F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Turbo Output
Studio RSR
      12-13-2012, 04:51 PM   #1
MNBart
22
Drives: '22 X5MC; '97 M3
Turbo Output
Anyone know what our turbo produces in lbs? I came from a GTI where the APR tune doubled the turbo's output but I am wondering what our BMW's produce stock. I haven't found anything on the topic using search so i apologize if it's out there
thanks!
      12-13-2012, 05:15 PM   #2
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Strange I haven't seen any threads on this either. What's the stock psi?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      12-13-2012, 08:51 PM   #3
utenigma
162
Drives: 2013 F30 335i 8SA M-Adaptive
Stock ECU on the N55 boost peaks at ~10psi
      12-14-2012, 10:36 AM   #4
mikew2069
mikew2069's Avatar
413
Wow that's pretty low. Lots of room to INCREASE!
BM3/H&R/Borla
      12-14-2012, 02:49 PM   #5
rallybull
rallybull's Avatar
179
Drives: F30 335i w/PPK
Not sure where I read it but it was something like 8.6 psi
      12-14-2012, 05:23 PM   #6
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
i don't think the stock block can handle insane amounts of more boost...12-14psi MAX, and that's probably meth.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      12-14-2012, 06:53 PM   #7
mikew2069
mikew2069's Avatar
413
The new Kia Optima 2.0T runs 17.5psi stock....
BM3/H&R/Borla
      12-14-2012, 07:50 PM   #8
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
Around 15 psi on pump gas no meth. with meth 16+
      12-14-2012, 10:08 PM   #9
shivaswrath
649
Drives: 2012 335i
this ain't a KIA, lol.
      12-15-2012, 07:11 AM   #10
mikew2069
mikew2069's Avatar
413
Exactly. I don't have much experience with turbos but why would the Kia 4 banger block be able to handle twice the boost as the Bimmer block?
BM3/H&R/Borla
      12-15-2012, 08:50 AM   #11
utenigma
162
Didnt research the kia, but off the top of my head they probably run less engine compression
      12-15-2012, 10:29 AM   #12
verbs
77
Drives: 2015 M235i
which is why you shouldn't jump to all kinds of assumptions that the 335i has tons of room to increase boost.
      12-15-2012, 10:57 AM   #13
mikew2069
mikew2069's Avatar
413
I am having fun and talking about what could be. Get out of here hall monitor.
BM3/H&R/Borla
      12-15-2012, 04:01 PM   #14
PeterM
17
Drives: bmw 335i
Boost will not matter that much its how much power it makes at that boost. Back to my 1.8T days i ran 24psi on stock turbo and 24psi on upgraded GT35R turbo the power difference is nigh and day and i ran the risk of blowing the motor. So are you saying increasing the boost by 4-5psi on a stock turbo N55 motor it will blow? Aren't the N54 guys pushing close to 500hp on stock engines.
2013 EB2 335i 6MT
      12-16-2012, 08:38 PM   #15
shivaswrath
649
Drives: 2012 335i
I was taking into consideration the turbo sizes and strength of the block.
I ran 23psi peak boost on my 4G63 block, but had a nice taper. The solid, iron block on an Evo VIII with its strong stock internals could take it, and the twin scroll turbo was a champ.
The N55 twin scroll turbo is significantly smaller...
      12-17-2012, 01:21 AM   #16
RPM90
890
Drives: 340i M-sport AT
BMW N20 18.9 psi.
Smaller displacement engines have to have very high stock boost pressure to achieve that type of power, as they have 33% less displacement compared to the N55's 3.0 liters.
The N55 can run lower boost pressure as it makes more displacement power.
1.0 liters more and 2 more pistons.
In simplest terms adding appx 15psi (normal atmosphere is 14.7 psi) of boost is like doubling the engines combustion chamber volume. For example, a 2.0 liter with 15psi of boost is like a 4.0 NA engine.
N20 2.0 at 19psi is like a let's call it 4.5.
N55 3.0 at 15psi is like a 6.0 NA.
But, the N55 has average boost a bit over 10psi, not quite double, 2/3's, or 2.0 liters more. 5.0 NA.
Even with a modest 5psi increase over stock, the N55 would then have 15psi of boost, doubling NA displacement to 6.0
The N20 would need 30psi total boost to make it like a 6.0 NA.
N55 with 30psi would be a 9.0!
That's why a larger displacement engine can run with less boost and create more power.
It also shows why the N20 is as powerful as it is compared to the N55.
This simple example shows a 4.5 vs 5.0 NA power.
This is just for fun, I'm not promoting this as exact as there are many variables.
The N54 is also a 3.0 running close to 9psi yet developed the same power as the N55.
But, that's a twin turbo vs a single twin scroll. It's one of those variables.
      12-23-2012, 12:25 PM   #17
RambleJ
RambleJ's Avatar
No_Country
57
Drives: F10 535i M-sport
Please go off of that assumption and let us know at what psi your engine goes boom.
Unfortunately engines are made differently, so simple assumption like that doesn't hold any value.
      12-23-2012, 04:22 PM   #18
mikew2069
mikew2069's Avatar
413
Once again, another hall monitor with a comment with absolutely ZERO value. See my comment about having fun talking about what 'could' be. Get out of here with YOUR assumptions that I actually want to just increase boost by 200% without accounting for other variables.
BM3/H&R/Borla
      12-23-2012, 04:41 PM   #19
RambleJ
RambleJ's Avatar
No_Country
57
my assumptions... Who pissed in your cheerios this morning kiddo.
Yes its pure speculation on my end seeing that this is my 4th turbo charged BMW.
It may seem like we are raining on your parade, but just giving insight from EXPERIENCE.
The n54 engine was able to handle double the boost with higher octane and FBO, but the n55 is not the same unfortunately.
      12-23-2012, 04:45 PM   #20
RambleJ
RambleJ's Avatar
No_Country
57
Unfortunately the differences between the n54 and the n55 are way more than just a different turbo set up and valvetronic. The n55 swapped out some internals to save some weight.
Search this Thread:
Advanced Search
f30post
