01-10-2013, 10:56 PM | #1 |
Rep 65
6MT Shifting from 1st to 2nd Under Pressure - Hitting the "notch"!
I'm not used the 6MT in my 328i Sport. When i'm accelerating in SPORT mode and shifting from 1st to 2nd under load, i'm hitting that damned R notch! It's so annoying! Any tips or am I just going to have to practice, practice, practice? My '02 Jeep Wrangler's 5MT was a lot easier to shift under pressure, as was my '03 Jetta! I remembering hearing in reviews that "if you like the BMW 6MT drive train, you'll like this one, but if not, you'll hate it". First bimmer so I guess i'm a little in shock that I keep hitting that damned notch!
'12 Jet Black 328i 6MT Sportline
Originally Posted by JBasham Caddy ATS . . . finally, a decent rental car option. |
01-11-2013, 06:48 AM | #2 |
Rep 150
Pull back on the the gear shift lever, not back and left. No need to ham fist it.
You can always try this... http://www.nexternal.com/uuc/article..._technique.htm Although I don't. Joel
That's a lot of white |
01-11-2013, 06:56 AM | #3 |
13
Rep 171
Interesting, never had any issue with that no matter what car or what kind of driving I did. (sporty, granny style,...) and I think nearly all brands have the Rshift overthere nowadays.
Then again I only have an automatic if its a loaner. |
01-14-2013, 12:32 AM | #4 |
14
Rep 525
Huh. I've driven a lot of BMW M/Ts and have never had that problem -- in fact, it can be quite difficult to get the car into reverse if equipped with a short shifter. Sounds like there might be something slightly 'off' with the gating? Yeah, don't be ham-fisted, but even if you are, you shouldn't be able to hit that notch.
01-14-2013, 12:42 AM | #5 |
595
Rep 3,870
go easy brother...
been driving 3 series manual transmission for over a decade now, and i've never had this issue..
from 1st, all you have to do is pull gear lever straight down, while maintaining a very light pressure to the left "wall"... no need to put so much pressure to the left as to fall into the R track...
