01-03-2013, 08:25 PM | #1 |
170
Rep 380
adaptive drive
Everything i read about this on the F10s seems to praise the way car handles when equiped with active roll bars and electronically controled dampers. xdrive stays perfectly flat in turns when equiped with this. Does anyone know if eventually this system will make onto F30s?
01-03-2013, 08:30 PM | #2 |
34
Rep 568
Probably not. Whole point of 3 series is more road feel and direct steering. Active roll bars and electronic dampers would just make it feel like a small 5 series.
01-03-2013, 08:48 PM | #3 |
170
Rep 380
How to active roll bars and electronic dampers take away from direct steering, which btw f30 lacks, unless you get VSS then maybe. You can already have electronic dampers as part of dynamic handling package. Some say it provides more road feel
01-03-2013, 09:00 PM | #4 |
54
Rep 1,544
They were praised on the F10 cos the base setting on the F10 is way below par (due to the heavy unladen weight of the car).
The F30 doesn't need adaptive drive to handle well, in fact all it needs is the passive M-sport suspension. Adaptive M doesn't provide better handling than passive M, if u want the best then just get aftermarket coilover such as KW. |
01-03-2013, 09:02 PM | #5 | |
170
Rep 380
01-04-2013, 03:28 AM | #8 | |
6659
Rep 15,858
The dampers themselves; F30 is a simplest form of CDC, with single proportional valve on each damper, coping with both compression and rebound damping variations. F10 uses the more advanced version of CDCe with two proportional valves per damper, dedicated to one function, compression or rebound settings. As a general note, on Adaptive Drive, the ARS function is, in my opinion, the key element to variable suspension, enables a car to have far better anti-roll characteristics, without the need for stiff (passive) ARBs and the negatives that causes, on the straight and over single wheel bumps where wheel copy unsettles a chassis. With Adaptive Drive the car handles far better even in comfort mode, as the cornering power and flatness is still pronounced. I can imagine it would be brilliant in the F30 chassis, but an expensive option in most users opinion, I guess. HighlandPete |
01-04-2013, 05:31 AM | #9 |
54
Rep 1,544
01-04-2013, 05:32 AM | #10 |
54
Rep 1,544
01-04-2013, 06:50 AM | #11 | |
6659
Rep 15,858
Will make the car weight more for sure, but would improve the sprung to unsprung ratio. Which factor is a positive aspect of suspension function in any vehicle. It is clear it helps 'shrink' the vehicles and improves the driving feel in the bigger models, like 5, 5GT, 6 & 7 series and the X5, X6. Whether many 3-series drivers would see the need, I'm not sure, but it would make a 3-series feel more agile, IMO. HighlandPete |
01-04-2013, 09:22 AM | #12 |
170
Rep 380
01-04-2013, 09:23 AM | #13 |
868
Rep 6,248
01-04-2013, 11:05 AM | #14 | |
54
Rep 1,544
Too many of these active systems will actually reduce road feel, that's why time & again the most the M cars get is EDC. |
01-04-2013, 11:21 AM | #15 |
54
Rep 1,544
01-04-2013, 12:12 PM | #16 | |
6659
Rep 15,858
As I said before, the ARB 'motors' are clamped to body, therefore are not unsprung weight by any definition. HighlandPete |
01-04-2013, 12:25 PM | #18 | |
6659
Rep 15,858
Exactly how this would translate to smaller chassis like a 3 (or even 1 series) is hard to predict. Certainly different, but whether better or worse for road feel, hard to know and judge without a system being available. I personally think cost is part of the reason why we won't likely see it in smaller cars, at this stage, but do take on board the comment on M-cars. But is that because it doesn't work, or is there more to it? Reading some of the technical papers on ARS systems, it is accepted that there are less compromiseds to a suspension system when we can control the ARB characteristics. Suggest we watch this space, as alternative and simpler systems are developed and tested. HighlandPete |
01-04-2013, 06:56 PM | #19 | |
54
Rep 1,544
I did previously asked over at the F10 forum the UK guys how they feel abt the M-sport suspension on the F10 & it seems those that have it are satisfied with wht they have. So the problem with handling can be solved by having M-sport (or better still a set of KWs). It's the ride comfort which needs EDC at least. Notice that previously BMW packaged the whole ARS+EDC system so that u must have both for 535i or above, but after 2011 u can have either EDC or EDC+ARS for 535i or above. For most F10 having EDC on itself is already good enough, tho the heavier versions might benefit from ARS. I think the weight of a vehicle plays a large part in whether ARS is beneficial or not. E.g. it's preferred to have ARS on a Porsche Cayenne & not on a 911 (PDCC is available on both). Using an active system on a heavy car means u can control weight transfer more effectively without the need for thick & stiff anti-roll bars, whereas a passive system is already good enough on a lighter car as there's less weight transfer. The main point of the active system is to maintain comfort whilst at the same time being able to control bodyroll. As I said before, too many active systems dampens driving feel, hence u don't see ARS tech on cars such as R35 GTR, but to a certain degree manufacturers accepted that EDC is a must cos the car have to have an acceptable ride quality for day to day driving. If u talk abt the F30 then it's not heavy enought to benefit from ARS. Even on the M-sport/M-performance the front anti-roll bar is only 22mm in diameter. Last edited by clarence; 01-04-2013 at 07:55 PM.. |
01-04-2013, 07:48 PM | #20 | |
54
Rep 1,544
BMW considers the subframe as part of the suspension system, hence it's part numbers have the same starting digits as other suspension components. The links from the oscillating motor to the suspension drop-links have to be significantly stronger than a normal anti-roll bar cos it has to minimise torsional movement when the suspension compresses during cornering. |
01-04-2013, 07:57 PM | #21 |
54
Rep 1,544
Similar except DHP has variable ratio steering (according to steering lock, passive system) but not active roll stabilisation.
01-04-2013, 08:03 PM | #22 |
35
Rep 501
