TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY M3/OEM Upper & Lower Control Arms
      01-06-2013, 05:01 PM   #1
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Note: Not responsible for any damage to you or your car, this worked on my car so will work on yours.
***This tutorial assumes you know how to get your car secured on jack stands, if in doubt do NOT attempt this DIY!
Tools Need not in pic (2 jacks if possible & block of wood, (1) for a safety catch in case jack stand fail (I saw this happen and will NEVER forget it)....safety 1st). The 2nd jack is for jacking up suspension up to ride height.
Torque specs:
upper & Lower control arms to knuckle 122 ftlb (165 Nm)
upper & Lower control arms to subframe 74 ftlb (100 Nm)
Suggestions:
Alignment is 100% neccessary, no ifs about it! your car will ride like a POS afterwards.
I suggest coating all bolts with bolt penatrating formula, applying anti-seize to all bolts and replacing your tie-rods with these below so you only have to do a lignment once. (see link)
http://www.hpashop.com/BMW-E8X-E9X-Z...Rod-E8x-9x.htm
Tools: (besides jacks and block of wood):
Pic of M3 Control arms:
Pretty sure "M" Logos where here LOL!
Step #1: (Jack suspension up to ride height (18.7" from bottom of hub to fender)
Step #2: Take off under belly and take loose the headlight adjusting rod (use 2-10MM wrenches) so you do not accidently forget
Pic of where to tighten/loosen rod:
Step #3: (Optional step, I did this to get a bit of "wiggle room" You can also take out your adjusting nipple...mine was already removed prior:
Step #4: Drop steering rack
Step #5: Loosen all bolts to Upper & Lower Control Arms & remove old POS!
If impact is not used or bolts just spins use this method:
A shop that installed my springs cut a slot in the stud to stick a screwdriver in for leverage and did not use the correct T40 in the end. This prevented me from being able to use the correct method and the bolt was stripped on there....luckily a impact lifted it just enough so I could get a hacksaw blade under it to cut it off (lost 2 hours of time) I was a bit PO!
M3 Upper & Lower control arms compared to OEM:
Movement of the M3 Lower control arms at subframe:
Step #6: Reverse all steps (dont forget to put new leveling rod in):
M3 arms installed: (I will be replacing my Tie-rod ends also with these linked below)
More camber at bottom!
Very easy tutorial, hope this is of help to somone!
Rob
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
Appreciate 8
      01-06-2013, 05:24 PM   #2
hugus311
Titanium silver + Sport + Premium
hugus311's Avatar
32
Drives: 2006 330i (E90)
very clear and concise
      01-06-2013, 05:43 PM   #3
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
thanks! Will add alignment specs before and after also.
      01-06-2013, 05:46 PM   #4
cypis007
Poland
Drives: E91 318d Touring
Thumbs up
Awesome DIY. You're a champ!
      01-06-2013, 07:59 PM   #5
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
thans man!
      01-06-2013, 08:12 PM   #6
froggy47
Drives: 2007 328i coupe
Is there anyone who makes just a bushing kit, so you don't need to buy the whole arm?
On my other cars I always find out later, that someone does make a kit.
Is the increase in neg camber from the actual dimensions of the M arm or is it a camber adjustment allowed by the M arm? Noob question.
My lower bushings a leakers on wifes 07 e92 coupe, but she doesn't need M stuff or the extra tire wear that may result.
2007 328i Coupe, 2004 Z06 Corvette, 1995 M3 Coupe, 2004 Lexus IS300, various SUV's
      01-06-2013, 08:33 PM   #7
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
there may be, but better replacing the arm. The negative camber of the M arm is in the arm.
      01-07-2013, 11:09 AM   #8
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Alignment specs:
Car handles unbelievably, roughness is gone. Great mod!!
      01-07-2013, 05:23 PM   #9
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Update:
Did some spirited driving and must say there is a HUGE difference....car handles without effort and this is with bad struts! This is one upgrade I would highly suggest, especially for higher mileage vehicles.
      01-11-2013, 10:18 AM   #10
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Also suggest getting these HD Meyle inner/outer Tie-Rods from Harold@HPAutowerks:
      01-11-2013, 02:30 PM   #11
DallasBoosted
DallasBoosted's Avatar
38
Drives: '08 E92 335i
2008 BMW 335i  [10.00]
Not that its difficult, but why drop the steering rack? I didn't do this when I did my suspension.
      01-11-2013, 02:37 PM   #12
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I did it to get the lower control arm bolts out easier
      03-23-2013, 10:11 PM   #13
simscott
14
Drives: 2008 328i
Do you need a puller to pop the ball joint out or can I just use a fork and hammer?
      03-24-2013, 08:01 AM   #14
Efthreeoh
17315
Drives: The E90 + Z4 Coupe & Z3 R'ster
Nice write up to the OP. Just one clarification: What the OP is calling the "Upper Control Arm" is actually referred to as the front "Thrust Arm" in the Bentley service manual and BMW calls it a "Tension Strut". It can get confusing.
Regarding popping the ball joints. I can't speak to the lower control arm (BMW calls it a "Wishbone" BTW), but I did replace the Thrust Arms and mine literally fell out of the steering knuckle. This on my car at 183,000 miles. I'd imagine the wishbone ball joint would be just as easy, or need a bit of finesse with a ball peen hammer.
      03-24-2013, 12:30 PM   #15
Atomicteal_M3
Atomicteal_M3's Avatar
748
Drives: E90 M3 AW
2007 335i  [9.00]
Great write up. I also purchased the M3 upper/lower control arms, Meryle tie rods, and M3 e93 front sway bar. I'll be getting it all installed in May upon my return from Afghanistan. Can't wait to feel the results!!
      03-24-2013, 01:00 PM   #16
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
there all the same, upper/lower control arm is easier lol! I just go by what the kit calls it that way people know....I agree with what you are saying as it does state this in the manual. Top is the same pulls out by hand.
      04-01-2013, 01:43 PM   #17
mannytabloid
757
mannytabloid's Avatar
Drives: 2007 335i E92
Dude, you left off a 18mm socket for the bolt to the subframe! Made for a very pleasant, but impromptu walk to Ace Hardware. Haha, no hard feelings, just wanted to let you know so you could update your DIY. Other than that, this guide was a godsend.
2007 335i E92
Sapphire Black, Saddle Brown, Sport, Premium, Cold Weather, OEM Rear Spoiler, M3 Strut Brace, Meyle HD Tie-Rods, M3 Front Control Arms - Upper and Lower, M-Tech Rear Bumper, Painted Side Reflectors, Alpine HID 5300k Angel Eyes
      04-01-2013, 03:17 PM   #18
mannytabloid
757
Oh and a quick question - for the lower arms, how did you manage to get the new arm bushing into the slot in the subframe? I cannot for the life of me seem to fit in it.
2007 335i E92
      04-01-2013, 05:56 PM   #19
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I ran into this issue the other day an another install...take a file and smooth out the mating surface. ..it will go right in! There is more than likely burs causing your issue.
      04-11-2013, 11:39 AM   #20
fdawg4l
0000000
12
Drives: E90 335i 6MT
Any idea why the M logos were scrubbed off your parts?
      04-11-2013, 11:46 AM   #21
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
they are TRW brand so are a lot cheaper...as you can see they are M brand with logos just scrubbed off. So basically no reason to get OEM M arms at a much higher price when the TRW brand is clearly the same part.
      04-11-2013, 03:38 PM   #22
fdawg4l
0000000
12
I wish you told me that 2 weeks ago. :-)
