BMW X3 Forum
BMW X3 Forum
      12-02-2012, 01:46 PM   #1
midwest 340xi 6sp
midwest 340xi 6sp's Avatar
360
Drives: 2018 340xi
Question for those in cold climates...
Do you keep your AC on the entire winter? In my older BMW's I used to turn it off, now I'm re-thinking that based on how well the AC can remove humidity..
Thoughts?
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
      12-02-2012, 02:39 PM   #2
gareth3685
13
Drives: 2.0D
Thoughts?
I tend to keep mine off, that's because I'm a tight a$$ and think (probably rightly) that I get better consumption with it deactived.
If its really wet and damp I'll switch it on to clear the condensation otherwise its off until those 2/3 days in July when its warm enough to warrant it
      12-02-2012, 02:42 PM   #3
rmeir
23
Drives: x3
in some cars the compressor runs all the time regardless of what u set it at. the defroster activates the air compressor so its basically the same thing, if you turn on defrost it turns on a/c. if the air is on, at least in my humble experience what happens it that the air is routed differently so there is more cold air. up to you but I dont know if you save a lot its not like old cars that a.c visibly affected performance
      12-02-2012, 04:05 PM   #4
HighlandPete
6659
Drives: BMW F11 535i Touring
If temperatures fluctuate around freezing, and humidity changes in your environment, I've found it best if left on, keeps the car dry inside and misting doesn't start to form.
Variable output compressors use very little power when in colder temperatures, so not like summer use for power/fuel consumption.
HighlandPete
      12-02-2012, 05:03 PM   #5
scotta2
Drives: MY2013 F25 X3 M Sport
Keep mine on most of the time, never noticed all that much difference in fuel consumption and it keeps the humidity right and clears condensation during winter.
      12-02-2012, 05:40 PM   #6
02420X3
63
Drives: 2011 X3 35i
I never touch the snowflake. It stays on all year long.
      12-02-2012, 05:58 PM   #7
Nahoa
45
Drives: F25 35i Mineral Silver/Black
      12-02-2012, 06:32 PM   #8
northX3
29
Drives: 2011 X3 35i
better to keep it on if it's below freezing.
too much humidity inside the vehicle may make frost inside your windows on the next morning. as a side note, keeping a lot of snow inside (on the carpets, for example) will give the same problem if it finds a way to melt.
      12-02-2012, 08:07 PM   #9
Nahoa
45
? The A/C takes moisture out of the air. Where would the additional humidity come from?
      12-03-2012, 10:34 AM   #10
colson79
Drives: 2012 X3 35i DSB
I know for me, I get snow on my shoes and get into the warm vehicle and the snow melts on the floor mats creating the humidity. I leave the snowflake on because it cuts down the fogging on the inside of the windows.
2012 X3 35i | Deep Sea Blue | Oyster |
Packages | Sports | Cold Weather | Cold Weather 2 | Premium | Technology | Premium Sound
      12-03-2012, 09:24 PM   #11
BeeMdblU
BeeMdblU's Avatar
452
Drives: F86, F25, G16
in previous cars the compressor won't kick in if temps are below 5celsius, not sure about F25.
      12-03-2012, 09:41 PM   #12
Nahoa
45
Thanks and apologies. I misread your earlier post and confused myself. Get your suggestion entirely now.
      12-04-2012, 12:21 PM   #13
snowboardjoe
Drives: 2013 X3 28i
Enabled all year long for me. The only time I turn it off is when I have all of the windows down on a warm/cool day. In Seattle it stays damp all the time and it was like that in North Carolina too in the mornings. Dehumidification is essential.
Think of the AC button as an "enable" function. It allows the AC compressor to be engaged automatically based on demands and control settings. It does not mean it's always engaged.
The AC is pretty smart on BMW's (for years) by using a multi-stage approach for efficiency and demand. Any AC system will not come on when it's really cold--law of physics. However, I believe it can still cycle if you are recirculating the air and it's warm enough in the cabin. If the air is cold enough outside, warming it up is usually more than enough to dry it out. I think front defrost button triggers full fan, full heat, AC, all vents on windshield and full recirculation.
Joe Morris
Last edited by snowboardjoe; 12-04-2012 at 12:24 PM.. Reason: Added middle paragraph for more info.
      12-06-2012, 07:28 AM   #14
BMWrules7
350
Drives: 2015, 740 LdX, Alpine White
The added humidity comes from the human body.
      12-06-2012, 08:49 AM   #15
Rodion
Finland
27
Drives: X3 (F25)
I keep mine on all the time. I think BMW compressor knows itself when not to run. Ie. Not to run in too cold temperatures.
And I have been told that it is not good to keep ac off all winter, because the compressor might get stuck on lack of lubricant. For example in warm parking houses the compressor runs and gets lubrication even if it is cold outside.
xbimmers
