F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Drive moderately malfunction
Extreme Powerhouse
      11-23-2012, 10:08 AM   #1
slmdgee
Usofstance
78
Drives: 328I 6SPD
I was just driving around, did a 2nd gear pull and it got locked out of 3rd. Than a drive moderately message came up.., its strange cause I have a 6spd. Anyways I turned it off and it's fine. What could this be?
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      11-23-2012, 11:32 AM   #2
BMWgasm
Hooah!
BMWgasm's Avatar
Drives: 2011 335i M Sport
Sounds like you may have been in Eco Pro. If not I have no idea.
'11 E90 335i M Sport Black Sapphire
'13 F30 328i M Sport Black Sapphire
      11-23-2012, 12:38 PM   #3
slmdgee
Usofstance
78
Drives: 328I 6SPD
I think i was in comfort mode!!! I did it again in Sport with Traction control!!
      11-23-2012, 07:30 PM   #4
BMWforLife
BMWforLife's Avatar
26
Drives: 2021 330i
How long have you had your car?
My car did something similar, but I have the 8-speed. I had driven it for a thousand miles before the issue. I went to the store and when I got in my car to come home I got an error message saying something like “steering system failure, drive moderately”. I couldn’t switch between driving modes, use cruise control, and the rpm’s where limited even when using manual sport mode.
When I took it to the dealer they said that one of the control modules was not fully activated and that someone had “missed it” when they took delivery. Whether that is true or not I am not sure. The module had to do with DSC/DTC, not the actual steering of the car like implied by the message. They reset the fault, “finished” activating the module and I have not had a single issue since.
Gone but not forgotten
14 335i
12 335i 6 speed
11 328i
06 330i
      11-23-2012, 07:45 PM   #5
slmdgee
Usofstance
78
Drives: 328I 6SPD
i only have 450miles rite now, its all good now. If anything goes wrong again ill bring it to the dealer.
      11-24-2012, 06:24 PM   #6
rmnoonan
22
Drives: F30 328I (July '12 ED)
I had this at 250 mi and not since.... 2k miles later.
      11-25-2012, 07:31 AM   #7
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
It sounds like you went into limp mode. There are a number of possibilities but you will need to have the dealer read the codes. Here's the rub - with your down pipe it is likely they will blame that for the limp mode (not an unrealistic explanation) and flag your car for warranty purposes. I wouldn't take it in unless it happens again. If it does, I would take the dp off and see if you can recreate the issue.
What octane gas are you running? Which brand of gas? What was the ambient temperature?
      11-25-2012, 09:53 PM   #8
slmdgee
Usofstance
78
Drives: 328I 6SPD
Yeah they probably will, if it happens again ill take it off and bring it their! I am using 93 octane but i got the car with regular because of the gas crisis we had in new york the past couple of weeks. So today was the 2nd time i filled the tank up with 93 octane. It runs 10x better.
      11-26-2012, 08:40 AM   #9
mocohead
mocohead's Avatar
54
So my best guess, based on the regular gas, is that the motor was detonating and the car went into limp mode to protect it. Hopefully you will be ok now.
      11-26-2012, 01:42 PM   #10
slmdgee
Usofstance
78
Drives: 328I 6SPD
Yes hopefully!
f30post
