AE and LED fog lights flashing
12-30-2012, 10:56 PM | #1 |
298
Rep 2,015
I just installed aftermarket AEs.
And Led fog lights. The issue is, when I start my car, ie engine start only the AEs and Led fog lights flicker or pulse on of for about 5 to 16 times. Is this normal, or did I get faulty lights. DDB |
01-02-2013, 11:48 AM | #5 |
860
Rep 35,253
we have both the flicker free angel eyes and flicker free led fog lights, PM us for more information
01-02-2013, 11:56 AM | #6 |
KOrey
26
Rep 548
Drives: 335i Coupe
i got the rear turn signal LED from ^ E90-Lighting and it gives me Malfunction however the lights are working fine.. i guess all leds has to be code out beside LUX
01-02-2013, 11:57 AM | #7 |
971
Rep 3,864
Drives: 330i, 135i
Its a cool effect..LOL JK I have the same issue ever since I installed new AE few years ago. Doesnt bother me much, I just manually turn knob to turn them on and flickering stops. Great to know that this can be coded out.
01-02-2013, 12:01 PM | #8 |
3441
Rep 79,211
It's the bulb check. That aspect is normal. But not all Angel Eyes or LED Fog lights do that. It can be coded out.
Our HPB 20 Watt Angel Eyes don't flicker on start up. |
01-02-2013, 12:13 PM | #9 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
01-03-2013, 01:37 PM | #11 |
11
Rep 113
whew, and I thought it was just me. I have Lux 5.1s installed, no flicker. But I did get matching HID Fogs, that do flicker everytime I press the unlock button on my keyfob. Really does look like strobe lights. Tacky, but I guess that can be coded out? I figure it can't be good for the life of the bulb, right?
Also, just a couple of days ago, got a 'right low beam malfunction' on my stock oem xenons. When turning the light on/off, it does flicker a bit before dying...does anyone have any idea what this is about? I'm hoping its just a simple D1S bulb that I can replace myself since BMW warranty doesn't cover bulbs. If not, I'll have to bring it in to BMW and get the headlamp looked at, as I'm still under CPO warranty, but I run the hassle of having to take off the Luxs and possibly the aftermarket HID foglights too. I don't want BMW voiding warranty on the headlamp because of those aftermarket parts. Any input? Thanks all! |
01-03-2013, 03:16 PM | #12 | |
860
Rep 35,253
01-03-2013, 03:30 PM | #13 |
11
Rep 113
01-03-2013, 03:32 PM | #14 | |
860
Rep 35,253
01-03-2013, 03:34 PM | #15 | |
11
Rep 113
Any idea what Lux's Kelvin temperature is? Some say 5k some say 4.3k... |
01-04-2013, 11:13 AM | #16 |
BimmerPost Supporting Vendor
469
Rep 4,938
the LUX H8 V3 angel eyes are a 6500K White
01-04-2013, 11:18 AM | #17 |
11
Rep 113
01-04-2013, 12:20 PM | #18 | |
Brotographer
88
Rep 1,741
They are a great match to the LUX's. They are also effectively the brightest D1S bulbs available. They have the same lumen rating as the Phillips 18211+ bulbs (OEM standard bulb, around 3400LM) but a different salt mix gives the CBIs a 5000k pure white rather than a 4300K yellow white. They need about 10 hours to break in, but once they're broken in they're amazing. The people of Hidplanet.com literally go bananas for these bulbs. Check out some of the headlight retrofit pictures and it will all make sense! My car will be needing a bulb replacement soon and I absolutely plan on using the CBIs. They really are the best bulbs available. No aftermarket D1S bulb can even come close to these--even the fantastic morimoto 5000k bulbs were no match for the CBIs in Hidplanet.com independent tests.) I'll always stick to aftermarket bulbs for auxiliary lighting, because it's more convenient and the added cost of converting an OEM bulb isn't worth it. But for something that is not only paramount to my safety, but the safety of the loved ones in my car and others on the road, it's OEM or better-than-OEM. My two cents. |
12-27-2015, 02:07 PM | #20 |
37
Rep 169
Drives: M140 LCI F21 and E92 M3 CS
Just fitted 2 sets of LED kits for High & Low beam. The start-up cold checks do the same thing on mine now. It's like starting up a fighter jet!! 5 or so seconds of sequential flashes before it rests.
How do I code it out? Is there anyone who has tried the kit I need to do that? Or would BMW do it? |
12-28-2015, 08:21 PM | #21 | |
298
Rep 2,015
That is the best way. DN |
12-29-2015, 01:53 AM | #22 | ||
37
Rep 169
Any idea where I would find someone who does BMW coding? Besides BMW of course. I need my Head Unit coding too.
Daily: M140 LCI Stage 1 Track: E92 M3 Manual FOR SALE: 123D Track Car ready to go
