PM.. |
03-15-2013, 07:38 PM | #21 |
Rep 15
Hello, really appreciate you taking the time to post. When this has been done to cas and then frm modules you then "sg_codieren" the CHOST/CAPPL/CGATE/CAUDI/CTUNE. Ccould you post a quick step by step so I can get it right first time. sorry to seem dumb but I always to be sure before I tinker John.
