Windows won't roll down after coding digital speedo
02-03-2013, 03:23 PM | #1 |
Rep 154
Drives: 2007 328i Coupe
Hey guys, I've searched but can't find much except update daten. I've only been coding for about 24 hours so still pretty new. Today I coded the digital speedometer and turned off the door gong without any problems. However, now my windows don't roll up or down when I open and close my door (e92). This is beginning to be a problem as you can imagine, as I have to roll down my window with my FOB before I get in every time. Then I just gently tuck the glass under when I shut the door. Anyone else experience this and know how to fix?
Thanks, Last edited by gdgraham; 02-03-2013 at 04:37 PM.. |
02-04-2013, 07:29 PM | #2 |
Rep 154
Anyone? I've successfully coded out multiple bulb checks, windows up with fob, folding mirrors with fob, disable door gong, front and rear fog lights as welcome lights, and digital speedometer. All without any errors or hiccups. However, windows still don't roll up or down when getting in and out. Fortunately I can use the fob now but I really need this feature back. Any ideas at all? Suggestions?
02-04-2013, 07:57 PM | #3 |
441
Rep 18,331
Make sure you Start the car. CLose the door...Press the window switch down until it rolls down all the way and hold it pressed down for 10 seconds. Then roll up the window until its all the way up and then hold it for ten seconds. Do this to both sides of the windows but one window at a time...See if it works. Basically your resetting the windows.
02-05-2013, 08:04 AM | #5 |
Rep 154
No this didn't work me but it did reset my windows. My dash light came up with each window and there was a ding sound. They both work correctly, just not when I open or close the doors.
02-05-2013, 01:28 PM | #8 |
Rep 154
I cycled the car on and off and tried holding the window switch again with still no luck. I will try resetting KOMBI and NFRM to defaults tonight when I get off work. I appreciate the help guys, I'll keep you posted.
02-06-2013, 11:37 PM | #9 |
Rep 154
I tried resetting the modules tonight but it still won't work. I'm pretty sure I did it correctly but I'm not positive because it didn't appear to reset anything besides my trip and my clock. Everything else I had coded remained. There isn't anyone local that I can take it to besides the dealership and it will be pretty clear to them what I had done. I'm afraid if I have the dealership fix it and then I code it again I'll be right back in the same boat. Think they can/will fix it without changing everything else I have coded?
02-06-2013, 11:41 PM | #10 |
///M at Heart
90
Rep 1,954
Does your check control say anything about the windows?
Mine were glitchy for a second when I turned on my HIDs at the same time I opened the windows. Just after I had coded out my bulb checks. |
02-07-2013, 12:07 AM | #11 |
Rep 154
No, control check is ok. I've done some more research and it sounds like it's happened to other people after using ncsexpert, but I haven't found any threads where they actually found a solution yet. One guy said he fixed his by locking the door with the fob, then pressing unlock 3 times quickly and that's all it took to fix it. Seems too easy but I'll give it a shot tomorrow.
02-07-2013, 04:48 PM | #12 |
Rep 154
Three quick unlocks did not work either...
02-09-2013, 08:37 PM | #14 |
Rep 154
I was able to code everything back to default in expertmode using sgcodieren, not sgreset. When I did this I obviously lost everything I had coded, but my windows did work correctly again so that's a plus. After this, I loaded my fswpsw.man profile and all my codes worked again but my windows did not. I suppose this means it's something in my .man file I've done that the car does not agree with (still no errors). Frustrating.
02-10-2013, 08:12 AM | #15 | |
441
Rep 18,331
02-10-2013, 09:04 AM | #16 |
Rep 154
Yeah, definitely doing something wrong because I don't edit my trc file, I edit my man file every time... I thought because everything was working and I had no errors that I was doing it correctly, apparently that is not the case.
02-12-2013, 09:29 PM | #17 |
Rep 154
I finally coded everything back to defaults correctly, and then recoded all the features I wanted. Everything is working properly now but I still don’t have any idea what went wrong. Looks like I was being lazy and taking shortcuts when I was coding and I wasn't doing it right, even though it did work and never had any errors. The point is, if it seems really easy and a quick process, then you probably aren't doing it right or safely. Make backups and if you follow tutorials, follow them to the “T”, no exceptions. There are very knowledgeable people on this forum and it’s unlikely a first time coder found a better way to do things.
02-12-2013, 09:43 PM | #18 |
441
Rep 18,331
Just because you have read one person or read a couple of threads from somewhat novice coder about errors, shouldn't shy you away from having your car coded for these convience items that makes the car so much better...Dont be afraid.
