F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Oil Catch Can? N55 "oil blow through" issue?
Extreme Powerhouse
      01-19-2013, 09:10 AM   #1
ewill858
16
Drives: 2013 335i M-Sport
While browsing burgertuning.com to learn about different available mods, I happened upon this "BMW Oil Catch Can". The description reads:
http://burgertuning.com/BMW_335_oil_catch_can.html
"It's no secret that the BMW N54 motor suffers from serious oil control problems causing oil to blow through and coat the intercooler and charge piping, gunking up intake valves and the VANOS system, lowering the effective octane, and generally degrading engine performance. The higher your boost levels the more apparent these problems become."
There is a kit for the N55 as well.
Is anyone out there knowledgeable about this "oil blow through" issue and knows whether it might also apply to the F30 335i?
Thanks!
      01-19-2013, 09:46 AM   #2
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
it happens in all turbocharged engines...
I wouldn't stress about it. I drove an Evo VIII at 24psi (peak boost) for 85k with no oil catchcan, and honestly, after changing piping or servicing it, not much oil buildup at all. Small amount is expected...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      01-19-2013, 11:28 AM   #3
ewill858
16
Thanks. That's helpful. This was the first I'd read about the issue.
      01-24-2013, 11:34 PM   #4
pattyp247
Drives: 2011 335i space grey
Maybe for an evo
I dont have an f30 but do have a n55 and highly reccomend it especially if your planning on run higher boost . I had got a half engine light on about a week ago Nd popped out my obd reader and got a code fuel system rail problem which is where your fuel injectors arent sprayin propperly but cleared it and went away then a Week later changed my charge pipe there was sooo much oil every where and all over my maf sensor the. Did some reaserch aNd found out it was the oil from my blowback getting on the injetors cloging them. bmws with turbos are known for this problem according to my sa its only 200$ to prevent future problems imo! God knows what other piping is coated with oil
      01-25-2013, 06:04 AM   #5
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
That's good info. Did you take any pics of the oil spray?... Who makes a Catch Can for the f30?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      01-25-2013, 07:40 AM   #6
shivaswrath
649
Drives: 2012 335i
Evo's push a lot more boost than an N55, ANY day.
Regardless, how much boost are you running?
      01-25-2013, 10:13 AM   #7
WilliamE92
WilliamE92's Avatar
21
Drives: 2013 EB F30 335 MT
That's silly, as an EVO isn't Direct Injection - the whole lynchpin of N54's buildup problems.
      01-25-2013, 10:49 AM   #8
shivaswrath
649
Drives: 2012 335i
Touche, totally forgot...I recant my comparisons...
I do remember my brother's 135i having a catch can (MY 2008)...his dealer agreed to install this.
      01-25-2013, 07:10 PM   #9
pattyp247
No i i mean i still have the oem charge pipe thats coated in oil but i mean my maf sensor loooked like it was a dipstick
      01-25-2013, 09:20 PM   #10
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
Don't worry I spoke with Terry at BMS it's not a big deal on our motors. It was really bad on the N54 but that motor had a list of issues. If your still concerned there will be some coming out later this year.
      01-26-2013, 06:04 AM   #11
mikew2069
mikew2069's Avatar
413
Cool. I'm not super concerned but my opinion is, if you're going to mod and piggyback or ecu flash, just go ahead and spend $150 or how ever much this will end up costing - very small insurance policy/longterm maintenance mod.
BM3/H&R/Borla
      01-26-2013, 10:37 AM   #12
buildbright
155
Drives: F80 M3 MG
I agree. Trust me I am on the BMS tech fourm everyday pushing for F30 parts. There is some really cool stuff for the E9x's N55 that I can't wait for and Rob Beck is even working on a Turbo upgrade for all N55's.
      04-13-2013, 11:43 PM   #13
aus
890
Drives: Odysse
This is a Direct Injection issue. NOT a turbo issue. This gas is from the crank case that really should be sent to the exhaust system, but in order to keep the tailpipie gases clean, manufacturers recirculate it to the intake tract.
In a port injection car, the fuel is sprayed before the valves, so the fuel sprays cleans off valves with each spray. With DI, the fuel is injected directly into the cylinder, so there's not fuel spray to clean the valves. There are plenty of Porsche Panamera/Cayenne engines with oil gunk on the valves too. The Audi RS4 was the first car to really bring the problem to light.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      01-28-2017, 07:14 PM   #14
mattpete13
122
Drives: 2011 e91 6mt
looking for any updates to this topic if any - have 2013 335 N55 w 60k miles - only using AFE scorcher w intake and also adding DP in spring.
Is this overkill for my situation but maybe necessary when adding a JB4?
      01-29-2017, 08:05 PM   #15
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
515
Drives: 582whp/596wtq '13 335i
It's not necessary for the f30 n55, nobody makes one.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      01-29-2017, 08:23 PM   #16
overkill1125
overkill1125's Avatar
130
Drives: 2019 440xi Gran Coupe
Available since 2013
      01-29-2017, 08:24 PM   #17
obriennathaniel
515
That's for an E chassis.
f30post
