How to shut off boost solenoids during engine running.
11-15-2012, 09:20 PM | #1 |
125
Rep 1,546
Trying to get to the bottom of a buzzing sound at idle and 1k rpm..
Under the hood, its sounds like its coming from the front of the engine, maybe solenoid sides.. Is there anyway to shut the solenoids off safely, so i can cancel them out or determine if the solenoids are he culprit? |
11-15-2012, 09:23 PM | #2 |
130
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
Do you have a tuner? Check out my thread:
http://www.e90post.com/forums/showthread.php?t=768383 Hope it helps!
11-15-2012, 09:25 PM | #3 | |
125
Rep 1,546
I hear a buzzing sound in the car at idle to 1k rpm when revving in neutral. After 1k rpm it complete goes away.. Its annoying as hell.. |
11-15-2012, 09:34 PM | #4 | |
130
Rep 2,489
11-15-2012, 09:35 PM | #5 |
200
Rep 2,799
Could you just unplug the vacuum line that connects to the stock airbox? I left that unplugged one time, car reved fine, there just wasn't any boost, maybe that might help you out.
thanks to MGallop |
11-16-2012, 06:43 AM | #6 |
441
Rep 18,331
It is the solenoids farting in the video as i had the same exact noise. My issues when I had it was the tune creating the wastegates to cause this buzzing and farting noise. Cars seem to be finicky with certain maps and for firmwares, but once I loaded a firmware that I knew didnt make this noise the buzzing stopped. Loaded the maps that had the buzzing noise and as soon I as started the car the buzzing came right back.
11-16-2012, 08:07 AM | #7 |
Some dude
92
Rep 1,780
JB4 has a valet mode, right? You can put it into valet mode with no boost. That should cut power to the solenoids. If no, then just unplug them.
RRT
E92 335i/6MT with stuff and things |
