M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      12-19-2012, 01:10 AM   #1
chudak18
chudak18's Avatar
68
Drives: E92 335, W463 G55
Write up of my recent H&R spring install
Hi, before taking this job on yourself, understand that I own a shop and have access to lots of different tools and equipment... please look over this write up before taking on a serious job such as this.... sometimes it's just easier to let the pros take care of it. Enjoy!
Obviously if you have access to a lift, hoist up your beast, performing this via the jack method will be a lot more difficult and dangerous.
I'll only illustrate one side of front and one side of rear, but they are identical. A simple look at our working area.
This is a picture of the sway link that will need to be removed to be able to remove the strut and replace the springs.
A shot of the mounting bolt on the control arm.
Method I used to remove the nut on the sway link.
Sway link seperated and moved to the side to allow removal of strut.
Tools used for sway link removal
A shot of the top mount of the strut
Start by popping off rubber boot
Carefully remove the EDC plug and make sure not to damage.
EDC PLUG
Three bolts that hold the strut in place, these will have to be removed.
Bolts removed and strut free
Tools necessary for removal of the bottom bolt and nut that attach strut to lower control arm. I suggest you use air tools in this case (very hard to do by hand)
Attach as shown and use the wrench to hold the nut in place as you impact the other end to remove the bolt.
Top of strut seperated from the frame.
This part is a little tricky, but with some down force on the rotor/hub assembly and some finessing of the strut itself and you should be able to gently force the strut assembly free of the hub assembly.
Strut assembly removed
A shot of the top of the strut and socket I used to remove the 'twelve point' nut
****IMPORTANT******
If you do not have access to one of these (spring compressor), stop and take your struts to a shop that has a spring compressor and have them do it for you for a nominal fee.... not worth losing an eye over... or worse, damaging your M5!!!! lol
Comparrison of the OEM spring and the H&R sport spring
Assemble the strut with the new H&R spring and use a impact gun to carefully snug the top nut
Reinstall the strut assembly and install mounting bolt and nut in lower control arm
Reinstall sway link
Align top mount to holes in frame. The srping will shift at this point with some force, get it nice and ligned up with the holes for easy reinstall.
Reinstall and tighten all bolts, and the EDC plugs and rubber boot... always be careful when handling the EDC wires and plugs.
LETS MOVE ON TO THE HARD PART.... THE REAR!!!!!
Pop the rear seat backs via latches in the trunk
Remove cap ends of rear seat by pulling on the top of the caps and then sliding out... the rear seat bottom can be easily popped out of place as well.
Once you release the end caps and rear seat backs, you will need to pull out four push tabs in the suede rear deck
Next you'll have to remove the AIRBAG cap to expose the screw holding the trim in place... this part really set me back... finding the screw was a PIA!!!
Once you remove the screws behind the caps, and you may or may not have to remove three 8mm screws in the trunk, that may or may not hold the sun shade in place (I removed them, but just as a precaution, always be careful, if it doesn't come easy, there's some thing wrong!) The rear deck should be easily slid out now!
CAUTION!!!!!!------ when the seatbelt housings are upside down, they will lock... the assemblies will think that the car is upside down... this is important when re-assembling the rear deck! You need to leave yourself room to be able to flip the rear deck and upright the seatbelt assy's.
You'll have to remove this screw to release the seatbelt assy.
This here is the rear strut mounting nuts and studs! Do NOT pull on the EDC wire on the rear struts!!!!!! They are perminantly attached... you will have to detach them from harness and fish them out with strut!!!!
This is a picture of what to expect in rear strut set up.... Take notice of the red arrows below. This stabalizing arm will need to be loosened and moved aside to be able to slide the strut assy out!!!!!!
This is the bolt that holds the strut connected to rear hub!.. Remove this.
Next you will loosen the top nuts to release the strut.
At this point you'll be able to work the rear strut out from behind the rear hub. Again pay close attention to not damage the EDC wire. You will need to again seperate the OEM spring from the strut assy, and install the new H&R spring, reassemble, and reinstall the strut assy with the new spring and reassemble the rear deck, seat backs, and other trim.
BELOW ARE SOME B4 and after pics... enjoy!!!!!
AFTER H&R SPRINGS
Appreciate 2
Jairomvp119.00
      12-19-2012, 04:07 AM   #2
jmh
Internet Crash Test Dummy
jmh's Avatar
331
Drives: F97 X3MC / F80 M3 / F90 M5
Nice job and wrietup !
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      12-19-2012, 05:33 AM   #3
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Excellent pics illustration & writeup.
      12-19-2012, 10:28 AM   #4
Rob///M5
Rob///M5's Avatar
76
Drives: 2013 M5 SSII
2013 BMW M5  [10.00]
Looks great!
I've read varying opinions...do the H&Rs get rid of the thunk noise in the trunk when going over speed bumps?
Thx
      12-19-2012, 10:32 AM   #5
Used2be
Perennial PFC
Used2be's Avatar
336
Drives: F90 M5 DG/Aragon
Great job!
I second that compliment. Thank you so much for taking the time and effort to so clearly document the process, and give the critical little hints that will make the job much easier! One thing, are there torque values for any of those important bolts upon reassembly, not just an impact driver setting, but an actual factory assigned tightening value?
      12-19-2012, 10:52 AM   #6
chudak18
chudak18's Avatar
68
Very valid question. As i was working on my personal car and trust my own work... Trust but always re-check after so many road miles.... I didn't bother looking those values up. If i can get my hands on them, i will post them up. I'll report back soon. Thanks for the questions folks.
      12-19-2012, 10:57 AM   #7
chudak18
chudak18's Avatar
68
Originally Posted by Rob///M5 View Post
Looks great!
Thx
I came from a G class Mercedes and those things are rattle/thump fiends. So for me the M5 rear thump was never really worth noting... Or maybe my car just doesn't exhibit those symptoms... But post h&r install, i would say the noise from suspension is the same/similar to what it was.
      12-19-2012, 11:01 AM   #8
Rob///M5
Rob///M5's Avatar
76
2013 BMW M5  [10.00]
Love the G wagon. Thanks for the info.
      12-19-2012, 12:55 PM   #9
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
Wow, this looks to be very involving. Great job with the write up.
      12-19-2012, 07:23 PM   #10
lincvert
19
Drives: M5 wannabe
What would a ballpark install be at your shop?
      12-20-2012, 02:00 AM   #11
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
Thanks for sharing.
How much time altogether did it take for the installation ?
      12-20-2012, 08:10 AM   #12
chudak18
chudak18's Avatar
68
Originally Posted by MCM5 View Post
Thanks for sharing.
This was my first time delving into the F10 so it took me approximately 7 hours... Given that i lost many hours trying to figure out how to take the rear deck apart and put it back together with the seat belts and all. Going back now with all the formalities out of the way, i would say armed with this write up and given you have the right tools, average of about 4 hours should be expected.
      12-24-2012, 10:36 AM   #13
Vic55
Vic55's Avatar
19355
Drives: 2023 BMW M8 Competition Coupe
Great writeup and pics, I had my springs installed in October and everything is good but one thing: my autoleveling headlights. They seem to be over adjusting and adjusting too much. When I drive straight they dip often and then pop back up and are relatively too high.
Was there a sensor or wire that might have been incorrectly reinstalled during my lowering process that you might know about?
Thanks for your assistance here.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      12-24-2012, 05:01 PM   #14
chudak18
chudak18's Avatar
68
If I'm not mistaken the sensor for the lights is on the rear control arm of the rear driver wheel. It's a little plastic assembly consisting of two plastic bars and one attaches to control arm, the other to a sensor with a pivot point to allow for compression. It in essence measures the distance the body travels when under load or weight, ie. Extra passengers in rear. The pivot point should be towards the wheel. If it was disconnected for reasons of strut fitment/removal, there is a chance it was inverted at time of reassembly. See pic below, it is in the far right and i actually disconnected this particular assy and in the picture the elbow is facing the wrong way, should be towards wheel. If i am wrong, some one correct me.
      12-24-2012, 09:12 PM   #15
Vic55
Vic55's Avatar
19355
Thank you so much... Ill have it checked on the 26th and report and thank back
      12-29-2012, 11:18 AM   #16
Vic55
Vic55's Avatar
19355
You were absolutely right- the elbow on mine was facing inward. We didnt do an uninstall we just pushed the elbow the other way and now it faces the wheel and my lights dont go crazy anymore.
Thanks again.
      12-29-2012, 04:34 PM   #17
chudak18
chudak18's Avatar
68
Good to hear. I almost did the same thing when re installing, reason it struck a note when you said what you had done to car and what was going on. Enjoy
      01-20-2013, 09:44 AM   #18
PatrickC23
PatrickC23's Avatar
186
Drives: '16 991.1 911 GTS, '16 F85 X5M
2013 BMW ///M5  [0.00]
Chudak - so your shop, would u do spring installs on the M5?
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red
      01-21-2013, 12:32 PM   #19
BikeGeek
BikeGeek's Avatar
14
Drives: E70 X5 35d, ATS-V, GTR
Excellent write-up. Although this should be just as accomplishable in one's own garage using hand tools, jacks, jack stands and a DIY spring compressor. Are there specific reasons you recommend only using a $800 spring compressor? My buddies and I have done many coilover installs using the $50 set from Sears.
BTW We plan on doing your same setup on a '13 M5 this coming weekend. The before-after is amazing!
      01-25-2013, 11:18 PM   #20
h4nh
h4nh's Avatar
237
Drives: 09 SC E90 M3 / 13 F10 M5
2009 E90 M3 (superc ...  [10.00]
2013 M5  [0.00]
I see you're one step ahead. Good thinking
      01-26-2013, 11:18 PM   #21
chudak18
chudak18's Avatar
68
Yes, very much doable on the floor with jack stands. Just less clearance is all. Also the $800 spring compressor is just easier and safer, heard horror stories with the two piece hand crank compressor for $50, wouldn't recommend it in writing, but again if careful, very doable. Most shops have a wall mounted compressor and they can do this step for you with out you risking one of the assemblies coming apart and hurting some one.
Yes i can do them... Did mine, no problem to reproduce.
      02-04-2013, 12:29 PM   #22
BikeGeek
BikeGeek's Avatar
14
Took us about 5.5 hours in my garage Saturday. Your write-up was great guidance.
2009 BMW E92 M3 | Jet Black / Fox Red, Extended - SOLD | Akrapovic Evolution - SOLD | MS Filter | StopTech ST60 / ST40, yellow | KW CS | 90mm stud conversion | 18x10F 18x10.5R HRE R43, Continental rubber | IND appearance package incl. key delete | JL Audio 10W6v3 (2) / HD700/1, Technic's harness
m5post
