BMW X3 Forum
BMW X3 Forum
      01-04-2013, 05:03 PM   #1
c3uo
39
Drives: 3 Series
Headlight Washer Leak Temporary Repair
All,
As posted earlier my headlight washer leaked over the past few weeks whenever it was below 10 F. I really don't like headlight washers and looked for a way to disconnect them. I eventually figured out as follows:
You can disconnect the headlight washer hose between the reservoir and the headlight washers as follows:
1. Relocate the washer fill nozzle (item 12 in below RealOEM link) from it's holder on the engine bay frame to get access behind the passenger side headlight.
2. Disconnect the passenger side headlight electrical connection.
3. Reach down beneath the passenger headlight and pull up on the headlight washer hose (item 9 in the below link) disconnect coupling (item 8) by pulling back on the sleeve and disconnect it. This is a quick disconnect coupling in the washer hose at this point. Washer fluid will pour out once disconnected.
4. Lift up the washer fluid hose and remove the 90 degree end coupling (item 8) to expose the bare rubber hose (I stuck two small screwdrivers on either side of hose to allow me to slide off the quick connect coupling).
5. Plug hose end (I had a small plug in my plumbing toolbox that worked).
6. I then stuck the loose hose up by the fill nozzle and put the fill nozzle and headlight electrical plug back on.
http://www.realoem.com/bmw/showparts...44&hg=61&fg=45
This disconnects the headlight washers and leaves the system open below the passenger headlight. My garage floor will no longer have a washer fluid puddle every morning! I'm not a fan of headlight washers. They always make your hood dirty and eventually leak... (this was a bit soon and I have no local dealer even though I am under warranty).
I hope to recode the ECU to stop the headlight washer pump from activating when you wash the windshield with the headlights on. I'll try to figure this out once I get my coding cable. Right now if actuated the headlight washers I would be dead-heading the headlight washer pump.
A few more tidbits:
- I originally removed the lower fairing / underbody panels and tried to fix the headlight washer from below the bumper. Access was a PITA. I ended up removing the lower side grill and going through the front bumper instead. It was terrible access. I now think it may have actually been accessible through the foglight (much easier). I can not tell how they are attached to the bumper because I would just replace the washer myself if easy to do.
- You can not access the washer reservoir and pumps from topside.
- I eventually figured out the only access to the reservoir was removing the fender liner. Unfortunately, I could only pull the liner back since I was afraid to break the fender liner pins. From this position I could not disconnect the washer motor electrical. I could see the reservoir and hoses though. In warmer weather this is fairly easy access to the reservoir and pumps once you remove the felt fender liner.
Anyway, not sure if this helps others but thought I would pass along my learnings.
      01-04-2013, 06:57 PM   #2
DonC
29
Drives: 2013 X3 3.5i M sport, etc
Thanks for your report!
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
      11-21-2013, 01:44 PM   #3
007nickjames
Drives: E89 35is
wqsher bottle leaks on x3 3.0se
Hi
Newbe here with 1st post, our hobby car is a mint 2003 z4 bmw 3.0i that we keep garaged. So for winter we have just purchased a X3 (we have owned Jeeps before) I think I know the problem but just wanted to check, the washer bottle has emptied fully only after 2 weeks and I have the rear drivers side carpet wet (UK X3 RHD) is this water pipe coupling coming loose that the X3 seem to suffer from? for now I will disconnect from the main pump and blank so I can use the front windscreen washers and headlight washers again.
Any body got any guides with pics for the fix ?
best regards
Nick
      11-21-2013, 06:39 PM   #4
Want the thrill
330
Drives: 2022 X4M40i, retired ‘11 X3
2022 X4M40i  [10.00]
Originally Posted by 007nickjames View Post
Hi
best regards
Nick
What year is your X3? First generation (2004-2010) or second generation (2011+)?
      11-22-2013, 09:39 AM   #5
007nickjames
Drives: E89 35is
Hi
Sorry about that 1st gen (54 plate ) 2004
regards
Nick
      11-22-2013, 11:46 AM   #6
Want the thrill
330
2022 X4M40i  [10.00]
Hi
regards
Nick
Hi Nick,
You will probably get more replies here:
http://x3.xbimmers.com/forums/forumdisplay.php?f=91
(The first generation X3 forum). Hope that helps.
xbimmers
