The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Nettodat = Fsw_psw?
      01-26-2013, 06:05 PM   #1
BmerMeUp
BmerMeUp's Avatar
32
Drives: Cinderella: 2008 E91 328xi
Nettodat = Fsw_psw?
Hi. Quick and potentially slightly stupid question.
I can code a module using the FSW_PSW file,
--> or
I can code the SAME module using its related NETTODAT.
QUESTION: When I code a module using NETTODAT, is that effectively setting all the same switches as if I did the same settings in the FSW_PSW file?
I'm thinking yes, but wanted to check.
      01-26-2013, 07:55 PM   #2
rich123321
rich123321's Avatar
72
Drives: BMW 325i E90
2015 335i  [0.00]
--> or
Don't quote me but I think yes. I believe it's just a specially encrypted file that's much more compressed
      01-26-2013, 08:15 PM   #3
BmerMeUp
BmerMeUp's Avatar
32
Same here.
I'm thinking the NETTODAT is basically just a numeric representation ("compiled" version if you wish) of the human-readable FSW_PSW file... but wasn't 100% certain.
Sitch is: I de-coded my car prior to service (over-cautious.. I know) and want to re-code all my modules, 1 at a time. One of them, NFRM (FRM2), has non-standard NETTODAT settings for the 4-click turn signal. So I was wondering... do I need to code the backed up NFRM *and* the NETTODAT... or just the NETTODAT because it does all of NFRM *plus* it fixed the non-standard hex bytes for the turn signals.
Mmeh. What the heck, I'll just give it a try with NETTODAT only and see if all the changes stick! Simple enough.
      01-27-2013, 01:05 PM   #4
BmerMeUp
BmerMeUp's Avatar
32
For reference, for anyone stumbling on this via a search.
I just recoded a handful of modules using their backed-up NETTODAT files instead of creating a .MAN file for each one.
They all worked (one at a time) except ABG which wouldn't talk to its backed-up NETTODAT, so I coded it with the backed up FSW_PSW file normally. Coding from a backed-up NETTODAT is a little easier (especially if you have more than 1 to do) because I don't need to copy/rename each FSW_PSW file to .MAN and Change_Job to SG_Codieren and all that, just code directly one-step from NETTODAT (*Note: NCS seems to need old-school less-than-8-character long file names for NETTODAT.TRC. It didn't like it when I had names like NFRM-NETTODAT.TRC, but "NRFM.TRC" worked fine). Also - don't forget to change your selected ECU between coding!
Fyi - seems like most modules CAN be coded directly from their NETTODAT (easier when backing up/restoring)... but not all.
