F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Updated cheat sheet f30
GetBMWParts
      12-04-2012, 07:39 AM   #1
ilhan1103
ilhan1103's Avatar
11
Drives: f30 318 2012
2012 318D  [0.00]
nvm - please delete thread
Nvm
Apparently this list was known f30 info added with lies and also known f10 info.
Just a heads up:
If you have something by default it doesn't mean the rest if the world has it too.
If something doesn't work on your car it doesn't mean the code is faulty either.
I searched for weeks for sport display and it still isn't working for example
      12-04-2012, 09:29 AM   #2
Joshhleee
///M Enthusiast
Joshhleee's Avatar
30
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
sweet, thanks!
      12-04-2012, 05:56 PM   #3
zeezz
Drives: F30 328i Sport Line
Thanks ilhan. I noticed you have Turn signal HUD in there with two settings, this actually works for you? I don't think anyone else has posted this in the main thread, so if that's the case I will give it a shot as well.
      12-04-2012, 06:29 PM   #4
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
I don't have the HUD myself mate, sorry. But that one (and others that I don't have the gear for) are confirmed to me by others.
Good luck.
      12-04-2012, 09:46 PM   #5
Puri1
Puri1's Avatar
25
Drives: F30 328i 2012
DUDE, that's awesome... thanks so much bud..
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      12-04-2012, 10:54 PM   #6
Puri1
Puri1's Avatar
25
Just tried using some of these...
- Can't find the CAS or FRM ECUs.
- Can't find the following under ACSM..
3000 SBR_FA_GWF_SBR_FA
3000 SBR_BF_GWF_SBR_BF
3000 SPW_FA
3000 SPW_BF
- Could you also add the REM codings from Svache's original post so as to make this an all inclusive file..
      12-05-2012, 12:31 AM   #7
Alpine F31
Alpine F31's Avatar
918
Drives: MB E350 4MATIC Estate
Button on driver-side will be enabled to CLOSE the trunk
How would that work??? That must be for a wagon with a power lift gate right?
      12-05-2012, 01:03 AM   #8
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
If you have the button it means there is a tiny engine used to open the bootlid (tailgate)
Should you not have the button it means your bootlid is simply released and flies open, ie no mechanism. In the latter case you can close without slamming it shut
      12-05-2012, 01:06 AM   #9
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
3000 SPW_FA
3000 SPW_BF
Could you show a screenshot from your fdl editor? the values should be there under ACSM.
CAS might be under a different name perhaps depending on your car (is it an f30?)
FRM = Fembody my bad
      12-05-2012, 01:43 AM   #10
demge01
demge01's Avatar
Drives: F30 320ed
Nice work!
Good to see an updated version.
      12-05-2012, 09:59 AM   #11
G16grancoupe
G16grancoupe's Avatar
12
Drives: 2019 f90
any one have before and after pics of "brighter ambient lighting?" i always said wish mine was brighter but i dont want it to b overwhelmingly bright like when you open doors....
      12-05-2012, 10:33 AM   #12
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
I've set it to 99% and it's not at all too bright don't worry.
      12-05-2012, 10:44 AM   #13
G16grancoupe
12
Drives: 2019 f90
just curious.. what is "stock setting" on brightness%? 50%?
also are you on white or amber ambient..
      12-05-2012, 11:11 AM   #14
Frogman
288
Drives: 2012 F30 328i
Good luck.
Can you confirm with "the others" that they got the HUD turn signals working on an F30?
I know it works on F10's, but I have not been able to get it to work on my F30 and I have not seen anyone else get it to work either!
      12-05-2012, 11:25 AM   #15
Puri1
Puri1's Avatar
25
Could you post a pic of that? do you know what the default value was ?
P.s. I'll post screen shots of the module for the seatbelts when I get home.
      12-05-2012, 11:26 AM   #16
Puri1
Puri1's Avatar
25
I can confirm that all the REM's work under your updated sheet.
By the way.. thanks for updating..
      12-05-2012, 12:08 PM   #17
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
Good luck.
"the others" are people from this forum if you confirm something not working I'll change it.
I'm not an expert I consider folks like you and Shawn the experts.
That said ill update again marking thing I didn't use as needs testing or something like that
      12-05-2012, 12:09 PM   #18
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
Stock value was 64% it's stated in the column hex std
      12-05-2012, 12:23 PM   #19
G16grancoupe
12
Drives: 2019 f90
Awsome I really appreciate the help!
      12-05-2012, 02:59 PM   #20
Joshhleee
///M Enthusiast
Joshhleee's Avatar
30
sweet so if we put the ambient lighting to 99% it stays apart from the instrument lighting right? and if we turn the light swtich down does it turn the ambient lighting down also or is stuck at 99%?
      12-05-2012, 03:41 PM   #21
ilhan1103
ilhan1103's Avatar
11
2012 318D  [0.00]
Setting it to 99 isn't for getting it independent. You need ambiente nachfuerung for that.
Also it makes it independent of your instrument cluster slider, it will still only turn on with headlights.
      12-05-2012, 05:45 PM   #22
Frogman
288
US cars are already set at 100% and the slider is enabled. I don't think there's anything you can do to increase it past 100%
f30post
