Procede running very lean
01-24-2013, 07:41 PM | #1 |
52
Rep 748
So I recently went from JB4 to Procede. I am full bolt-on so I am running the Stage 3 Aggressive 9-23 map. I am running very lean (~20:1) on WOT runs with maxed fuel trims. I have progressively upped the global OL setting which helped (originally maxed AFR) but still have very lean AFR's. Can anyone tell me why and how I can resolve this? These are on map 1.
Settings window (I changed the OL on each of the datalogs): OL100: OL:85
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
01-25-2013, 07:41 AM | #4 |
184
Rep 2,841
That seems unusual to be running out of fuel and maxing trims at only 14 psi of boost.
You should log fuel trims for bank 2 as well as bank 1 to see if they are both maxing out. This will help rule out a faulty injector in bank 1 causing this issue. You can also try increasing the cell values for open loop fueling in the user adjustable table. Here is what I changed mine too: . . . |
01-25-2013, 07:57 AM | #5 |
68
Rep 1,432
+1 for looking at both of the banks. If only one is running lean, you could have accidentally swapped the o2 sensors in your DPs. Or as Ilma said, you could have a bad injector.
01-25-2013, 08:19 AM | #6 |
177
Rep 6,631
If he swapped front o2 sensors his car would be undrivable. If he swapped rear o2 sensors it would throw an SES light along with a code for swapped sensors, but would not affect trims the way the OP is seeing. He also did not appear to have these issues with his old JB4, which rules out hardware.
01-25-2013, 09:02 AM | #7 | ||||
52
Rep 748
I am running 93 octane gas, no E85 local to me unfortunately. Quote:
01-25-2013, 09:10 AM | #8 |
65
Rep 1,708
Looks like both trims/AFR were logged and matching well. This seems to be a fuel pump issue. I don't remember the logging options in procede for fuel pressure, but you can use BT tool to see if you are short of target.
I believe HPFP would be more likely to throw a code... LPFP can easily be short of target without throwing a code. So if you wanted to "try" something, LPFP would be my guess. |
01-25-2013, 09:20 AM | #9 | |
177
Rep 6,631
Like he said he did not have any issues with the JB4. this is tune related.
E90 LCI N54 6AT
01-25-2013, 10:13 AM | #11 | |||
52
Rep 748
Thanks for the input guys, I will try this when I leave school today. Called (voicemail) and emailed vishnu again so hopefully they will have some good information too.
01-25-2013, 10:15 AM | #12 | |
17
Rep 283
01-25-2013, 12:23 PM | #13 | |
3441
Rep 79,211
Call them after 11 AM PST. Best way to contact Vishnu is by phone. They are flooded with too many emails. |
01-25-2013, 05:20 PM | #14 |
52
Rep 748
Talked to Vishnu today. They told me Shiv thinks it is either the injectors or stock DME flash and to see how it does after I get the reflash and install the VFF700 kit next weekend. FWIW I had the injector recall before and they checked the injectors and replaced one bank. So we will see how it does after I install the VFF700 with the DME flash.
Although I think something is amiss somewhere with max fuel trims on pump gas at this low boost, but we will see. I also was not able to log that LPFP voltage as it snowed and I had to leave my car at my school parking deck. I'll report back the LPFP diagnosis hopefully tomorrow. On a more positive note, my Kosei K1's and Hoosiers arrived today. Should have some drag times March 23rd when the track opens and some dyno numbers sooner.
01-26-2013, 08:23 AM | #17 |
542
Rep 1,195
Dont simply assume the Procede flash will solve your problems. I thought the same and when the flash came back I had new problems that Vishnu refused to acknowledge.
Wouldn't return my phone calls or emails. Its been 2 months and I'm still waiting on my "Guaranteed he will get to you this time" reply from Shiv himself. If you don't live near them I would stay away from the flash option. It is impossible to get any help otherwise, even when they make a mistake. My car is now totaled (thanks to a dump truck losing its cargo on the interstate) so my muffed DME is in the junkyard where it now belongs. |
01-26-2013, 05:57 PM | #19 | |
52
Rep 748
Well I did another datalog with 3 different fuel pressure parameters logged. Also my old logs had debug type 4 already logged as well so that is included as well. My OL fuel map:
01-26-2013, 07:15 PM | #20 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
^^Now that is a literal definition of screenshot! LOL. I have a similar issue...maxing out fuel trims at 14 psi on pump gas, also throwing 29E0/1 fuel mixture codes, which I presume are related. But my car throws these codes even on stock tune. Called VAC to see if they can help me, but they havent called me back..,pretty disappointed, actually.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
