The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Setting up Laptop for coding
      12-21-2012, 01:12 AM   #1
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
Currently Running Win7 Home Premium SP1 with 1.7GHz processor, 8GB installed RAM and 64-bit. NO CD Drive
I need a 32-bit OS. Downloaded a copy of Windows XP. Currently its an .ISO file. No Cd Drive (Can't burn it to a CD)
I wanted to install the windows xp on either a virtual drive or a memory stick. I've been reading around and been playing around with Daemon tools and Oracle VM VirtualBox but still haven't got anything running.
Some help would be appreciated!
      12-21-2012, 12:24 PM   #2
rich123321
rich123321's Avatar
72
Drives: BMW 325i E90
2015 335i  [0.00]
Hey bud. I have a presetup coding VM that I made myself and code with. Basically plug and play except you need to change the port settings (may not even have to do)
      12-21-2012, 01:06 PM   #3
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
Just got VM running! Thanks
Moderators can close or delete this!
      12-29-2012, 12:00 PM   #4
infamousq
infamousq's Avatar
314
Drives: 2018 Ford Raptor
Is there anyway I can get a copy of this VM so I can code my car also?
      01-03-2013, 04:25 PM   #5
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
A few options:
1. google and download Oracle VM Virtualbox it's free software and a copy of winxp (or any other 32 bit OS from a wares or torrent link). Install the 32 bit OS within Oracle VM virtualbox.
2. wait for Rich to respond
3. buy a 32 bit OS laptop
      01-04-2013, 02:39 AM   #6
rich123321
rich123321's Avatar
72
2015 335i  [0.00]
Ill pm you now!
      01-08-2013, 06:09 PM   #7
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
Hey Rich,
Is your VM running a 32 bit OS with all the drivers installed?
I am running Win XP VM and have had trouble installing drivers I guess? I have a few yellow "?" marks in Device Manager. (Base system Device, and Video Controller (VGA Compatible)
I kind of don't think thats the problem though. Because I had followed every step in Juniors PDF.
I think I have problems with finding the correct port the cable is using :S not sure how i'm wrapping my head around this. (I should probably use the cable soon...lol)
      01-08-2013, 08:00 PM   #8
apeyuen818
Drives: BMW 435I GC
Hi, I'm new to the coding but I'm gonna try to set up my laptop and do the coding myself (Win XP). Just wondering if you mind to send me the presetup VM as well. I will be so appreciated if you can help me. Thanks soo much.
      01-09-2013, 12:21 AM   #9
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
The VGA wont be causing any problem
just make sure you set to COM1 for the USB cable
Latency to 1
Send us what errors you are receiving
Originally Posted by adriang View Post
Hey Rich,
      01-09-2013, 07:08 AM   #10
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
I am not exactly sure how to set the com1 for the usb cable,
however I found FTDI drivers off of FTDIchip.com and seem to have sucessfully installed drivers.
In device manager it seems as if the USB cable is com3
      01-11-2013, 07:41 PM   #11
rich123321
rich123321's Avatar
72
2015 335i  [0.00]
Double click on USB serial port. Click advanced settings then port settings. Set com port to 1 even if it is in use change latency to 1ms
      01-15-2013, 12:06 AM   #12
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
done that, but still not having luck.
I've also been reading about removing pin 8 from the cable, although not sure if I need to do this (for a 2009 Bmw x5 35d and 2011 Bmw 335d)
Maybe when somebody is bored one day, they would like to set up a remote connection to see my configuration
I've got the see-through cable off ebay with a white chip inside pin 7 and 8 soldered together.
      01-15-2013, 06:58 AM   #13
cn555ic
cn555ic's Avatar
441
Drives: 335i
If you have the VM machine it's basically dummy proof and should work right off the bat with just minimal tweaking of the comports. It would lead me to believe its the cable that's defective, or the comport on laptop is defective
      01-15-2013, 07:24 AM   #14
eddiem74
eddiem74's Avatar
Ireland
23
Drives: 2008 E92 325i M-Sport Coupe
Ill pm you now!
Hi Rich,
You seem to be the man.
I have just ordered my cable from one-stop-electronics and now want to get my software set-up. I have a laptop with Windows 7 Home Premium 32bit but as most of the software was designed to work with XP I am wondering could I take advantage of the presetup process you have also using VM?
PM if acceptable.
Thanks,
Eddie
2008 E92 325i Black Sapphire M-Sport Coupe
      01-16-2013, 11:37 AM   #15
mot
38
Drives: e92 AW M3 6MT
I dread the setup portion of coding...
      01-17-2013, 07:12 PM   #16
cole92
cole92's Avatar
Drives: too much
Setup is a breeze, just setup my macbook air tonight.
      01-18-2013, 11:50 PM   #17
Ducati848R
19
Drives: 06 325i
Can anyone help me get past this error:
In INPA
APILNIT: ERROR #135
API-0015 HOST COMMUNICATION ERROR
API INITIALZATION ERROR
NO API CALLS POSSIBLE!
Any help would be great.
Thanks
      01-19-2013, 09:43 AM   #18
mot
38
Ill pm you now!
Hi Rich,
PM if acceptable.
Thanks,
Eddie
Does this mean we can set up VM with win7 home? I believe only pro allows for winXP VM, correct?
      01-19-2013, 02:07 PM   #19
cn555ic
cn555ic's Avatar
441
Drives: 335i
Yes you would be able to set it up in almost any OS. Just need to run the software VMware and it will work.
      01-19-2013, 09:13 PM   #20
mot
38
Can someone send me this VM please?
      01-19-2013, 09:36 PM   #21
Ducati848R
19
Drives: 06 325i
I need Rich's VW as well if someone who has can send it.
thanks
      01-25-2013, 12:50 PM   #22
DrAmazing
Drives: '07 335i Coupe JB4
Same. I had it at one point but computer related mishaps led to me losing it. next time I back it up.
