6MT High HP Misfire issue solved
12-12-2012, 05:38 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
UPDATE (12/26/12): Confirmed solution. Georgiatech335i replaced his stock dual-mass flywheel with a single-mass flywheel and the misfire is gone
Hi guys, In the last few weeks, 3 newly-installed single turbo n54s ran into a high RPM (~6500rpm) misfire problem. One local (tmo335tt) and two in florida. This came as a surprise to us given how many 6MT VFF single turbo cars are running around problem-free. We tried everything from updating DME software, revision CPS algorithms, changing torque limits/calculations in the flash, etc,. Short of disabling misfire detection in our flash (yuck), nothing seemed to solve the problem. We were working with tmo335tt for some time with this and it's a good thing that this problem happened to him because I don't think anyone else would have spent enough time figuring out the cause of the problem. Which he did. The problem has to do with the factory dual-mass flywheel that twists at high torque levels. Combine that with high RPM (where misfire diagnostics is most sensitive) and you get a misfire fault without the real misfire. It also explains why the the only three misfiring Single Turbo 6MTs have stock dual-mass flywheels while all others have single mass lightweight flywheels. I also recall BMW themselves changing the clutch/flywheel assembly on the 1M for this reason. And that is only with a small power bump. So no, the proper solution isn't to mess with the knock tables or to disable misfire detection (which I did today on tmo335tt's car until his new flywheel comes in next week). The real solution to run a suitable flywheel that is capable of withstanding the higher torque loads that upgraded turbos (and sometimes even stock turbos) are capable of supporting. Other option is to just make less power I suppose. Hope that helps those 6MTs (like BigTom, IIRC) that were battling high rpm misfire. And big props for tmo335tt for wrapping his head around this and figuring this out. It will undoubtedly save a lot of people headache in the future as they try to make more and more power. Cheers, shiv P.S. Here is some good info on the subject of dual-mass flywheels and misfire detection: http://papers.sae.org/2007-01-3544/ Shiv Last edited by OpenFlash; 12-26-2012 at 04:18 PM.. |
12-12-2012, 06:13 PM | #5 |
48
Rep 1,290
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
12-12-2012, 06:21 PM | #7 | |
1737
Rep 17,960
Drives: A Lot
Unless I'm mistaken I think even Dzenno, who eventually resorted and routinely recommends disabling misfire detection, also has a stock dual mass flywheel (but now with a fully built head). The latter didn't fix his misfire issue. Because the issue wasn't engine-related. Shiv |
12-12-2012, 06:27 PM | #8 | |
130
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
I kept thinking of Dzennos car as i was reading your thread, and then i saw what you mentioned. Interesting results that you came up with. Thanks, E
12-12-2012, 06:38 PM | #10 |
441
Rep 18,331
Should have jumped on it real quick. It was a matter of time getting the solution. Shiv having surgery didn't help either to expedite the solution. But either way glad there seems to be a fix. Looking to hear results
12-12-2012, 06:46 PM | #11 |
125
Rep 2,172
Yeah... I think if I would have had 20k on me before shift sector while we were working on it at FFTEC, he would have took it. That was a very frustrating weekend for him and a few other people who didn't make it... Can't wait to see what the solution will be for the AT cars.
12-12-2012, 06:50 PM | #12 | ||
11
Rep 442
12-12-2012, 08:29 PM | #13 |
Some dude
92
Rep 1,780
I wonder whether age and wear on the flywheel and/or vibration damper can contribute to this phenomenon. All in all, that's one incredible find!!
RRT
E92 335i/6MT with stuff and things |
12-12-2012, 08:40 PM | #14 |
48
Rep 1,290
6 people that were diagnosed with aids this week didnt smoke ciggarettes.
The 17 that didnt get aids do smoke. We have deduced that smoking ciggarettes is the cure to aids. Your welcome
12-12-2012, 08:42 PM | #15 |
Rep 69
To be fair, this is still theory and still unproven. Until such a time as the current 6MT ST misfiring cars install SMFW's and the misfiring goes away you are just assuming this is the problem.
12-12-2012, 08:52 PM | #17 |
48
Rep 1,290
YeAH the best part is Malboro stocks are still low. If you buy now, its an easy retirement
12-12-2012, 08:53 PM | #18 | |
177
Rep 6,631
cool i guess.
E90 LCI N54 6AT
12-12-2012, 09:16 PM | #19 |
292
Rep 2,898
Really interesting stuff.
Am I correct then that the problems encountered by single turbo folks with auto trannys are completely unrelated? Thanks and props to you and tmo335tt. Neil |
12-12-2012, 09:29 PM | #20 |
14
Rep 961
What direct evidence is there that it's the DMFW? I just have a hard time seeing it being the FW.
Are you saying it's because of the harmonics or the slight give between the separate sections of the FW? Have you had the car hooked up to an oscilloscope to verify the signal interference?
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
12-12-2012, 09:34 PM | #21 |
1737
Rep 17,960
Drives: A Lot
Hi guys,
I just posted up what I believe to be the cause based upon supporting evidence I've gathered. And this does include scope readings of the CPS waveform at various loads/rpm. What happens to the square wave at high RPM/high load, with a DMFW, is pretty interesting. I'll post up more data once tmo335tt installs a new FW in his car. But the link to the SAE papers that I posted in the first post should explain things for now. I'm not trying to sell people clutches. Nor do I have any stock in Spec, Tilton, etc,. I'm just posting our findings based upon the data collected. By no means do I suggest going out and replacing your stock DMFW. Unless you have a 6MT and are making over 500whp, it's unlikely to cause an issue. But if you are making big power and have had to disable misfire detection to prevent a high RPM limp mode, this is just something that you can look at. shiv |
12-12-2012, 09:42 PM | #22 |
38
Rep 864
Drives: '08 E92 335i
Just as a random question, whats the downside to disabling misfire detection?
