My Custom 335 Intake Is Finally On!
08-10-2007, 07:24 PM | #1 |
Modder Raider
755
Rep 8,633
Drives: M3
First of all, I have my flame suit on for all of you haters.
Here's the thread that I posted when I was calling it a project. As you can see, I changed a couple things. I went with a smaller "3 connector" pipe. http://www.e90post.com/forums/showthread.php?t=68787 Second, I have no idea if this increases power. It most likely doesn't since there's no heat shield. So, why did I make it? Becuase it was fun to do. Instead of waiting for a company to offer one or to purchase the gruppeM for 1800, I thought it would be interesting to see if I could make something and I did. Of course, it could be improved, and I've thought of many ways to make this with the least amount of bends, but I really wanted to use the stock plenum so this is one of the reasons I came up with this design. Also, there really isn't that much room. So, how much did I spend? At the most 20 bucks, I used the ABS piping from Home Depot and made sure everything was glued securely. The filter I had in my garage with 4 others from older cars/trucks. I had 2 bigger filters but they wouldn't fit under the hood. I think that an oval would be perfect. I also had a sparco silicone hose that I used. Here's a video that I shot so you can hear what it sounds like. Sorry about the shakiness, but I was the only one home so I had to clip it to the hood so you guys could see. I'm sure that with a bigger filter and some better/bigger diameter piping the sound would be a little better. I'll check it daily to make sure nothing is melting (like some people said in my other thread), or coming loose. I wouldn't see how the abs would melt since it's not touching any metal. If the stock air box didn't melt then this will be fine. I'm going to do a dyno run next week on my procede that I put on a week ago, so I'll throw thi son afterwards to see if I increased anything (or if I lost anything). Now I need to find a heat shield. hmmmmm.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
08-10-2007, 07:40 PM | #3 |
441
Rep 18,331
looks very neat and as for custom looks pretty damn good...I hope you gain some hp with that mod....If you find some kind of aluminum sheet metal maybe that can be your heat shield!
08-10-2007, 07:59 PM | #4 |
27
Rep 528
+1
need a heat shield for sure. 2nd, is that the intake does one hell of turn right right there. I like the use of the OEM ram air through the kidneys. A for effort! |
08-10-2007, 08:15 PM | #5 |
164
Rep 2,409
nice effort but from what i remember reading on some other forums in the past is that the plastic would melt on NA cars. Now taking the 335 with its extremely hot motor.... I think you might see it melt/deform pretty soon, hopefully it doesnt. Either way nice work, look at a company called weapon r... they had some sort of shield + snorkel type device...
08-10-2007, 08:37 PM | #7 | |
153
Rep 5,780
This was not meant to be a knock, just speaking from experience. Different plastics have different operating temperatures. The plastic used on the stock intake is not ABS which is designed for ambient air use. The typical maximum continuous operating range for ABS is between 160 F and 180 F. After driving, with the hood closed, can easily reach this range. In fact, I placed a thermocouple between the intake manifold and the airbox and recorded 170+ with the hood open. Please be careful and keep an eye on it. Again, I wasn't knocking, just providing experienced knowledge on the subject. |
08-10-2007, 08:38 PM | #8 |
Samtaro!
125
Rep 2,601
Personally, I think the stock air filter has a larger surface area, and thus is less restrictive... in addition to pulling in cooler air.
08-10-2007, 08:46 PM | #9 |
Rep 76
Besides ingesting extremely hot engine compartment air, that piping looks very restrictive with all the bends.
Make sure you close the hood for your dyno runs to simulate real world conditions.
My crew. 2005 GTO Twin Turbo 10.8 at 133 mph 11 psi 4050# race weight |
08-10-2007, 09:12 PM | #12 |
11
Rep 600
Drives: 07 335i Coupe
CURRENT: 13 Turbo S - DD ** 12 Continental GT - Weekend Fun ** 13 GS350 Fsport - Wife's DD ** 13 RX350 Fsport - Family Hauler ** 14 IS350 Fsport - DD2 ** 14 Nissan GTR - Track
GONE: 13GS350 Fsport, 11TT, 13GTR BE, 13GS350 Fsport, 13 GTR Premium, 13GS350 Fsport, 09TT, 11 RX350, 12 IS350 Fsport, 10 E63, 08 E350, 11 RR HSE, 10 GTR, 09 C2S cab, 09 C4S, 09 C63, 06 CLS55, 06 E55, 05 E55 |
08-10-2007, 09:19 PM | #13 |
115
Rep 3,345
nice. lets get some dyno runs.
Brentuning Cobb AP pro tune -IG: @beemeraddict 2010 335i zmp fbo, 465/513 E60 mix |
08-10-2007, 09:35 PM | #14 |
153
Rep 5,780
08-10-2007, 09:41 PM | #15 |
153
Rep 5,780
That would be easier.
The manifold or light load pressure sensor can be seen under the cowl. I have a TMAP sensor I can snap a pic of off the car if desired. The extra one, on my work bench, is still functional but a test subject. I agree, it would be much easier to see on the car though with the main plumbing removed. |
08-10-2007, 10:37 PM | #17 |
17
Rep 605
I like the fact that he took the initiative to at least give it a try. If it works well and shows some gains, he could build it or have it built from metal so the temperature is a concern
08-10-2007, 10:46 PM | #18 | |
Modder Raider
755
Rep 8,633
Drives: M3
Did anyone check out the video that I posted in the first thread? It doesn't sound too bad. Like I said before, I think it's a good start and I'm not saying that this is the end all--be all. Hopefully, a couple companies will see this and start testing out their own. Just imagine if i had the capability to have a quick 2" to 3.5" piping with perfect bends that ended up with a big filter that all fit into a ram air setup.
08-10-2007, 10:49 PM | #19 | |
Modder Raider
755
Rep 8,633
Drives: M3
I'll be perfectly honest and say that when i do the dyno run, I will have the hood open, not closed.
08-10-2007, 10:53 PM | #20 | |
Modder Raider
755
Rep 8,633
Drives: M3
It looks like we are only using half of our air filter. The bottom of the box almost touches the middle of the air filter. Talk about starving for air!
08-11-2007, 01:27 AM | #21 |
675
Rep 4,080
I think there's a lot more going on with the air dynamics here then people are realizing. Example, the fact that the tube guiding the air to the filter chamber opens up so quickly lowers the velocity of the air prior to it reaching the filter without decreasing volume, and when air expands quickly it cools. Also, the benefits of ram air pressure through the stock system at 60 mph can't be replicated while the car is on a dyno, so the #'s from the dyno might not tell the whole story.
08-11-2007, 09:35 AM | #22 |
175
Rep 1,517
Drives: E92 335i coupe Black AUTO
your Intake very close to the engine. I hope you get again hp n torque.. It look like it will rob you some hp n torque.. Get a heat shield asap
