Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > brian jessel brake replacement cost
      12-22-2012, 10:38 PM   #1
e90_328
modding little by little
e90_328's Avatar
Drives: 2013 328i
2009 BMW 328i  [0.00]
hey guys my car is making horrendous geinding noise when i brake.
thinking i need new brake pads...
u guys know how much to replace all four at brian jessel??
      12-23-2012, 02:30 AM   #2
e90_328
e90_328's Avatar
Drives: 2013 328i
pic of one of the brakes..
Here's the one that makes the most noise.....
Seems like i have enuf pad left?????
+ no brake sensor warnings....
Wat's wrong w/ ma brakes!! lolz.
      12-23-2012, 07:39 AM   #3
KCX_335xi
KCX_335xi's Avatar
62
Drives: 2018 M4 | 2013 e70 X5
It could be your wheel bearing man..... I just had mine replaced.
      12-23-2012, 08:32 AM   #4
MyF15+F85
MyF15+F85's Avatar
50
Drives: 2015 F85 and 2015 F15
I hope that someone will see what I see, but you have NO PAD left....
The only thing that I see is the steel backing ( which the pad is glued on )
and nothing else. As for the warning ???? It should have gone off already, but ??? Definitely there is no pad left
      12-23-2012, 04:52 PM   #5
e90_328
e90_328's Avatar
Drives: 2013 328i
I see... lol I thot that was the pad. lolz.
all the shops are closed. and i put the car in the garage,,,,,
I guess if i've been grinding this rotor all day, I'd better change the rotors as well...
Damn it. time to get some BBKs?
      12-23-2012, 05:01 PM   #6
e36mcab
30
Drives: e36mcab
I don't think you are correct. There is plenty of pad left. As to the noise, I don't have any suggestions.
'19 M5 Competition - Donington Grey
'99 M3 Convertible - Estoril Blue
'08 M3 Sedan - Sparking Graphite Metallic *Sold*
'95 318ti - Alpine White *Sold*
      12-23-2012, 05:03 PM   #7
e90_328
e90_328's Avatar
Drives: 2013 328i
I thought the red arrow part is the backing that holds the pads. no?
      12-23-2012, 05:06 PM   #8
e36mcab
30
Drives: e36mcab
The red arrow is the pad width. The backing is thin metal piece beside the left side arrow.
      12-23-2012, 05:09 PM   #9
e36mcab
30
Drives: e36mcab
If there were grinding on the rotor, you would see scoring on the rotor. It appears your rotor is in ok shape.
      12-23-2012, 06:06 PM   #10
MyF15+F85
MyF15+F85's Avatar
50
Guys !
You better look at ANY used or NEW for that matter pad.
There is nothing left on that pad, hopefully this will work...
Look at the thickness of the pad, please...
      12-24-2012, 05:35 PM   #11
e90_328
e90_328's Avatar
Drives: 2013 328i
Got my new rotors, pads and Brake Queit, etc etc....
Got home, can't find a thingy to undo my lugnuts.. I have it somewhere!!!!!!!
ARGH..
      12-24-2012, 10:21 PM   #12
arthurg
Drives: silver 335i
You have no more pad left, as why the brake light did not go off is that the brake sensor is only on one side, that side might still have some meat left
      12-25-2012, 12:17 PM   #13
e36mcab
30
Drives: e36mcab
Guys !
Ooopps...You were right! I didn't realize the backing was that thick.
      12-25-2012, 03:34 PM   #14
TOPEC
<3 Flat Four
217
Drives: 335is LM Blue
id get ur brakes done professionally, it looks as if ur outboard pad is down to the pad backing while the inboard pad has pad left since it did not trip the sensor, that means one side must have been seized and not sliding in and out properly. my guess is the piston on the inboard side if seized.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White
      12-25-2012, 04:08 PM   #15
dtea604
dtea604's Avatar
28
Drives: 06 E90 325i
Try nixons or cg motorsports forsure cheaper then brian jessel you could also try drivehard performance or aria auto
      12-26-2012, 07:29 AM   #16
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 Audi TTRS  [10.00]
2012 BMW X6M  [9.00]
2007 BMW 335i  [9.00]
Just did all 4 corners with new pads, rotors, sensors. Cost about $850 from tire rack for parts.
