Downpipe fitment issue (v-clamp won't close)
01-12-2013, 09:43 PM | #1 |
20
Rep 186
Drives: E92 2008 335i - AW/CR
So I finally got around to installing my downpipes but I am having a issue with the longer downpipe (front turbo). I can't get the v-clamp to close on the pipe/turbo flanges because the Downpipe flange doesn't sit flush against the turbo. On one side it is flush, but on the other side there is a small gap about halfway around the pipe. Even though the v-clamp grabs both, it does not close because the flanges are not tight enough.
Has anyone encountered this? Are there any suggestions or do I need to replace the downpipe because of a poor fit? I will try posting pictures tomorrow. Thanks in advance for the help. |
01-25-2013, 08:28 AM | #5 |
20
Rep 186
turned out to be a defective pipe. i swapped it out for a different one and everything it great now. v-clamp is closed to about 1/4" with nothing touching. No noises or vibrations and im loving the new feel. i never realized the sound of the turbos would become so much more noticable. can't wait to test the additional power once it gets above 10 degrees in NY
01-25-2013, 08:47 AM | #6 |
132
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
I had a similar issue, the clamp was slightly warped and was very close to starting to thread but wouldnt. After 3+ hours i ended up making sure it was completely on, then using pliers to close it. It worked perfectly and without much resistance. No exhaust leak after several hundred miles
01-25-2013, 12:18 PM | #8 |
20
Rep 186
any smells in the cabin at all? the awful new downpipe smell went away after 2 days, but i still get a burning smell when i park in the garage. i'm thinking it might need a few more days unless i have a leak. everything sounds good tho.
01-25-2013, 08:35 PM | #11 |
20
Rep 186
01-25-2013, 08:44 PM | #12 |
132
Rep 2,489
Uhm what????? We were supposed to?
01-26-2013, 07:41 AM | #13 | |
Rainbow Racer
1008
Rep 2,540
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
01-26-2013, 11:10 AM | #14 |
132
Rep 2,489
Very true. At that point of the install i was about to kick the damn car off the jack stands and sell it hahahah
