Question regarding brake sensor for new brake pads
11-30-2012, 12:43 AM | #1 |
Rep 121
I just had my rear brake pads replaced by the dealer under warranty. There was still 11k miles left on the pads according to the wear sensor. Afterwards, when I check the mileage indicator via Idrive, it still states I have 11k miles left. This is even with the brake pads being new. When I called the service guy about resetting the brake pad wear indicator, he told me that it could not be done, and that it would stay at 11k for a while or until the brake pads were worn to about 11k miles left.
Is it true that the wear sensor for the brake pads cannot be reset up to a given point, or were my pads just not replaced? |
11-30-2012, 01:33 AM | #2 |
149
Rep 3,552
give your pads a visual look. All maintenance service interval reminds can be reset unless the wire itself needs to be replaced or you have low pad life.
check this thread out to see how. http://www.e90post.com/forums/showthread.php?t=384430 |
11-30-2012, 02:08 AM | #3 |
Rep 57
Sounds to me like they replaced the pads but not the wear indicator. If you reset it now, it will just show four dashes (----) on the display and throw up an error every time you get in the car.. Very annoying! Did they charge you for a new wear indicator? this should be replaced when they do the pads, especially at a main dealer!
The way it works is that it is attached to the pad and sits against the disk and wears down as the pad wears down, giving a reading of estimated mileage left until the pads are fully worn.. |
11-30-2012, 02:31 AM | #4 | |
Rep 121
I can look at the brake pad, but for some reason, the pad feels like it was replaced (previous one squeaked a little) |
11-30-2012, 02:58 AM | #5 |
Rep 57
If the sensor was replaced, there is no reason it can't be reset. Follow the link that idrift4wd posted and reset the brake pad indicator. If it comes up with the 4 dashes (----) then the sensor wasn't replaced and you should take it back to the dealers.
11-30-2012, 11:09 AM | #6 |
BMWCCA 149159
38
Rep 847
"The way it works is that it is attached to the pad and sits against the disk and wears down as the pad wears down, giving a reading of estimated mileage left until the pads are fully worn.."
Huh? Your car must be different from mine and all other BMW brake systems I have worked on. The wear sensor sits on the pad itself and will not activate until the pad is worn to the point of rotor to sensor contact at which point it closes the circuit and activates the pad indicator. Once the sensor is replaced the system should be reset within two driving cycles. Typically it resets when you power the car up. The brake pad reading on Idrive is purely an estimate of your pad wear based on the data collected by the car it does not measure wear on the pads it is an estimate... |
11-30-2012, 11:43 AM | #7 | |
331
Rep 1,268
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus Present: 24 992 C2 |
11-30-2012, 12:55 PM | #8 |
Rep 121
Thanks you guys! I followed the link from idrift4WD and McCoy and was able to reset the rear brake sensor. Thank you! It now says 25k miles instead of 11k.
11-30-2012, 01:54 PM | #9 |
BimmerPost Supporting Vendor
2045
Rep 25,989
Reset the indicator as everyone stated. If you get the dash marks, take it back to the dealership and ask them to change the sensor.
VMR|Wheels | 714.442.7916 |
11-30-2012, 02:05 PM | #10 |
Rep 47
Brake pad sensor
On the older BMW's that I have worked on, as the brake pad wears down the rotor contacts the wear sensor. As the rotor contacts the wear sensor it removes material from the wear sensor and eventually breaks the wire that is molded into the wear sensor. When the wire breaks the circuit is opened and the brake pad warning light illuminates. I have outened the annoying warning light by cutting the wires to the brake sensor and splicing them together, thus closing the circuit. Maybe the pad monitoring method has changed on newer BMW's. I resused the same sensors when I put different pads on my 2009.
11-30-2012, 03:00 PM | #11 | |
24
Rep 413
