Seat Belt Lights Blinking after battery replacement
12-01-2012, 08:28 PM | #1 |
Rep 80
Drives: 2007 335i
SO i replaced my battery and now my seat belt/airbag red lights will not go off
does anyone know how to reset them with out having to go to the dealership? thanks
JB4, Cowl Filters, Oil Catch Can, Sport Oil Cooler Valve Modified bmw Clutch Valve, Short Shift Kit, Short Throw Clutch Stop, VSRF 7" IC, VSRF 3" Downpipes, HKS Bov SSq3, ER Charge Pipe, H&R Sport Coilovers, Spec Stage 2+ Clutch & Flywheel, Stoptech Brakes, BMW P Exhaust, Dual Cone K&N Filters |
12-01-2012, 10:19 PM | #2 |
46
Rep 541
Is this the SRS malfunction warning? Part of the SRS system is a pyro that blows the battery clamp off in case of an accident. There's a sensor on the battery clamp that will cause a SRS fault if the wire is loose, or has a problem. Once the code is set, it will show up even if the problem no longer exists. It is possible that you jarred the connection while replacing the battery and set the code. You'll need a rest from the dealer, a BavTech tool, or INPA and a K+D-Can cable.
See my reply in this thread: http://www.e90post.com/forums/showthread.php?t=458022 and this thread: http://www.e90post.com/forums/showthread.php?t=383433 |
