07 iDrive E90, can you add factory Sat radio
01-15-2013, 02:54 PM | #1 |
Rep 122
Hello all
I did a search and could not get a answer I need. I have a 07 E90 with iDrive and the car does not have Sirius Radio. I have a buddy with a 2 door 08 335i as a donar without iDrive but has Sirius and wondered if I could get his parts to work in my car? He does not use Sirius Thanks Sethro
I repair iPhones, smartphones, Tablets and laptops
www.tecrehab.com |
01-15-2013, 05:33 PM | #3 | |
Rep 122
Thanks Seth
www.tecrehab.com |
01-17-2013, 01:43 PM | #4 |
14
Rep 294
ah... in that case it'd be more involved. Check wds online, to find out the exact wiring scheme for you and your friend's car. Then you need to move the wiring from his car to yours.
01-19-2013, 09:15 AM | #5 |
11
Rep 33
Check your vin, if your car is sat prep, you may only need the unlock code to activate Sat radio. No hardware required. I can't remember when they swapped over to this but it was around this time.
01-19-2013, 09:29 AM | #6 | |
2297
Rep 13,005
01-19-2013, 09:41 AM | #7 |
170
Rep 1,843
No the unlock code was not until later. He needs his car to be equipped with "satellite prep" then the module from his friend's car, and to have the tuner coded in. Part of the process will be rearranging some fibers at the MOST connector behind the rear seat bolster as well. BTDT with my '09.
If he doesn't have "satellite prep" it is probably going to be more trouble than it's worth unless he really really wants Sirius. |
01-19-2013, 11:57 AM | #8 | |
2297
Rep 13,005
01-29-2013, 08:40 AM | #10 |
170
Rep 1,843
