BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: 328i 3-stage intake manifold conversion
      02-07-2013, 08:51 PM   #1
BradZditosky
BradZditosky's Avatar
49
Drives: '15 435i xDrive Gran Coupe
The three stage conversion was not very difficult, you just need the right tools. I recommend that you have torx bits. All in all the conversion, including installing the new afe intake and doing the aa tune, it took me about 6 to 7 hours. Just be patient and take you time, you dont want to mess anything up.
obviously the intake and the tune are not needed to do the conversion, but to take full advantage of the new intake with the disa's you will need a tune.
here is a list of parts you will need. Search around for everything, you should be able to get everything for around 300-350.
11617559523 Intake Manifold
11617579114 Adjustor Unit
11617560538 Adjustor Unit 2
11617547242 Gasket set
11617535850 x2 Screw 50x35
11617535849 x4 Screw 50x20
11617535851 x1 Screw 50x66
some other lists say you need 5 of the 50X20 screws so thats what i had bought but i only used 4, i could not find anywhere that the 5th screw would go so i have an extra one now lol
These are the two wires that will plug into the DISA Adjusters on the new intake manifold. The longer one of the two is that one that will wrap around the manifold and plug into the adjuster facing the engine block.
First things first you need to remove the Air Box
and take the two nuts off to looses the power steering fluid reservoir.
Once you get the air box out, move the steering fluid reservoir over to the side and it should look somewhat like this.
Now remove all of the plastic pieces from around the engine. Just be careful not to break any of the plastic clips, everything came off pretty easily and was pretty self explanatory.
The engine bay should look somewhat like this now.
Now i didnt get any pictures of it because i got so caught up in working that i kind of forgot, but you need to remove the throttle body from the manifold, there are 4 10mm bolts holding it on. also remove the vacuum hose that is right behing the throttle body on the air intake manifold. Just squeeze the connection and it pulls right out.
Now you need to disconnect a few wire before you take off the manifold.
Once you get those disconnected, just go around the manifold and look for any wires that many still be attached.
Now you can take off the bolts and nuts that are holding the manifold onto the engine. lift up on the manifold so you can reach behind and disconnect the two hoses and one wire that you will see. Also there is a bracket that is connect to the manifold, under where the throttle body was, you need to use a torx bit to remove the two screws that are holding it to the manifold. Once you are sure that you have everything disconnected from the manifold you can slowly pull it out making sure you did not forget to disconnect anything.
Now that you have out the manifold, move any brackets that may still be attached to it, to the new manifold. Also be sure to put the new gaskets one the new manifold and screw in the DISA Adjusters.
Old manifold.
New Manifold.
Old Vs. New
Now just revers all the steps and be sure to plug in the DISA Adjusters, double check that you are plugging everything back in.
Once you are done it should look like this
Let me know if anyone has any questions and i will try to answer it.
Stock For Now
otitxn6.00
      02-08-2013, 12:13 AM   #2
blingman
40
Drives: 3er
Awesome job! How you liking it?
      02-08-2013, 08:30 AM   #3
BradZditosky
49
i really like it, you can definitely tell there is more power there.
Stock For Now
      02-08-2013, 08:33 AM   #4
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
awesome write up! thanks for taking the time.
      02-23-2013, 08:35 PM   #5
OrangeInOhio
OrangeInOhio's Avatar
Drives: 2008 328i
Dude, awesome write up. I've thought about doing this to my 328i but I might wait until my CPO is over. Don't want to void that. Have you had it on a Dyno since doing this?
      02-24-2013, 12:29 PM   #6
BradZditosky
49
Thanks! but no i have not, but i can definitely tell there is more power there then before.
Stock For Now
      02-24-2013, 09:36 PM   #7
andrey_gta
andrey_gta's Avatar
298
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Great Post. best mod for the n52 hands down.
I would stress that before you go on pulling out the manifold, make sure you undo what is connected to it on the bottom, It is a cable loom box attached with torx 35 or 37 bolts. It was my most challenging struggle, followed by the gentle removing of air/oil catch hoses.
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      03-11-2013, 02:54 PM   #8
intensee92
intensee92's Avatar
55
Drives: Your Girl Crazy.
thanks for the diy!
http://www.e90post.com/forums/image.php?u=101661&type=sigpic&dateline=1350502789
      03-26-2013, 01:28 AM   #9
Anthonyv335is
Anthonyv335is's Avatar
13
Drives: bmw 335is and M5
great diy so is this what turns the 230hp to the exact 255? or around there
      03-26-2013, 09:06 PM   #10
BradZditosky
49
you need to get a tune to get the full effects of this mod and depending on what other mods you have, you could possibly get an extra 50hp at the crank based on the research i have done. but with the mod alone and a tune you should be getting an extra 30-35hp at the crank, so yes around the 255hp like the 330 has.
Stock For Now
      03-26-2013, 10:11 PM   #11
Anthonyv335is
13
cool wish they would have continued with 330i for the newer models after 06 would be great in e92 seems like its a little of everything power mpg reliability
      04-02-2013, 11:52 AM   #12
E90X
Drives: 2014 328i M Sport Wagon
You mentioned you recommended having torx bits. What sizes did you use and what portions of the install required them?
Thanks!
      04-02-2013, 05:16 PM   #13
BradZditosky
49
i believe it was t27 that i used mostly and it was quite a bit that i used it, but there were a few others i would get a torx bit set and a torx socket set. just incase you run into anything you are prepared
Stock For Now
      04-05-2013, 06:39 PM   #14
OrangeInOhio
Drives: 2008 328i
I forgot to ask you in my original post... what tune did you get? AA Stage 2?
2008 328i | BMW PE | 3 Stage Intake IM | OFT Stage 1 Tune | K&N Drop-in
      04-05-2013, 08:53 PM   #15
BradZditosky
49
You are correct, the AA Stage 2.
Stock For Now
      04-05-2013, 09:10 PM   #16
Clammy
322
Drives: 2006 330i 6MT
Sweet! I'm getting the AA Stage 2 Tune next week, and will do the IM swap late spring/early summer. Looking forward to the power gains!
BTW, did you do the charcoal filter delete as well?
Cheers!
      04-05-2013, 09:21 PM   #17
BradZditosky
49
Cheers!
nice man! im sure you will enjoy it as much as i do! but no i got a aFe Stage 2 Seal Intake.
Stock For Now
      04-05-2013, 09:25 PM   #18
Clammy
322
I know it!! Heheh... I'm planning on keeping the stock airbox, and doing the charcoal filter delete.
Cheers!
      04-05-2013, 09:38 PM   #19
BradZditosky
49
Cheers!
Very nice!
Stock For Now
      05-05-2013, 02:01 AM   #20
saeng
11
Drives: e90
Do it have to be aa tune?? Will this mod work with bms powerboxs??
      05-05-2013, 12:29 PM   #21
optimaxed
39
Drives: M340i
AA have probably most experience at tuning these conversions, powerbox doesn't retune the ECU for new manifold I believe
      05-16-2013, 12:55 AM   #22
ObiChen
ObiChen's Avatar
82
Drives: 11'E90 / 18'F82
2018 BMW F82 M4  [0.00]
Pics are dead, OP can you edit the thread to show the pics? PLEASE!!!
