Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Help, loss of engine power and engine malfunction light
      12-02-2012, 03:38 PM   #1
335M_PR
Got Boost?
335M_PR's Avatar
Puerto Rico
Drives: 2008 BMW E93 M3
I've been out having some fun lately with my N54 coupe. However, there is an issue taking place which has me worried. Whenever I'm under full acceleration (wide open throttle) and go past 125-132 mph the engine power dies on me and I get the yellow engine light indication on the trip computer area. It has happened at different speeds within that range. Once the power shuts I wait for a while and the engine indication resets and the engine operation returns to normal (I have the new upgraded resistance JB4 installed). Has this happened to anyone else? I don't know if it has to do with engine misfires or if it is a top speed governor. Any insight would be appreciated.
09' N54 335I Alpine White w/Coral Red Interior and Brushed Aluminum Trim/Sport Premium Package/Comfort Access/6 AT Steptronic/JB4 G5/BMS DCI/AR 3" Downpipes with Race CAT/ER Charge Pipe with Synapse BOV/2nd CAT Delete/M Tech Front Lip/M3 Rear Lip Spoiler
      12-02-2012, 05:33 PM   #2
Leekay07
Drives: 08 335XI Sedan
Pull the codes but its not a misfire. Misfire trigger the SES light. Your talking about the car going into limp mode. It doesn't sound to be the water pump but could well be the fuel pump (low or high)
      12-02-2012, 06:28 PM   #3
E93Blackhawk
E93Blackhawk's Avatar
31
Drives: 2008 335i M sport
the top speed governor is set at 155mph anyway so its not that
its probably the HPFP, pull the codes, you can't know until then really.
      12-02-2012, 09:13 PM   #4
Fun w/N54
39
Drives: '11 E92 335is AW/CR/DCT
What is your oil temp? Will go into limp mode at around 270 degrees.
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275.
      12-02-2012, 09:18 PM   #5
Exzackt
Exzackt's Avatar
Drives: n54 e92 335i/e39 540i6
i had this same problem.. Codes will probably be 29f2 and 29e2. Try changing your open fuel looping setting manually. You can learn how to do that on the jb4 sticky.. Except its now Future Use B not A on g5
If changing the fuel setting doesn't work. Probably the hpfp... just speculating though
2007 BSM 335i ZSP/ZPP l JB4 G5 ISO l E85 l BMS FLASH l METH l DCI l DPs l Twin BOVs l
Scoops l 18" Forgestar F14sl Koni Yellows l Swift Spec-R l GForce Rivals/Slicks l Quaife LSD
