BMW X3 Forum
BMW X3 Forum
      12-06-2012, 06:56 PM   #1
Markap
18
Drives: 2011 X3 2.8
Passenger seat sensor
When I place my iPad on the passenger seat, the fasten seatbelt light and chime go off. Seems like the sensor is way too sensitive. Can this be adjusted or replaced? Anyone else have this problem?
      12-06-2012, 07:00 PM   #2
mge92
SPEED RACER
mge92's Avatar
375
Drives: BMW X5 M50d BMW M2 CS
you can code it so it never goes off
      12-06-2012, 07:43 PM   #3
02420X3
63
Drives: 2011 X3 35i
I have the same problem. It's not a weight issue, it's an RFI issue. I get the same result with two cellphones. I have sport seats, and my solution is to pull out the thigh support a bit, and put the cellphones in the crack between the thigh support and the seat. The iPad I just lean against the seatback.
      12-07-2012, 12:43 AM   #4
RichardBR
Norway
18
Drives: 2012 BMW X3 30D Msport DSB
Sounds strange. I can put my laptop backsack on the passenger seat with at least 5 kg in total. No seatbelt chime..
      12-07-2012, 06:11 AM   #5
BMWLVX
Drives: X3 2.0d
Same as RichardBR here. I've put more than 5kg on the passenger seat and never got the warning chime.
So, question about my wife's X3…
      12-07-2012, 09:41 PM   #6
Markap
18
Drives: 2011 X3 2.8
Yep definitely not a weight issue. My briefcase with laptop, iPad and a bunch of heavy stuff didn't set it off but the iPad by itself did. Guess its RFID so I'll look into turning it off via coding
      12-07-2012, 10:11 PM   #7
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
The laptop I was using to code the vehicle with was setting off the seatbelt warning so I coded it out.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      12-08-2012, 07:07 AM   #8
Nahoa
45
Drives: F25 35i Mineral Silver/Black
Coding solutions aside, yes, I have the same issue with the iPad. It's clearly an RFI-like issue and not a weight issue. For the original iPad it didn't have any impact sitting there until I plugged it into a charger. I now have the current iPad and it doesn't seem to create a problem.
      12-08-2012, 10:03 AM   #9
Markap
18
Drives: 2011 X3 2.8
I have the ipad2 and it was on the charger at the time. So, the testing continues....
      12-08-2012, 10:47 AM   #10
SoDigito
SoDigito's Avatar
24
Drives: 16%E2%80%99 X6 / 10%E2%80%99 5
BMW should fix this sensitivity issue. If I driving alone in my X3, I wouldn't want my passenger side airbags to go off if God forbids I get into an accident. I've seen the damage the deployment of those airbags can do and it's not pretty.
      12-08-2012, 12:17 PM   #11
Longbow64
_______
Longbow64's Avatar
169
There is a weight difference in whether the airbag deploys or not. I'm pretty sure is 90 lbs. Despite your seat belt gong going off, I don't think your passenger airbag is associated with it. You'd have to look to see if the Passenger Airbag disabled light is on next to the SOS button.
      12-15-2012, 05:05 PM   #12
02420X3
63
Drives: 2011 X3 35i
I looked, and the Passenger Airbag Disabled light is not on. SoDigito's concern appears to be valid.
      12-15-2012, 06:42 PM   #13
Longbow64
_______
Longbow64's Avatar
169
The light only illuminates if a weight is sensed that is less than the weight required to enable the airbag. If no weight is present the light will not illuminate.
      03-29-2013, 05:46 PM   #14
schappells
Drives: 2010 X3
My 2010 X3 seatbelt warning goes off with nothing in the passenger seat. The passenger airbag disabled light is on. The chime stops when I connect the passenger seatbelt. It does not happen every time I drive, but is very annoying when it does. Any ideas?
      03-29-2013, 06:06 PM   #15
mge92
SPEED RACER
mge92's Avatar
375
If anyone wants me to to code their car so it doesn't sound when you place a phone on the seat let me know! I am in the DC area.
xbimmers
