01-22-2013, 08:10 PM | #1 |
Rep 17
Question about A/C
Hi, how come every time I start the car the air conditioning comes on, in spite of being turned off previously
Thanks |
01-22-2013, 08:13 PM | #3 |
179
Rep 1,044
Yeah! I find it annoying too. Especially when you have to turn it off immediately. Isn't it bad for the ac compressor to turn it off shortly after it has been turned on?
01-22-2013, 08:25 PM | #4 |
12
Rep 42
I've read that normally you can just leave the system in auto mode with AC on, all year around.
Is this true? I don't think the manual was very clear on this matter. Also, should I just leave everything in auto most of the time? (Auto climate control, AC on, Auto fresh air/recirc) |
01-22-2013, 08:52 PM | #5 | |
47
Rep 420
believe that setting acts as an air filtration system. My personal preference in the winter time is to keep the temp on AUTO but A/C off, Seems to work out fine, I switch the A/C to on in the summer with AUTO on. So, basically the reverse. |
01-22-2013, 09:19 PM | #8 | |
47
Rep 420
01-23-2013, 03:57 AM | #12 |
Infidel
122
Rep 1,102
Why would you wanna turn the A/C off? Mine is constantly on, on the exact same setting all year around -> 22 C. It makes no difference if itīs way below freezing (like now at -20 C) or real hot summer temps. Always have fresh air inside and I get fresh air thus no stanky smells develop (from moisture).
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
01-23-2013, 06:13 AM | #13 |
2797
Rep 5,115
it also means that the gas is circualted around the system , I was always under impression you need to use teh a/c at least once a week. If you don't, the gas can start to leak out and if it gets really bad, can damage your compressor causing you a large bill.
Best to leav it on all year. You set the temperature you want and the system looks after ecerthing else. It will als ensure the car doesn't steam up inside when its say raining outside. I simply can't think of a reason to turn it off. |
01-23-2013, 07:21 AM | #14 |
Infidel
122
Rep 1,102
The only reason one would want to turn it off is to save a few cents on fuel. But thatīs just fooling yourself as keeping it off can eventually create other, more costly, problems. So donīt be cheap, be smart.
01-23-2013, 05:54 PM | #15 |
80
Rep 251
Drives: E82 N52 6MT A51
Doesn't this car have a disengaging alternator. So if the ac is off, there is significantly less strain on the engine during winter months?
01-23-2013, 07:03 PM | #16 |
128
Rep 588
Drives: F30 320d & G29 M40i First Edtn
I didn't think the alternatr disengaged when the temp was low as with the ASS - linked all together...
Modern cars are designed to have the AC on all the time now really. Gone are the days of hefty fuel consumption increase and decreased power when pulling away and using AC
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
G29 M40i First EditionFrozen Orange |
01-24-2013, 04:30 AM | #17 | |
6659
Rep 15,858
As already said "think smart" and keep the CC in optimum condition, no discomfort (or smells) in the car. HighlandPete BTW, I assume some of the posters mean they switch off the A/C function, and are not meaning they switch off the whole HVAC system, meaning no air changing in the car. |
01-25-2013, 02:32 AM | #18 |
12
Rep 42
The AC system is separate from the air filtration system right? What I means is turning the AC on or off should not affect the quality of air filtration.
Compared to my old econobox, I do notice much improved air quality, since I'm driving mostly with all windows closed while it is winter time. I have put the moonroof in tilt mode once in a while, but would immediately notice outside smells (like diesel smells from big rigs) in the cabin, leading me to immediately close the moonroof again. Never noticed that with my old car, so I am wondering if the BMW is doing a good job filtering the air, so as soon as I crack open the moonroof, the outside smells become that much more noticeable. |
01-26-2013, 05:30 AM | #19 |
Canada Eh!
12
Rep 221
I don't have a F30 but I have a E90. My car has 200,000 KMS on it now and I never turn off the A/C compressor. It cools me down in the summer time and keeps my windows from fogging up in the winter time. It's still running strong. I wouldn't worry about it too much.
