Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Will coding out bulb checks fix hyper flash from replacement LED turn bulbs??
      12-04-2012, 10:46 PM   #1
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
I bought a few bright white LED bulbs to replace my turn signal bulbs. They are not CANBUS bulbs (local supplier didn't have any) but they look amazing. If I code out all the check bulb programs will this stop the hyper flash I get or does only canbus bulbs stop hyper flash?
Thanks in advance!!
      12-05-2012, 12:14 AM   #2
07e92
121
Drives: 07 335i
code them out, I bought a set and although the seller claimed it is canbus, but still hyper flash on my 07
      12-05-2012, 06:33 AM   #3
makkan00
makkan00's Avatar
886
Drives: F83 and F36
It should.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      12-05-2012, 08:05 AM   #4
Volasko
Volasko's Avatar
705
Well the cable is on the way from ebay so only a few days to confirm this!
Thanks for the help gents!
      12-05-2012, 02:33 PM   #5
Elliott@DetailAddict
300
Drives: E90
Turn off cold and warm checks. On top of the hyper flashing, the LEDs will strobe when ignition turns on (cold checks) and after 15 or so minutes of driving (warm checks) which can present a dangerous situation when driving.
      12-05-2012, 03:15 PM   #6
Volasko
Volasko's Avatar
705
It is kinda hard to tell from your comment (the way you said "On top"), but are you saying that disabling cold and warm checks will stop the hyper flashing?
      12-05-2012, 03:20 PM   #7
300
Drives: E90
Sorry yes, it will disable the hyper flashing.
I was saying, in addition to no more hyper flashing, if you turn off the warm and cold checks it will disable all flickering.
Most people don't notice the warm check flickering since it happens while you're driving, but its not a good thing to have happening.
      12-05-2012, 03:46 PM   #8
Volasko
Volasko's Avatar
705
Good to know, I do have a canbus side marker LED that doesn't create any bulb error messages but I have noticed it flashing on startup (cold check) and while driving (warm check). Thanks for clearing this all up guys. Can't wait to start coding myself, this website has soo much good info!
      12-05-2012, 03:52 PM   #9
07e92
121
Drives: 07 335i
yeah... those so called CANBUS bulbs do not work well in 06/07 model. Best way is to code them out.
