Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Code out Adaptive Headlights?
      11-22-2012, 09:57 PM   #1
trickcruiser
99
Drives: F80
Greetings,
I am still pretty new to coding but have had pretty good luck so far. This all started with an injector going bad...
Using IMPALOAD I was able to code my injector without issue
Then I figured what the hell, I have the cable!
Since then I have been using NCSEXPERT and have coded folding mirrors, removed seatbelt dings, removed IDrive startup warning, digital MPH, etc.
Now a few months ago, moisture found its way into my pass headlight causing the famous adaptive headlight failure... My question now is what do I need to do to remove this check from my car? I have searched for the past day or so and have not found much in terms of a DIY. I have read that I need to remove $524 from VO but I have NO idea how to do this... YET!
      11-22-2012, 10:01 PM   #2
cn555ic
cn555ic's Avatar
441
Drives: 335i
Remove $524 from VO from the PDF below showing you how to VO code...Then use expertmode and code default to CAS and NFRM and your done
      11-23-2012, 11:37 AM   #3
trickcruiser
99
Drives: F80
CN555IC,
Your the man! This is exactly what I was hoping to see.
So with the PDF example, they are adding $655 into the VO. Is it safe to assume that I need to find $524 in my list and simply delete it and then follow the rest of the steps in the guide?
Thanks again,
      11-23-2012, 12:07 PM   #4
cn555ic
cn555ic's Avatar
441
Drives: 335i
Yes but in our cars, it's not the LMA but the Nfrm module that needs to be coded along with Cas
      11-24-2012, 10:23 AM   #5
trickcruiser
99
Drives: F80
So I can get to the ADD screen but can not delete the $524...
I will keep searching but if someone has an answer on how to delete I would appreciate it greatly.
Regards,
      11-24-2012, 10:38 AM   #6
cn555ic
cn555ic's Avatar
441
Drives: 335i
Regards,
Your not looking hard enough
Here is the PDF on deleting VO..page 8
      11-24-2012, 11:13 AM   #7
trickcruiser
99
Drives: F80
OK, so the problem was that I am running virtual PC on a MAC and my keyboard does not have backspace. When in PC mode it sees my delete as backspace... Used a USB keyboard and I was able to delete $524 and run through the rest of my instructions (Including the NFRM part instead of LMA).
I have also changed CHECK_SMC_ERROR in the NFRM to nitch_active to turn off this check.
I still have the Addaptive error... Double checked and $524 is no longer in my VO...
Do I need to remove/clear the stored error code from the car? Or is there something else that I have missed?
Thank you for your help and patience.
      11-26-2012, 07:50 AM   #8
trickcruiser
99
Drives: F80
Bump!
Still stuck...
      11-28-2012, 04:37 PM   #9
trickcruiser
99
Drives: F80
I am still stuck.
Any ideas at all?
      12-04-2012, 05:00 PM   #10
dxu1789
Drives: 2007 335xi
If I am remembering correctly you need to recode your CAS and NFRM so they will update with the new VO data.
      12-04-2012, 05:02 PM   #11
Elliott@DetailAddict
300
Drives: E90
Sounds like you just deleted the VO... you then need to FA_Write to CAS and NFRM/FRM, THEN recode them (All of these steps in expert mode).
Please read the DIY and instructions carefully first before half coding your cars
      12-05-2012, 07:39 AM   #12
trickcruiser
99
Drives: F80
Grant,
I switched CHECK_SMC_ERROR to nitch_active when I did my initial coding (mirrors, windows, etc.) hoping it would eliminate the code. After deleting the option from my VO I went back and changed DYNAM_LWR_ENABLE to nitch_active.
So I should do the following:
1: Change CHECK_SMC_ERROR and DYNAM_LWR_ENABLE to active in NFRM using Expert Mode
1: Ensure that $524 is deleted and FA_Write (again) to CAS and NFRM/FRM in Expert Mode
2: Code CHECK_SMC_ERROR and DYNAM_LWR_ENABLE to nitch_active in NFRM using Expert Mode
I have a feeling I have made this much more difficult than it has needed to be...
Thank you for trying to help, I truly appreciate it.
      12-05-2012, 12:00 PM   #13
300
Drives: E90
No between FA_Write step and your next one, you need to SG_Codrien the effected modules.
That's the point of VO editing... you shouldn't need to code individual lines after properly updating and programming from the VO.
      12-11-2012, 11:57 PM   #14
MidLifeCrisis330Xi
MidLifeCrisis330Xi's Avatar
Drives: 2011 BMW E92 M3 Coupe
2011 BMW M3  [0.00]
2006 BMW 330Xi  [0.00]
i'm a newbie to bmw's but did some very basic coding to an Audi 2.7T many years ago. can you guys point me to where I can go to get details on how to code my 330Xi? thx.
      12-12-2012, 01:50 AM   #15
300
Drives: E90
Really?
Check the stickies and search this subforum please.
      12-12-2012, 01:42 PM   #16
trickcruiser
99
Drives: F80
Grant,
I will be trying to code out the adaptive headlights this evening! I will update on how it goes. Appreciate the guidance!
      12-12-2012, 05:43 PM   #17
trickcruiser
99
Drives: F80
SUCCESS!!!
Thanks for the help.
      12-13-2012, 12:18 AM   #18
300
Drives: E90
Cheers. Glad I could help.
      08-08-2014, 09:40 PM   #19
akumetsu
akumetsu's Avatar
Drives: 330i AW
Guys I have the same problem. I need to remove $524. I did it successfully for CAS. But, when I change ECU to FRM, I'm getting this error:
Error in CABD! Look at CABI.ERR and ERROR.LOG!
COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei
SYS-0005: SG-Beschreibungsdatei nicht gefunded FRM_87
COAPI-2000: Fehler in EDIABAS oder in SG-Beshcreibungsdatei
SG_CODIEREN
Please help me I've been stuck for 5 days now...
      08-08-2014, 10:34 PM   #20
spencers
Isle of Man
199
Drives: Sthrizzle
You need newer daten files. What version daten have you currently loaded?
      08-09-2014, 01:49 AM   #21
akumetsu
akumetsu's Avatar
Drives: 330i AW
I got the daten files from here http://www.e90post.com/forums/showthread.php?t=882353
so i guess its 50.2
Do you know where I can get the latest one that will work for me?
Thanks!
      08-09-2014, 09:39 AM   #22
spencers
Isle of Man
199
Drives: Sthrizzle
According to that thread you also need bmw tools 2.12. Is that the version you have installed?
Also what year is your bmw
