Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > M3 Rear Subframe bushing questions
      12-29-2012, 12:11 AM   #1
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I am getting a LSD/M3 control arms this month, then coilovers the next month then sways the month after that LOL!! Question is when is a good time to do the M3 subframe bushings? I am guessing with the LSD since exhaust, drive-shaft ECT will be out? What is the speacial tool it takes to get these out I keep hearing about? This doesnt seem to be a real hard job...maybe 6 hour job but will be more than 1/2 way there when taking pumpkin out (taking pumpkin out to take to a shop to have wavetrac or Quaife installed....dont want to set back lash LOL!!). Will a shop have to press these out or can I do this?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      12-29-2012, 12:19 AM   #2
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Found a link to the tool, dont know if I am aloud to post it LOL!!
      12-29-2012, 01:33 AM   #3
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Thinking about going this route instead of renting a tool lol!!
http://www.e90post.com/forums/showthread.php?t=543295
      12-29-2012, 11:07 AM   #4
cleex024
104
Drives: 2008 BMW 335i Coupe
the best ones would be the ones from powerflex that is solid but its much more of a pain in the ass than the inserts...i would be curious though to how big of a difference it actually makes...
and whats up with all the LOL!! at the end...i dont see whats so funny with everything you say
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
      12-29-2012, 11:24 AM   #5
cvc 22349a
cvc 22349a's Avatar
164
Drives: 335i
In conjunction with a rear sway bar as the subframe has to be dropped a bit to r/r a rear sway bar. To avoid duplicate labor, I'd wait to to lsd, rsb and rear subframe bushings at the same time.
Your questions are answered in the suspension subforum
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      12-29-2012, 12:49 PM   #6
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
It's called being slap happy.
      12-29-2012, 12:59 PM   #7
Ænema
14
Drives: BMW
If I was you I would look into the Defiv lockdown kit...
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
      12-29-2012, 01:05 PM   #8
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
you are the second one who mentioned this...I will find out wht this is...do you have link by chance?
      12-29-2012, 01:21 PM   #9
Ænema
14
Drives: BMW
I have a link but I can't post it because I would probably be banned
Google search defiv diff lockdown kit and click the "officially released" link
      12-29-2012, 01:34 PM   #10
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I found one for $650.00? I know ths is dumb but I am doing all the labor so it won't cost more.
I am putting in the LSD, then coilovers, powerflex subframe bushings (full not inserts) and they area lot easier to install without a tool and then the rear set bar. Some are saying to not do the rear swaybar and only do the front, I can't see logic in that....maybe they don't have a LSD? Probably do lockdown kit after all suspension is one unless I get bad wheel hop.
      12-29-2012, 01:49 PM   #11
Ænema
14
Drives: BMW
Yeah, that's the one. If I had the entire rear end apart I would go ahead and the lockdown kit, if not then you'll have to drop the diff again later to put put the kit in. I can almost guarantee you're going to have some severe wheel hop. I'm making less power than you are/will be and there's no way in hell i can launch my car at the track or on the street without either blowing the tires off or getting wheel hop(believe me, I've tried)
      12-29-2012, 02:08 PM   #12
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
see, I do mostly 40 punches...but some tracking to, so I will look into this farther.
      12-29-2012, 04:36 PM   #13
tcw
52
Drives: 2008 335i
What is the biggest benefit of the subframe bushings? Do they help with wheel hop at all (or will the Defiv kit solve this on its own) or just eliminate the "loose" feeling when under full load?
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
      12-29-2012, 05:13 PM   #14
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I went with these:
http://www.bimmerzone.com/product/PW...0-422-E9X.html
      12-30-2012, 01:17 AM   #15
MilehighM3
MilehighM3's Avatar
915
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
+1. The install is far easier than the M3 bushings. The hardest part of the job is installing the M3 parts. Compared to that, the sloppy OEM ones fall out...
Do the bushings at the same time as the rear sway bar, since that is the only other job that requires rear subframe removal/lowering.
      12-30-2012, 06:54 PM   #16
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
just ordered it
