08-23-2007, 08:11 AM | #1 |
97
Rep 1,191
Steering Wheel Removal
before you begin, make sure you have a valid reason to do this...and only reason would be to install an M steering wheel also unplug the battery for a good amount of time. I left it for 5 minutes, others may do it for 30.
oh yea and don't sue me if you screw up. i'm not responsible for your mistake! *it is possible for you to install any 3 series airbag/steering wheel combo if you like. Also the X series I believe fits as well* moving on... 1)find the little holes by 10 and 2 o' clock position behind the steering wheel it self 2)Insert small and long screw driver into the hole. and you have to push the bar towards the center. it's really hard to find(was for me at least) 3)Airbag will "pop" out and hang..it's okay don't freak out. and start to unplug the wires. when unplugging the wires from the airbag, use a very small flat head for the connector...you wont be able to use your hands for that more than likely. Also if you have those black connectors in the steering column, it means you may add steering wheel controls(if i remember correctly) 4)take off the center nut which is pictured above, and steering wheel should come straight out. Make sure when you are RE installing, line up the notches on the wheel and the column. |
08-23-2007, 10:13 AM | #2 |
Rep 92
I'm so jealous. Great write up. Did you find a good deal on the wheel? How much does it boost your enjoyment level of driving? I want one so bad, but i can't justify spending $900.
09-01-2007, 05:37 PM | #5 |
Rep 62
Drives: 2004 Z4 3.0, 2003 VFE 530
I've seen his istall in person and it is SWWEEETTTTT!!!!
09-04-2007, 08:02 PM | #6 |
97
Rep 1,191
i dunno u might disable the airbag, blow the airbag, or both lol don't want to find out!
2022 GLE 53 Coupe
09-05-2007, 07:16 PM | #7 |
61
Rep 1,379
Drives: E89 Z4 sDrive28i M Performance
what is wrong with the new wheel? It looks like it has a couple of defective dents in the top center of the wheel.
09-06-2007, 06:46 AM | #8 |
60
Rep 2,128
01-08-2009, 05:40 PM | #9 |
Rep 57
i called BMW austalia today and they mentioned to me that in order to complete a steering wheel change i need to replace the steering wheel itself and the airbag module.
looks like you just replaced your steering wheel and looks great and props to your work, but are you sure the airbag is ok? |
02-01-2009, 11:35 PM | #10 |
(oO (||||) (||||) Oo)
Rep 165
The only way to find out is to hit something... hard
No, the airbag will be fine. If it wasn't, the car would shoot out an error code right away.
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red |
02-02-2009, 06:47 AM | #11 |
60
Rep 2,128
Like a lot of dealers, they'e mistaken. The airbags on the M wheels and the standard wheel are interchangeable, so you can re-use the original.
02-10-2009, 02:30 PM | #12 |
23
Rep 374
do you have to insert both screw drivers into the hole at the same time or can you do it one at a time?
do you just push and it unclips the airbag? trying to get a better idea on this as i am about to do the same swap |
02-11-2009, 02:52 PM | #13 |
There I was balls deep in a...
29
Rep 1,470
Its so easy! Took me about 5mins to do the entire thing! Just do one side at a time and it pops out, then remove the clips undo bolt and then redo!
05-21-2009, 03:11 PM | #14 |
Rep 67
I am about to do the same thing to my car. I have the multifunction wheel but don't really like how it looks. Was hoping to find someone who likes the look of the multifunction or wants to be able to control the radio from the wheel. I see your wheel does not have the multifunction inserts, wanna trade?
03-30-2014, 09:34 PM | #19 |
23
Rep 413
Drives: Z4 3.0, CLS63 AMG
Swapped out my stock Z4 wheel with the M wheel a couple days ago and LOVE the new wheel. My '05 wheel was disgusting from all the wear and Tischer had a deal I just couldn't resist...
The install was easy, but as the OP described, I had a tough time finding airbag release points with a screwdriver. After 5-6 mins I found the right release point and the left took less than 10 sec. LOVE the new wheel. Feels so substantial and the stitching is great too.
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
05-08-2014, 03:19 PM | #21 |
13
Rep 164
Drives: 08 Z4M Coupe
Wheel Removal
Thanks!
Just used this post to straighten out my wheel! |
