Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Codes
      12-04-2012, 07:28 PM   #1
Lankster
Sigma Alpha Epsilon
38
Drives: 2007 335xi
Codes
2F6C - Exhaust flap (dont care)
2D2E - Angle of Throttle Valve - Intake pipe under pressure, correlation
30FF - Underboost
29D2 - Missfire Cyl 6
Is the 29D2 directly correlated to 30FF and 2D2E? Car drives fine, but once I reach about 130mph or 6k RPM the car goes into limp mode. Nothing on charge pipe at first glance and havent checked FMIC yet. Is 2D2E something worth my concern or not? (search results on what 2D2E means and how to fix it comes up with vague information)
Thanx y'all
Forum Bible http://www.albinoblacksheep.com/flash/posting
JB4, BMS DCI, Dimisa 4" tips, VMR 710 Matt Black, Plasti-Dip Mod
      12-04-2012, 07:44 PM   #2
Eric335
Eric335's Avatar
130
Drives: 2007 E92 SG 335i 6MT
2007 BMW 335i  [7.66]
30FF makes me believe theres a boost leak (chargepipe/FMIC). The 29D2 makes me believe you have either fouled plug/coil on Cyl 6 or it was caused by the boost leak as well (due to not having the PSI on the cylinder, causing it not to detonate correctly, causing a limp mode. Im not explaining this well, but you get the drift).
2F6C you can ignore, although i recommend plugging the trunk-wire back in for the sake of figuring out whats wrong with the car.
$0.02, take it or leave it
      12-04-2012, 07:58 PM   #3
Lankster
Sigma Alpha Epsilon
38
Drives: 2007 335xi
Ill be replacing plugs and coils tomorrow or the next day, also will be looking for leaks. My concern was the 2F6C and if I should ignore it or not. Now I know to ignore and I thank you for your $0.02 you can just paypal me that whenever u want =)
