Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding help
      12-19-2012, 04:44 PM   #1
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
Coding help
Hi
I have been doing coding for about a year and have had nearly 100% success.
However lately i have not been getting good results.
I get the following error:
VIN faulty
DATATRANSMISSION TO INTERFACE DISTURBED.
In the error.log i see
ERROR! Modul: LFCDHDIA.CPP (A_E65CAS.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
COAPI-2000: EDIABAS or SGBD error
IFH-0003: DATATRANSMISSION TO INTERFACE DISTURBED
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000
FGNR_LESEN
>> ERROR! Modul: COAPI.CPP, Proc: coapiReadFgNr, LineNr: 04, ErrorNr: 2000
FGNR_LESEN: A_E65CAS
Nothing has changed on my laptop. i use Windows 7 32bit in VMWARE. I can get the 2 black cirlces everytime however i get the above error.
Sometimes i can read the ECU but then when i go to write to the ECU i get the above error.
Any help would be appreciated
      12-19-2012, 07:01 PM   #2
rich123321
rich123321's Avatar
72
Drives: BMW 325i E90
2015 335i  [0.00]
That happened to me when I coded a friend of mines car. I just kept trying to read / write and it worked eventually. My guess is an issue with ediabas or maybe a low car battery charge?
      12-19-2012, 08:26 PM   #3
cn555ic
cn555ic's Avatar
441
Drives: 335i
This is weird. This issue is not the first I heard if this happening. I have no clue why. This also happened to one my friends trying to code a F series. His cable and computer would not connect at all but when I tried mine it worked. After I coded the car, he went back to try and connect with his setup, it worked! No explanation.
      12-19-2012, 08:32 PM   #4
mrtanz
Australia
24
yeah sometimes i can get all the way to checkcoapi.... then when i execute SG_CODE.... it gives me errors
other times when i click E89 then CAS i get the message straight away.
Could it be bad cable. I have had the cable for about a year and only just started happening
      12-20-2012, 04:24 PM   #5
mrtanz
Australia
24
I have read that jb4 needs to be put on map 0 for coding to work is this the same thing for proceed and could this be causing my problem
      02-22-2013, 11:13 PM   #6
ilovemye93
ilovemye93's Avatar
Drives: F32 435i
I'm having the exact same problem.
I'm using Windows 7 32bit and trying to code my 2012 E70
Any ideas?
      02-24-2013, 09:58 PM   #7
mrtanz
Australia
24
make sure latency is correct
Are you doing it through a VMWARE?
